Question about Humidifiers
How to add water to a Bell and Howell color changing humidifier? I misplaced the instructions.
My bell and howell sonic breathe humidifier worked for the first bottle of water and thats it. now i put the bottle on and the steam only comes out if we squeeze the water bottle.
It sounds like a piece of ''something'' fell inside the hole where the bottle goes. Can you check for that?
Is it ''take-apart-able?'' I can pretty much assure you that if you can _see_ the components involved where that bottle makes contact, you will find an obvious problem.
Obviously water is not getting _past_ something, and it really sounds simple to me. (i.e. ''take it apart, find obvious problem and correct it, then reassemble'').
Feb 27, 2015 | WhateverWorks Bell And Howell Sonic...
Sonic breathe does not mist?
Find out where the mist is supposed to escape from inside the unit. Clear the airway.
Nov 30, 2014 | WhateverWorks Bell And Howell Sonic...
Where do I add the vaporizing steam liquid
I believe that you just have to add it with the water in the container. Here is a video detailing the product and its use.
May 20, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
How do you change the mineral absorption pad?
The pad is very easy to replace. Simply remove the water tank. The mineral pad floats in the hot water reservoir. Pull out the old one and discard if it has begun to break down. That's all their is to it.
I hope this helps.
Jan 01, 2009 | Slant Fin GF-210W 2 Gallon Humidifier
I need to know how to clean my filters on Hunter Humidifier Model # 33222. I have misplaced my instructions.
The instruction manual suggests using the water vinegar solution.
The following is from the manual.
1. Turn the humidifier ‘OFF’ and unplug the unit.
2. Lift the main housing and remove the water dispersion tray and the PermaWick™ Filters. The motor is attached to the main housing. Do not place the motor near water. Do not use a wet towel on the motor or motor housing as electrical shock may occur.
3. The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
4. After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
5. Remove the water tank from the base and empty any water that is left in the tank. Soak the base in a mixture of one (1) gallon of water and eight (8) ounces of vinegar for 20 minutes.
6. After soaking, wipe the base with a soft cloth or sponge to remove any mineral build up. Rinse with clean water several times. If you are planning on storing the humidifier, be sure the base is completely dry.
7. Fill the water tank with one (1) gallon of water and eight ounces of undiluted white vinegar. Replace the tank cap and shake the tank vigorously until all interior surfaces of the tank have been exposed to the water/vinegar mixture.
8. Empty the tank of the water/vinegar mixture. Rinse it several times with clean water and then replace the tank cap. If you are planning on storing the humidifier, dry it inside and out, leaving the cap off to allow the tank to completely dry. Continue to clean the other parts of your humidifier.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes. 41553-01 01/03/2008 6 © 2008 Hunter Fan Company
Rinse well and reinstall the water diffuser cap. Do not expose motor or other electrical components to water.
10. Wipe the surfaces of the main housing with a soft cloth.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOURHUMIDIFIERto continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location.
Dec 18, 2008 | Hunter CareFree Plus 33222 Humidifier
Continous ware flow on Honeywell HE220A Humidifier
I am having the same problem. I have had my humidifier for about 5 years now and I just started having the problem where the water continuously flows through the solenoid. I took apart the solenoid by removing the fittings from both sides. When I did that, I noticed that there was a hole in the metal that allowed me to see through to the other side. Apparently, it had corroded and and broken through, allowing the water to pass through the solenoid without really going through the valve within the solenoid. There are several sites that sell replacements for about $70, which is not cheap, but cheaper than buing a new humidifier for $120. Here is one site I found:
Oct 18, 2008 | Honeywell HE220A1019 Whole House...
Runs, but no humidity
These things have a "sponge" appearing part that is located below the tank. Be sure to totally soak that part in water before trying to use the unit. I had one of these about 3 years ago, and the same thing happened to me. I believe the "sponge", which is really a filter, actually wicks the water into the section of the humidifier that sends water vapor out of the top. You must completely soak it to "Prime" the system, so to speak. That is what worked for me.
Feb 11, 2008 | Honeywell HCM525 Humidifier
HM5081TG Reset Light won't turn off
Reset the unit once it is refilled by pushing the power button and holding it down for 5 seconds before releasing. This should reset your unit to factory settings.
Oct 21, 2007 | Holmes Products HM5080-U2 Humidifier
Humidifiers Logo
303 people viewed this question
Top Humidifiers Experts
Paul Carew
Are you a Humidifier Expert? Answer questions, earn points and help others
