Question about Vacuums
Sears Kenmore sewing machine. Looking for a Replacement belt for 566 91591?
This is the model number of the sewing machine that I can find and I'm told it needs a new belt and the belt looks very worn and the wheel barely moves and smells like rubber-- the stitches do look ok
  • 6 Answers
SOURCE: Kenmore Elegance Upright Bagged Vacuum Belt Broken and Smelling
It sounds like the brushroll has caused your belt problem and will be the cause of your burning smell as well. What commonly occurs is that carpet fiber,hair,string, thread,etc got wound around the brushroll and some will get caught in the end caps which is where the bearings are.The end caps need to be removed and cleaned so that the bearings can allow the brush to rotate freely.Check that there is no melting of the end caps or the base plate where the end caps fit into the machine._Good Luck
Posted on Oct 26, 2008
  • 389 Answers
SOURCE: bissell lift off, brush won't move smell burning rubber belt fine
OK - so your brush roller is jammed. And yes, the belt is melting! Unplug the machine, remove the belt (you will need another new one anyway) then see if you can turn the roller by hand. If it turns freely without you doing anything else, then you may have put the new belt in incorrectly. However, you will probably find you can't turn it, or it's hard work (it should rotate freely). Remove the roller and check the bearings - there may well be something tangled up at one end of the roller. If you can get the roller rotating freely, all should be well.
Good luck
Posted on Mar 08, 2009
  • 821 Answers
SOURCE: Kenmore YM-40-35 R Sewing Machine
hello,please kindly visit the site below to see the comprehensive instruction with video on how to thread and bobbin your sewing machine.
http://www.wonderhowto.com/how-to-thread-mechanical-singer-sewing-machine-224245/
wish you good luck,
take care.
Posted on Jun 10, 2010
  • 51 Answers
SOURCE: operator manual for Kenmore 10
http://www.tradebit.com/filedetail.php/9322718-kenmore-12493-385-1249280-385-1249380-648800071
Posted on Sep 18, 2010
micromatikal
  • 2777 Answers
SOURCE: I need a instruction manual
Most manuals I can find for free online, but I have been looking for quite some time for a 158 manual and the best you can do is $5.00 for the one I will link you to at the bottom of the answer here...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
http://gotoes.org/sales/KenmoreManual.htm
Thanks
Tim
Posted on Oct 12, 2010
Where can i find a manual for a Kenmore Power spray carpet cleaner model number 175.8099?
There are more numbers in the model number than what you posted and Sears parts site come up with 4 possibilities. I assume that you are looking for an owners manual rather than a parts listing and it looks like all they have is a parts listing. I will include a link to the page that lists all 4 models in case you are looking for parts. Model Search Results
Jun 30, 2015 | Kenmore Vacuums
How do I change the belt on the 116 model?
To properly fix a belt on a Kenmore vacuum, you will first need to indicate whether this is an upright or a canister vacuum. The model given, 116, is only the first part of the model number, and all Kenmore vacuums, upright and canister style, start with 116. There is a period first, then a whole string of numbers, 116.255553 etc.
Kenmore vacuums are mainly made by Panasonic for Sears, and most will use a Panasonic belt. If the belt is an upright, this makes it simple, and will be a Panasonic "UB" belt.
For a canister vacuum, most models use what's referred to as a cogged belt. This type of belt has little teeth on the inside of the belt, and is Panasonic CB-5 belt.
Instructions on How to Replace the Belt for an Upright;
There will usually be to plastic screws on the top of the agitator housing on the base of the vacuum, that will say belt access. Simply take a flat head screw driver, and turn the screws so that the screw is pointing up and down on both sides. Then pull the plastic agitator housing, or the top of the base of the vacuum off. Inside you will see a the roller brush, and the belt (or broken belt). Simply take the new belt and wrap it around the silver pulley located in the back of the machine, opposite the roller brush, and wrap the other end of the belt through the roller brush. Stretch the roller brush back into the housing of the machine, and replace the top of the base of the vacuum back on the machine. You should give the belt a tug, to ensure that the brush is spinning when the belt is being pulled..
Aug 02, 2012 | Kenmore Vacuums
When I go to the manual category @ Sears and click on Kenmore Sewing Machine Manuals (including my model #), all that comes up are parts...they don't show manuals...where can I find a manual for my...
Here is a link to an online version of the manual. You are going to have to have the updated version of Adobe Reader X before being able to access the Manual.
Here is the link: http://www.managemylife.com/mmh/owner_manuals/2247/KENMORE-Mechanical-Sewing-L0909123?brand_name_search=158.14300+
Hope this helps!
Sep 16, 2011 | Vacuums
I am in need of a manual for a sears kenmore sewing machine model # 385.17124790. I purchased it from a friend and she did not have the manual that came with it. Also, I need a picture of the machine as...
google and type in --- user manual for kenmore sewing machine model385.17124790--- and find the site that has a pdf version to down load
as for the missing part , go to sewing machine repair shops and have them get one for you
Sep 08, 2017 | Vacuums
Seem to have a belt slipping problem. The motor runs but the belt is not turning. Have been trying to get new belts. IMPOSSIBLE !!! I have two machines...148 15600 and 385 1233280
I assume you need belts for both machines? Searspartsdirect (SPD) are the best place for Kenmore replacement parts.
There are 2 belts on the 385 1233280 - the timing belt and the drive belt. Both are in stock at SPD and can be obtained by clicking on the following link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Sewing-machine-Parts/Model-3851233280/0582/1220000/00024020/00008?blt=06&prst=&shdMod=
If you hover over the exploded parts diagram you can see a larger view. The timing belt is number 7 and the drive belt is number 15. If you scoll further down the page you can add them to your shopping cart.
They also have both belts for the 148 15600. They are numbered 16 and 17 in this diagram:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Sewing-machine-Parts/Model-14815600/0582/1220000/00033316/00008?blt=06&prst=&shdMod=
Again both are in stock, and can be ordered by scrolling down the page and adding numbers 16 and 17 to your shopping cart.
Yoiu may be able to get these from a Sears store, but you can any which you need from here.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 16, 2010 | Vacuums
I need a book for a Sears Kenmore sewing machine Model 153.14310
Hi.
Model 153.14310 does not exist. Model must be 158.1431 followed by other number.
The full manual is not available for online dowload. The manual is available for online purchase:Kenmore 1431
Here free threading diagrams.
Regards.
Ginko.
Oct 28, 2010 | Vacuums
Sears Kenmore Whispertone Vacuum Problem:
If you push inwards on each side of the light cover on top you can remove it. With the light cover removed remove the (2) access screws. Now you will be able lift of the entire top cover from the base. You will then see the belt and roller brush, remove the old belt and replace with a new one. You can get the replacement belt you need here:
Kenmore Whispertone Replacement Belt
Oct 28, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore Quick Clean Advanced Allegen - The plastic screws (for the cover that houses the belt and beater bar) are broken. Is there a replacement cover?
Go to Sears.com, click on parts, put in your model number, a parts list is available, also a picture diagram of it. You can purchase what you need from this site.
Mar 06, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
