Question about LG Televison & Video
42lg61-ua tv has green flickering lines going horizontally. The lines show up more on darker backgrounds/videos.
The audio also has some problems as well, but turning it off and on again normally fixes it. The flicker happens on all inputs and it doesn't matter what device is plugged in.
  • LG Master
  • 6,694 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Dec 20, 2016
I have an LG plasma model number 60 PA 6500 UA a line that goes horizontal or there'll be a green out line going across parts of the screen then occasionally it'll I'll shut it off and the screen will stay...
It sounds like your display controller is dying. This is a little computer board in your TV that essentially controls the picture that shows up. If your TV is under warranty, the LG will fix it for you. Otherwise, it is probably not worth the money it would cost to get it fixed.
Oct 26, 2017 | LG Televison & Video
Lg line horizontal 1/4 down from top and down center picture still appears but screen flickers every few seconds sound good still what could it be 6 years old
The video processor is an issue. Is the picture quality ok otherwise, in which case it can be repaired fairly easily.
Dec 11, 2016 | LG 47LD450 47 in. TV
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Jan 18, 2016 | LG Televison & Video
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
Apr 25, 2014 - Uploaded by
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Samsung ln52a650a1fxza LCD has horizontal band of dark lines across screen
check connections on top of screen this is becoming a stockfault on samsung tvs
Dec 01, 2012 | Televison & Video
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
T.V. screen is green with bright horizontal lights top to bottom
There are 2 possibilities of green screen in this model.
1- Driver circuit of green gun is defective. 2- Screen itself is defective.
Now I want to know, do you have TV repair experience and basic electronics knowledge to test and check above 2 sections in TV?
Jan 10, 2009 | Sony FD Trinitron WEGA KV-32FS16 32" TV
Sony trinitron
the problem is that the horizontal blanking pulse wont tun off during horizontal retrace period. the problem is in the IC. that process the TV signal.
Apr 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Green lines on my Sony projection
Those are called retrace lines and they are the result of the blanking pulse not having the desired effect. This could denote a problem in the Horizontal section of the TV. In this case the green gun is not being turned off as it goes back to the left side of the screen.
Sep 20, 2007 | Sony KP-57WS500 57" Rear Projection...
Green horizontal lines
Hi, I have a Philips 29PT9009/12 TV. Recently I have begun to see horizontal green lines on my tv, when either watching a dvd or watch tv. This has gotten worse and now the green lines are more visible and the background is now turned a shaded green. Please help me. Thanks in advance
Apr 30, 2007 | Philips 28PW6506 28" TV
Televison & Video Logo
59 people viewed this question
Computer Repairing
Computer Repairing
