Question about Tablets & eReaders
IOS device the links open the browser I want it to open the app
How do i get my apps to sim card
Do you want to transfer apps from your iPad to its SIM card? This might work on android but it's technically impossible to do the same trick on iOS.
However there are some other methods to transfer iPad apps to your computer or another iOS device.
May 15, 2016 | Tablets & eReaders
How do I downgrade to 0s7 from 8?
by resetting you settings
but 50-50
Feb 09, 2015 | Apple iPad 2 Wifi 16GB
How do I delete an app from my ipad when it does not show the x
The App that you are wanting to get rid of is more than likely a built in App. All Apple iOS devices ie iPhone, iPod, iPad, iWatch come with pre-installed Apps, these apps unfortunately cannot be deleted, Apple does not provide any options with these built in apps to hide, remove or otherwise. ALL NON Apple Apps will always be able to be deleted, like you have mentioned by a wobbly widget and an "x" in the top left corner. Hope this information was helpful, if so please click the link below.
Sep 20, 2014 | Apple iPad 32 GB WiFi Tablet PC
How do I download free Netflix app that is compatible with apple ipad1 first generation iOS 5.1?
install netflix on ipad first gen.:
first make sure your iPad 1st. gen is on iOS 5.1.1 !
It is possible, a bit tricky, but possible. First, you'll need to download the Netflix app through iTunes on your computer, this will make it show up as "purchased" in your library. After that, open up the App Store on your iPad 1 and go to the 'purchased' tab. When you try to install it this way it will tell you that you need iOS 6 or higher, but will also ask if you would like to download an older version of the app. then click on download.
- again step by step:
1) Open up iTunes on your computer
2) Go to Store (left hand column) ->iTunes Store
3) Search for Netflix; - download the app
4) then open App Store on your iPad
5) Click on 'Purchased'
- you will have to install NetFlix by clicking on it as usual.
App Store will ask you: "Download an older version of this app. The current version requires iOS 6.0 or later, but you can download the last compatible version.",
then click on Download and it should finally work.
download-free-netflix-app-compatible-ucocffsbdgqp14shduy2nfxr-3-0.jpg download-free-netflix-app-compatible-ucocffsbdgqp14shduy2nfxr-3-2.jpg download-free-netflix-app-compatible-ucocffsbdgqp14shduy2nfxr-3-5.jpg
Sep 15, 2014 | Tablets & eReaders
How to download showbox app for ipad
Open Safari & go to this URL.
https://itunes.apple.com/sg/app/showbox/id793056594?mt=8
bobwin
Aug 12, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Ios 6 download install can I install this app
on a 1.gen. iPad it is impossible to install iOS6:
this model supports only iOS 5 !
- NO iOS 6/7/8
- the processor is too slow....
For the iPad first generation (A1219) before iOS 5 to update is only possible with connecting the device to iTunes on a computer. Plug it into your computer and open up itunes under devices click on your ipad and then click on check for update.
- but this model supports only iOS 5
- NO iOS 6/7/8 !
ios-6-download-install-install-app-puadae1tafe2snbdqkdlrrgh-2-0.jpg ios-6-download-install-install-app-puadae1tafe2snbdqkdlrrgh-2-2.jpg ios-6-download-install-install-app-puadae1tafe2snbdqkdlrrgh-2-5.jpg
May 17, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Download ios
iOS is not an app - it is the running system of an iPad and is to be dowloaded from Apple:
- the download depends on the model of your iPad:
For the iPad first generation (A1219) to update is only possible with connecting the device to iTunes on a computer.
- NO iOS 6/7/8
for all other models:
There are two ways to upgrade the iOS version of your iPhone, iPad, or iPod Touch - via connecting the device to iTunes on a computer
- or directly from within the device, but only snce iOS 5, it is possible to upgrade the iOS version without the need to connect the iOS device to a computer (over-the-air update)
just go to: settings - general - software update
download-ios-ziidwqfjzh12fiagolk42ia4-3-0_0.jpg download-ios-ziidwqfjzh12fiagolk42ia4-3-2_0.jpg download-ios-ziidwqfjzh12fiagolk42ia4-3-5_0.jpg
Jan 30, 2014 | Apple iPad Tablets & eReaders
My iPad says i need to update to iOS 6 when I try to download on the app sore
- depends on the iPad model you have:
- but this model supports only iOS 5 !
- NO iOS 6/7/8 !
There are two ways to update the iOS version of your iPhone, iPad, or iPod Touch - via connecting the device to iTunes on a computer
- or directly from within the device, but only since iOS 5 it is possible to update the iOS version without the need to connect the iOS device to a computer (over-the-air update)
ipad-says-need-update-ios-6-when-try-ucocffsbdgqp14shduy2nfxr-3-0.jpg ipad-says-need-update-ios-6-when-try-ucocffsbdgqp14shduy2nfxr-3-2.jpg ipad-says-need-update-ios-6-when-try-ucocffsbdgqp14shduy2nfxr-3-5.jpg ipad-says-need-update-ios-6-when-try-ucocffsbdgqp14shduy2nfxr-3-9.jpg
Jan 28, 2014 | Apple iPad 32 GB WiFi Tablet PC
How do I delete open apps on the iPad air
there are 2 different ways to delete an App:
1) t's easy to delete apps from the iPhone or iPad. Simply tap and hold on any icon for about 2 seconds - see them to start to wiggle and tap the X button in the left corner. that's it.
2) For devices running iOS 5 and later, there is also another way to do this is hidden in the Settings app, in the General tab, under: usage.
- you can manage the apps on your iOS device. Once there, you'll notice (after a certain delay if you have a lot of apps) that your on-board apps are listed in descending size order. That means: the apps that take up a lot of space will be listed first.
Tap on any app and you'll get even more info, including the version, the size of the app and the size of the Documents & Data. Just below that, you'll have a Delete App button in red. At the very bottom, you'll see how much space is available on the device itself.
delete-open-apps-ipad-air-00ezcyyoy3jz4o4kppxkp0dk-3-0.jpg delete-open-apps-ipad-air-00ezcyyoy3jz4o4kppxkp0dk-3-2.jpg delete-open-apps-ipad-air-00ezcyyoy3jz4o4kppxkp0dk-3-5.jpg
Jan 10, 2014 | Tablets & eReaders
How to install iOS 5.0
How to do I update to iOS 5?
For the iPad first generation (A1219) to update is only possible with connecting the device to iTunes on a computer. Plug it into your computer and open up itunes under devices click on your ipad and then click on check for update.
- NO iOS 6/7/8 !
- or directly from within the device, but only since iOS 5, it is possible to upgrade the iOS version without the need to connect the iOS device to a computer (over-the-air update)
install-ios-5-0-b1rp0yxywxqcfecmaboiorny-3-0.jpg install-ios-5-0-b1rp0yxywxqcfecmaboiorny-3-2.jpg install-ios-5-0-b1rp0yxywxqcfecmaboiorny-3-5.jpg
Aug 27, 2012 | Tablets & eReaders
Tablets & eReaders Logo
21 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
