SOURCE: GE frig just starting leaking water at the bottom of the freezer side door
The water on the floor below the freezer door is due to an inadequate door seal. The door is not closing completely, either a foreign object at the bottom, or more likely, the freezer door gasket needs replacing.
SOURCE: G.E SxS REFRIGERATOR
Ice maker works- door water dispenser does not- light comes on when dispenser is pushed.
SOURCE: GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
SOURCE: Replacing water line in freezer side door
Yes as I stated on other posts, go to an appliance shop and get a threaded connector. Mine cost about $7 and i had to do some minor adjustment cutting to the plastic guard at the bottom of fridge/freezer...so the new piece would not put too much pressure on the line. The white coupling connector on the line u will see has a red and blue washer conected on eitrher side of water line. To disconnect line ..just push in on top of washer and pull line. Cut the torn lines so u at least have a line that is clean and mostly straight, but dont cut TOO MUCH!! just the bare edge, about 1/8 " inch. Use some needle nose pliers ,real small ones.. to pull the line from bottom of door and apply connector. Put lines back on and do faceplate and check for leaks. Good luck!!
SOURCE: G.E. Side by side model quit dispensing water
It is possible the water line inside the freezer door froze . Remove the bottom kick plate and follow the white tubing about 6" to a coupling . Push in on the white ring and at the same time , pullout on the tubing . Push the water dispensor , and if water comes out of the hose going under the fridge , this means the line is frozen in the door . If no water comes out , it means the water tank at the bottom of the fridge section (behind crispers ) is probably frozen . A hair dryer should work on the tank , but , a different procedure will be needed to thaw the door . Come back if door is frozen for the procedure .
Testimonial: "The diagnostic aid was helpful. Still trying to figure out how to unfreeze the water line in the door of the side by side GE refrigerator, however. "
