We hooked a dyna glo heater up and its a unervisal unit we hooked up every thing the way it shows to hook it up to LP but 2 piolts come one together whats wrong
  • 625 Answers
SOURCE: dyna-glo
try this site - they have dyna glo parts
Posted on Dec 11, 2007
SOURCE: Dyna-Glo RMC95C6 Kerosene Heater
I have uploaded the manual for all to use here.
Posted on Nov 22, 2008
SOURCE: No Gas getting to the pilot
Thanks for the response......when I mentioned in the original problem of getting no gas that was with depressing the safety switch to light the furnace,,,,,,,,,I still get no gas when this switch is pressed.....I was looking at the furnace today and noticed there are a couple different lines running through different parts......I'm not sure which is a sensor you a reference site on the web that can help me or a place to find a manual for a dyna-glo heater ?
Posted on Nov 23, 2008
  • 359 Answers
SOURCE: a blower you can hook up to the dyna-glo wall mount heater
only if there is one for the particular model heater you have ck with dealer in your area
Posted on Dec 17, 2008
  • 2299 Answers
SOURCE: the heater blows the fuse
Does the fuse blow immediately? Or does it run for a while before the fuse blows? Please give me more detail. Thanks!
Posted on Nov 15, 2010
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
Jan 12, 2016 | Heating & Cooling
I need a thermocouple for a dyna glo heater model #RMC-40GT
I believe on your particular model , that you have to replace the entire pilot assembly. As the thermocouple is an intricate part of it. In which case any LP or Natural Gas heater's pilot assembly will fit it. You will have to secify either Natural Gas or LP Gas when ordering.
I have provided 2 links to where you can purchase the pilot assembly you need.
I hope this helps you & thanks for choosing FixYa.
Jul 29, 2011 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Dyna- Glo is manufactured by GHP Group, Inc. click the link:
Dec 13, 2010 | Dyna-Glo (PPH16-LP) Utility Heater
My Dyna glo Heater RMC-KFA210WH-03 will not fully ignite
I just bought one. The fuel line was cracked. Replaced it 2$ fix
Jan 27, 2010 | Dyna-Glo (PPH16-LP) Utility Heater
Dyna glo tag along propane heater pilot stays on but when turning
sounds like either a bad thermocouple or more likely a pressure regulator problem. should have unit checked by someone familiar with propane systems.
Jan 13, 2010 | Dyna-Glo (PPH16-LP) Utility Heater
We have a dynna glo zero clearance for Natural Gas
Before you attempt to covert to lp. You need to check the flue. Black smoke is cause by incomplete combustion. So it may be now plug with black soot. Heat-exchanger may be damage Before you invest in a lp kit. Make sure it is worth it. To convert you need the main burner orifices and lp spring for gas value. Once you replace these parts you must adjust gas pressure, nat gas is measured at 3.2 - 3.5wc lp is measured 10.5 - 11.00 wc. In my honest opinion this is to dangerous for customer to attempt. Please a HVAC contractor inspect unit and install lp kit.
Nov 20, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Yes and most larger hardware stores will carry the parts ( it should only be a connector and a small adjustment...cost...maybe $6.00 to do
Dec 08, 2008 | Dyna-Glo Heating & Cooling
A blower you can hook up to the dyna-glo wall mount heater
Nov 24, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
