Question about Dehumidifiers
Looking for a soft start dehumidifier - Dehumidifiers
After running for awhile the pump light starts blinking and the drain tube is not bent ?
Sounds like the plumbing is obstructed somewhere, try looking upstream as well as downstream of the pump. A very small piece of crud can cause a clot or embolism in the narrow channel. You might try blowing out the system with compressed air, but beware of getting showered with dehumidifier crud!
Jun 25, 2015 | DeLonghi DE500P Dehumidifier
I have H. Bay model HB40F dehumidifier. It does not seem to ever actually start the compressor. There is a plastic box on the side of the compressor that contains a couple of coily looking things. It...
It is probably the start device(the coil looking things), as long as you don't hear the compressor humming. A loud hum is a lock compressor and the cost would be far greater than a new unit.
Jun 17, 2011 | Soleus Dehumidifiers
I need a start capacitor for this model.
Look dont spend time looking for a start capacitor for a dehumidifier and just invest in a new dehumidifier they are pretty cheap. It may sound harsh buy its true its a better investment seriously.
May 12, 2011 | Ebac BD80 Dehumidifier
NEED THE RUBBER PIECE FOR WATER DRANIAGE; A PLASTIC CONNECTER TO THE SCREW ON WATER EXIT HOSE FITS INTO A SOFT RUBBER INLET PORT; THE SOFT RUBBER INLET COVER HAS MELTED. I NEED A REPLACEMENT PART
I will advice you check ebay.com to search for the replacement part and order for it or you can check any electronics sales shop to get the replacement part.
Take care.
Aug 24, 2010 | Comfort-Aire BHD-501 Dehumidifier
Compressor won't run
could be the thermostat or humidistat, check that the microswitch is being activated when you push the reservoir home, listen for a soft click.
Apr 08, 2010 | Whirlpool AD40USR Dehumidifier
I am looking to purchase a used Hampton Bay
This unit you looking to buy only covers 1000sqft .
Mar 17, 2010 | Maytag M7DH45B2A Dehumidifier
I have an old Sahara 25 dehumidifier need water collector chamber
I contacted GE on the web and found out they don't make the parts anymore for this unit. I used Gorilla glue to repair the cracks in the old semi soft plastic water collector chamber.
dmbrownpe
Jan 29, 2010 | GE Dehumidifiers
Dehumidifiers Logo
90 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
