Question about LG Dryers
I have an LG gas dryer, DLG 3744. When running there's a squealing, squeaky noise. When I stop the machine and manually make some 3 revolutions backwards, the noise goes away but eventually returns.
    Top Expert:
  • LG Master
  • 40,547 Answers
The drum rollers in the rear may be worn or have dry bearings.
Posted on Dec 20, 2016
Where is the drain filter on lg 4408dle
Lg Washers have model numbers that start with WM
LG dryers start with either DLE(electric) or DLG(gas)
so check your model number and add comment below
May 01, 2017 | LG Washing Machines
How do I fix a squeaky belt on a minivan?
Post question is automotive section?
Is belt squealing? or is there a squeaky noise?
Squealing would denote belt slippage... belt might be loose, apply more belt tension at idler pulley (if possible). Consider trying a spray-on 'anti-slip" compound.
Squeaky noise could mean a bad pulley bearing.
Oct 13, 2014 | Dryers
LG Gas Dryer Noise
Contact the manufacture at their web site and get a Support Rep. to assist you with dowloads of Manuals.
Mar 25, 2014 | LG DLG2524 Gas Dryer
LG DLG 2526W dryer running but no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
May 22, 2010 | LG D2526 Gas Dryer
Lg dlg 7188rm gas dryer will not heat
Check to make sure that the thermal fuse is not blown. Small plastic piece with 2 wires coming off of it. Typically this is problem.
Feb 01, 2010 | LG DLG7188 Gas Dryer
LG DLG8388WM won't heat ...
It could be a clog in the supply pipes inside the dryer itself or a faulty regulator your best bet it to find a local repair shop as dealing with any gas appliance without proper knowledge can destroy your appliance or worse you PS: do you smell gas when it runs if so then it could be the igniter is faulty!
Nov 13, 2009 | LG DLG8388 Dryer
Loud squeaky noise when dryer starts, noise stops after several minutes
I would replace the belt that turns the drum. It is probably wearing out and that is causing your noise.
Jul 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Feb 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
