My heat pump comes on only with the fan and not on auto; then it will not blow warm but show heat is on
  • Heating & Co... Master
  • 1,657 Answers
See if the compressor comes on when in cooling, sounds like a low pressure problem
Posted on Dec 20, 2016
Heat pump will not turn on in heat mode auto, the fan will blow if I turn on fan but it does not warm up the house?
If the fan does not turn on when set in auto and system to heat you likely do not have the thermostat set up properly. In settings be sure to set up heat pump with backup electric heat. Then the tstat brings fan in not equipment
Nov 13, 2016 | Heating & Cooling
Amana ptac during heat mode will blow hot air , then blow cold , but will cycle back to heat eventually is this Normal?
if the fan switch is in the Run position and not the auto position you are getting cool are when the heat element is not on. this is kind of like a way to circulate the air. look for an auto setting it then should only come on when needed. Keep in mind it is normal for the fan to start blowing before the heating element is warmed up, this prevents it from over heating, or coming on when the fan is not working
Nov 26, 2014 | Heating & Cooling
Coleman/ Evcon central electric furnace Eb15b thermostat on auto will not blow air out i hear a click u see and feel it heating up then i hear Another click dont see nor feel heat then but put thermostat...
check the thermostat setting on back for electric heat. sounds like it is on gas heat. the fan should turn on right away if it is electric or heat pump.
Nov 15, 2014 | Heating & Cooling
My furnace works on ac and blows on ac but on heat it does not blow but i hear a humming sound coming from the furnace
Most furnace operating on Oil or gas will heat the combustion chamber before starting fan to prevent cold air draft at start-up, can last a minute or two. Eiter the main flame does not come on or the chamber thermostat have fail. Try to modify fan option on room thermostat from auto to on. Cold air coming out: burner problem or no more oil or gas, warm air: burning chamber thermostat problem, leave room thermostat fan option to on until repair.
Jan 02, 2014 | Comfortmaker Heating & Cooling
Home AC only blows cool air when set to fan. When placed on Auto/fan it doesn't blow and no heat.
At your thermostat ,
Set switch to heat, turn up temp switch.
Fan should be set to auto. Wait up to 5 mins to be surethat somthing is wrong. If your fan comes on without heat. Check gas valve or if heat pump check main a/c breaker. If elect heat or any of above dosn't work.
Call a service company. If your in Pensacola. Look up Absolute Heating and Air Conditioning.
Oct 30, 2012 | Heating & Cooling
Heater blowing cool air
Is it set on summer switch which is the fan running all the time blowing cold air
Feb 15, 2012 | Heating & Cooling
Energy Knight heat pump refuses to blow!
Does this problem happen when the temperature is below 30 degrees? When it gets about that cold outside, the air outside is too cold for the heat pump to "steal" heat from. On the thermostat you'll find a switch labeled aux or emergency heat. Turning this switch on will operate a traditional coil heater inside the system, providing you with heat. The only downfall to this is that it uses more energy to heat this way. Try turning the fan switch from "auto" to "on". If the fan comes on, then we can rule that out. If the aux heat switch is NOT on, set the thermostat such that the system will try to heat. If the outside unit is running, the problem is either it being too cold like I said earlier, or there's a problem with the heat pump's mechanical system that needs to be serviced by a professional. If the outside unit doesn't run but it should be, check it's breakers at the panel, the breaker inside the electrical box that feeds it, and look to see if there's a reset button on the unit itself. Finally, check the air handler (part of the system inside with the fan in it) to see if there's any circuit breakers or fuses on this unit. Make sure they're not tripped/blown. If none of this helps, you definitely want to get a pro to work on your system.
Feb 27, 2010 | Heating & Cooling
Need a wiring diagram for jaguar xj6 series 3 4.2cc auto 1984 showing where the relays are for the heating system I pretty sure one of them has blown and will need to be replaced to get the fans to blow...
heating blows only cold air on my jaguar xj6 on a p registration
five weeks ago my fan belt snapped and when i replenished the overfill to radiator i used only water
Nov 27, 2009 | 1984 Jaguar XJ
Fan cycles on and off to often the burner stays on and the fan cy
what is happening is that the heat exchanger has to get to a certain temperature before the fan comes on that way you have warm air blowing out of the grilles and when the heat excahnger gets cool it shuts off until it warms back up again.
Jan 15, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
