How to operate envirastation model#dws130 - Computers & Internet
Envirastation model dws 170
Usually it is due to bad batteries or remote is too far away from home unit. Put units next to each other and press the channel button on front of the home unit. It will start a search to find the remote. If it finds it with a temp reading press the channel button again and you should hear a beep. Channel is locked in. If you still do not get a temp reading try changing batteries in both units and try again. Another try is to unplug the home unit and wait several minutes with no batteries in either house unit or remote. Replace batteries in remote then in house unit and plug back into power. Set all settings and see if you get the reading. If not try step one again. Weak batteries will do the same thing as well as remote to far away from unit.
Oct 06, 2013 | Measuring Tools & Sensors
Need instruction manual for EnviraStation DWS-110. Basically cannot get wireless to transmit to inside unit. Have new batteries in both units. Pls advise.
Here is a ink for the manual
http://www.simaproducts.com/support/files/FW_101_user_manual.pdf
You will need the free Adobe reader to open the file: http://get.adobe.com/reader/
J
Thanks for using FixYa!! I provide my answer for free as a public service - a 4 THUMBS rating and POSITIVE Comment is really appreciated for the FREE answering of your question.
LtCmdr Spock said: "An ancestor of mine maintained, that if you eliminate the impossible, whatever remains, however improbable, must be the truth."
Mar 06, 2011 | First Alert FWS-101 Wireless RF Weather...
I want to set my EnviraStation DWS220 to the right time zone.
TIME ZONE SELECTION
Press SET" button on the front of home receiver to select from the following
time zones in the U.S. (zone is displayed in the upper right hand corner of
time display).
P - Pacific Standard Time M - Mountain Standard Time
C - Central Standard Time E - Eastern Standard Tim
Dec 05, 2010 | Measuring Tools & Sensors
Outside temp not measuring correctly
I keep the outside unit of our in/out set under a coffee can shaded under a bench; one could argue the aesthetics but shielding it from wind and sun is mandatory otherwise one can get record temps pretty often.
The outside units generally transmit to the receivers only every few minutes to keep battery consumption down so moving them won't necessary gie you an immediate change.
Jul 15, 2009 | La Crosse Radio Controlled Atomic Clock
Computers & Internet Logo
David Payne
David Payne
