Question about Samsung Televison & Video
UN43J5200AF is the model of my samsung tv. I need help identifying model number of T-Control Board.
  • Samsung Master
  • 6,694 Answers
Posted on Dec 20, 2016
I have a Samsung 32" LED tv model number UN32F5500FXZA. It has sound but no picture but passes the flash light test. I don't see any backlights. Any idea what the part is?
The backlights are located around the edge of screen inside the tv. Now this model is know to have LED failures. The LED strips are you backlights. The LED strips are powered by the power supply board but due to the fact that this model is know to have LED failures, I would recommend replacement of the LED strips, all of them, first. Samsung BN96 25300A Replacement LED Strips UN32F5000AF UN32F6300AF
This website currently doen't have the parts in stock for your tv however this will help you identify the parts and they even have some tutorials.
Feb 04, 2017 | Samsung Televison & Video
I have a faulty Samsung LCD TV and i would like help identifying the part of the TV that needs to be replaced.
like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 12, 2016 | Samsung Televison & Video
Where can I get a power supply regulator board.
You will need to do the following. Every TV is different and no one guess it for you.
1. Note down your TV manufacturer name; Model number; Serial #
2. Place the TV on the Bed upside down and remove the back cover with correct ***** driver.
3. Identify the power board and look for the symptoms like blown capacitors etc.
4. Note down the board number. Take a pic and seek help to identify if necessary.
5. Google and research site like
TV Parts LCD TV Parts Plasma TV Parts TV Repair ShopJimmy TV Parts Rear Projection Plasma Big Screen Satellite LCD TV Parts TV Repair Parts eBay Samsung Television Replacement Parts Accessories
6. Some websites suggest equivalent part codes too.
Apr 07, 2016 | Televison & Video
Where is capacitor located on TV
There are several.
You should be identifying the four large components
- Power board
- Logic board
- Timing Control (TCON) board
- LED inverter driver board
99% the capacitors you are looking to identify for a power related issue on the power board.
capacitors look like
26155016-a3z50hdvc01hdf5dkelcuavu-4-0.png hope the video below helps you identify the defective capacitors
Fixing the Blown Capacitor in Samsung TV Yourself
What component should I get to fix my Samsung LCD TV?
HI,
Probably the t con broad is faulty. t con board id the on which drives the LDC panel. I some tvs its not possible to replace the T con board as it would be integrated to the LCD panel normally in 32 inches and bellow. In others i would be separate board which is replaceable individually. I have added a video to know how to locate a t con board which is replaceable individuality. As you didn't mentioned the model number its not possible to add the exact image. In all most all the tvs T con Board (individuality replaceable one ) will be placed on the top center of the tv cover with a metal shield. If its incinerated to the LCD panel then inside the LCD protection metal chassis. Check and fin which one you have.
Samsung LCD TV Repair Identifying Samsung Con Board Part Numbers How to...
www.electro-medical.blogspot.com
Sep 10, 2015 | Samsung Televison & Video
Hello, I have a problem with my Samsung UE32F6400 TV. Please have a look: https://www.youtube.com/watch?v=UZcq26EysEQ&feature=youtu.be https://www.youtube.com/watch?v=B8AXt3KkI_U&featur
Looks like a damaged t-con board. You will need to identify the model number on that specific board for a replacement.
Here is a link to some, (May not be exact model you need)
http://goo.gl/VZBmBI
Nov 24, 2014 | Samsung Cell Phones
Need to get the circuit diagram for board e106527 srf-c 94v found on TV Digistar Model CR_20SS01D
quick way with location number for the part (a cap?) will be marked on the board---call the maker or Google the model number with the location number.
Oct 15, 2012 | Prima Televison & Video
I have a 46 inch Samsung plasma HP R4252 picture went black
Probably the power supply that drives the video has gone bad. Samsung recommends the TV go to a service center. If you have some skill and are willing to try, open up the back of the TV, remove the shielding and look at the boards to identify any obvious damage. Leaking or bulging capacitors, soot, scorch marks are the obvious. (Other parts can have bad solder or tiny cracks that are hard to spot.)
http://www.shopjimmy.com/catalogsearch/result/index/q/HP-R4252 has reclaimed parts for this TV. These are parts from TVs that were damaged in shipping and were only run during quality control tests. They list several power supplies for the model so check what part number is actually installed (there is usually a label on the board).
I hope this helps.
Aug 01, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
60 people viewed this question
Jerry Greenberg
Jerry Greenberg
