Question about Belkin Computers & Internet
How do you change the WiFi password on a belkin 313
  • 340 Answers
Please post full model no. with image
Posted on Dec 20, 2016
Set belkin admin password
Hi try this and let me know if this helps .
  1. Connect your computer to the router with a cable
  2. Turn off wifi if its a laptop
  3. Open router setup page by typing http://192.168.2.1
  4. On the left under Utilities Click System Settings
  5. Leave the password blank and click submit
  6. And here leave the current password blank, Create a new password and confirm it
  7. Save the changes
Hope this Helps
Regards
Rakesh Warrier
http://facebook.com/quietmouse89
Aug 03, 2014 | Belkin Computers & Internet
Need to reset password on a Belkin d80
To restore it to the factory settings press a paperclip into the hole marked "reset" for 5-10 seconds. Do that wile the router is on. Then if you need to set a special password you can connect to it and change the password.
To change the password connect to your router by going to your browser on your computer after connecting to your router. The default address for belkin is usually "192.168.2.1" for login its either "admin" or just left blank. there shouldn't be any password. After you login you can go through the settings and change your wifi name and password. Most routers also have many other security options like only allowing certain computers on that you add their mac addresses. Hope this helped. If you need more help just leave a comment.
Feb 11, 2014 | Belkin (F5D7230-4) Router (587009)
Name and passsword belkin f7d1301
  1. Choose a laptop or WiFi device that is currently connected to your network. If none of your devices are connected, use an Ethernet cable and connect a computer or laptop directly to your wireless gateway.
  2. Open a web browser and go to the Admin Tool (http://10.0.0.1) - this is the wireless gateway's administration site. The default settings are:
    • Username: admin
    • Password: password (case-sensitive)
    • Note: If you changed your Admin Tool password previously, you will need to use your new login information. If you don't remember your Admin Tool password, you will need to factory reset your wireless gateway. Instructions on how to do this can be found by reviewing the wireless gateway user guides at Wireless Gateway Guides.
  3. On the left navigation menu, select Gateway, then Connection and then Wi-Fi.
  4. Under Private Wi-Fi Network, you'll see the Name (SSID) of your WiFi network. (You may want to write down this information.)
    • Wireless Gateway 1 customers, click EDIT at the right.
    • Wireless Gateway 2 customers, click EDIT for both 2.4 GHz and 5 GHz bands to view the settings for each. ?
  5. Check the box next to Show Network Password. The Network Password (Network Key) will be displayed above. (You may want to write down this information.)
    • On this page, you can also edit your wireless network information, including changing your Network Name (SSID) or Password (Network Key). If you make any changes, remember to click SAVE SETTINGS.
  6. Now that you have your Network Name (SSID) and Password (Network Key), you can connect your WiFi devices to your network.
  7. If you have changed any information, use the new information to reconnect all your WiFi devices to your network.
Learn how an XFINITY Internet subscriber visiting your home can connect to WiFi without sharing your Network Name (SSID) or Password (Network Key)
Jan 04, 2014 | Linksys Wireless-G Broadband Router
How do i put a password on the router
The new Belkins already have security set up. I would not change it, and yes I have a Belkin.
Here is there user friendly web site:
http://www.belkin.com/us/support-article?rnId=7005
Oct 14, 2012 | Belkin (F6D42304) Wireless Router
Changed internet companys and now my belkin g router dosent work how do I reconfigure?
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Click on WAn settings and set it as your internet service provider settings.Then click on wireless settings enable wifi turn radio on If you want secure wifi then enable WEP security enter WEP code it is your password to connect wifi.. Let me know if you need further assistance. Thanks for using FixYa.
Jul 25, 2010 | Belkin (F5D7231-4) Wireless Router
Belkin router wifi with i phone and g1 will not connect the lap
this is because of the security type WPA enabled in the router...youo can login to router setup page by typing 192.168.2.1 in the internet explorer...click on security (found in the left side, if it asks for password leave it blank and click submit) and change the security type to wep64bit and type any 10digit number as your password in key1...dont type anything other than that in any other boxes....click on apply changes...
now scan and connect your network from iphone and enter security key and login....
also delete the preferred networks from your laptop and scan and connect again....
rate me if it is useful....
Feb 14, 2010 | Belkin Computers & Internet
When i try to connect my ipod touch to my belkin wireless router, it will not connect after i enter my password. i am able to connect my laptops and the wii with this password.
Open RSP by typing 192.168.2.1 on the Address of the Internet Explorer
Change the Security Mode into 64 Bit WEP
And also Disable Wifi Protected Setup
Dec 26, 2009 | Belkin F5D7234-4 Router
Security codes
In your router WEP or WAP security enabled so it ask for password.
For that follow below.
connect your router to computer with ethernet cable.
Then you can access it with following link.
for belkin routers http://192.168.15.1
for other routers
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then click wifi or wireless settings There is WEP or WAP security enable note down that code if it is in * or # format then add new code then save settings and restart router.
That code is your password to connect wifi.
Nov 22, 2009 | Belkin (F5D5231-4) Router
Computers & Internet Logo
96 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
