Question about Homelite Garden
I my homelite chainsaw was idel screw will not stay were I set it. It keeps making the chainsaw run too high. How can I get the idel screw to stay were I set it?
  • 22 Answers
Take screw out and clean. Put a drop off loctite on threads. Let dry and reinstall. This should give resistance to keep it where it is set.
Posted on Dec 28, 2016
    Sergeant:
  • 202 Answers
There should be a coiled spring on the idle screw. Since an idle screw is most often never tightened all the way down, the spring helps to keep it in the desired position by creating tension on the screw.
Posted on Dec 20, 2016
My 16poland chainsaw needs ideling adjusted it wont stay running
If it can be adjusted there will be a idler screw located on the carberator. Get it running and while you try to keep it running start adjusting the screw. I believe the turning it in increases the idle.
Nov 20, 2017 | Garden
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
Homelike chainsaw carb settings high/low
Hi, most chainsaws start with carb settings at 1&1/4 turns out( hi+lo) usually once the chainsaw has been run in, the 'hi' screw can be turned in an eighth, tickover set low enough not to cut out but high enough not to engage the clutch, cheers Billy
Feb 15, 2013 | Homelite Garden
Homelite 300 chainsaw carburetor settings
3/4 OUT HIGH MIX SCREW ABOUT 1 1/4 ON LOW SCREW, MAY NEED A LITTLE TWEAKING BUT THIS WILL GET YA CLOSE.. JAY THE PUMP GUY FL
Feb 02, 2012 | Homelite Garden
Setting carb on homelite chainsaw
Make sure that the air cleaner is not choked with sawdust. Turn both H and L jet screws CW to stops (lightly) then back out each 1-1/2 turns CCW. Start the engine and allow to warm up. Pull the throttle full on and adjust H CW so that the engine will speed-up somewhat, but still 4-stroking. Proper final adjustment is to be 4-stroking, but immediately 2-stroke when cutting. Allow to idle and adjust L so that the engine runs fairly smoothly, but will allow the engine to 'follow the throttle'. Set idle speed screw so that the chain doesn't move, but the engine keeps running. Hope this helps!
Apr 15, 2010 | Garden
Homelite timberman only runs wide open
im no pro but id start with the throttle stop adjustment and the low speed jet.
screw low jet in, till its fully seated, do not force it. then back it out 1 and 1 / 8 turns. this should get it running and ideling.
Feb 28, 2010 | Garden
Rebuilt carb need air and idel mixture screw settings. Blower runs but only a few seconds and then will not restart.
air fuel mixture screw shoould have initial setting of two turns out from lightly seated,check unit make sure cylinder is tight to base they only have two screws holding them down,if 2 cycle motor has a vaccum leak they will not run properly,also check compression if you have gauge should have a least 100 psi to run properly.
Oct 01, 2009 | Homelite 'Yard Broom' Leaf Blower
I need a manual for a homelite gas hedge trimmer HT-19 I need the factory settings for the carb. bottom out screw turn out 1 1/4 turn? Have to hold throttle wide open to run.
Hello cosorio70:
You can Get a Manual from the Following Site Addy;
https://register.homelite.com/contact_us/new and Fill Out the Required Information. Remember to have the UT Number if this Unit has One.
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade and for Chainsaws and Trimmers they Do Not Bog DOwn Under a Load. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 14, 2009 | Homelite Garden
Homelite ht 17 hedge trimmer won't stay running
Homelite support page was no help.    Usually with these small engines you start the needle placment by lightly seatign the needles all the way in and then  1and 1/2 turns out.    That is enough to get the engine started, then ajusted while running almost always father in. Idel jet at idle , of course and high speed jet under load,if possible. I would start with the carb first as that is the most likely problem.
Dec 25, 2008 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
59 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
