Question about Garden
I haven't started my Craftman 27"snow blower in over a year. The switch is on, the fuel valve is open, the choke is on, I filled the tank with fresh gasoline but it still won't start. What do I do?
  • 2,226 Answers
Check spark plug wire is connected. Remove air filter and check it. Try some starter fluid.
Posted on Dec 20, 2016
Troy Bilt 3090 snowblower surges off choke, doesnt surge on choke, cleaned the carb, jets, float, drained tank, cleaned fuel filter, fresh gas, still surges. Could it be the governor or idle jet?l
you could try opening up the idle/mixture screw another turn to make the transmission from idle to throttle better
governors just open the throttle butterfly according to the spring tension setting from the throttle lever
Dec 16, 2016 | Troy-Bilt Storm 2840 277cc 28-in Two-Stage...
Have Troy Built 3090 gas tank was dry when I put fresh fuel in won't start
Fuel shut off still off? Fuel filter? Owner's manual troubleshooting?
Mar 06, 2015 | Garden
I have a Craftsman Snow Thrower model # 247.881731. At the end of last year I drained the gas as recommended in the manual, this year I filled it with fresh gas and it now has a problem starting. I pu
Draining the gas from the tank doesn't drain the float bowl in the carburetor. It still had last year's gas in it. Gas will start to turn to varnish if left sitting 6 to 12 months. You'll probably have to remove the carburetor, disassemble it and clean it out with Gumout carb cleaner or some similar product.
When you get it running and the snow's over and done with, put some Stabil in the gas tank to prevent the gas from converting to varnish and then start it up and run it until that stabilized gas is through the carburetor and into the engine. You can leave it with the treated gas in the tank.
Feb 01, 2015 | Craftsman Snow Blower 26 In. 208CC...
Need starting instructions for Ariens snow blower Model # H5065226H
do you have a fuel shut off valve? if so make sure its in the open position. choke closed,prime 3 times and pull cord. if not started after three pulls open choke and look in carb for fuel delivery. if none service your carb also check to make sure you have spark before assuming its the carb
Nov 22, 2014 | Garden
Snow thrower starts then shuts down after a few minutes
Hmmm... THAT sounds like you have an obstruction (ice???) in the fuel line or in the bottom of the tank.
Feb 15, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Not getting gas
The bulb usually doesn't feel that way, you're thinking of a small 2-cycle machine where the bulb will fill up with fuel and offer resistance when pushed. A primer on a snowblower is merely to get fuel flowing to the carb from the tank, whereas the bulb on 2-cycle items actually purges air from the fuel circuit. If you keep pressing the primer you should see fuel drip from the carb inlet. Btw, if you see where an air filter might be on other motors, a little metal cup looking thing, try removing the bolts and flipping it over so the fuel drips out easier and snow doesn't have the chance to fall into it if it were facing up. Once you see fuel dripping out, provided you ran it dry last season when you put the blower away and the carb isn't gummed up with varnish, it should start on full choke. Give it about 3-5 seconds and move it to half choke. Once it seems to want to run on its own, open the choke completely and you should be warmed up and ready to go. Also always remember to let engines idle a bit to cool down if you've been running them at high rpms.
Nov 11, 2013 | Mtd Yard Machines 24" Two Stage Snow...
Start up instructions for PM05450-07.02
check the oil level fill fuel tank with fresh fuel open the shut off valve on the bottom of the tank put choke on and turn the kill switch to the on position and pull the rope release choke after i second pull alway shut the fuel off and run the carb out of gas when done using it
Sep 03, 2012 | Coleman Powermate 6250
Starting problems . never used it before just need simple instruction
  1. Fill the tank with fresh properly mixed fuel.
  2. If equipped turn the switch to RUN or ON
  3. Make sure the tank is full of fresh fuel mixed per directions.
  4. pump the primer bulb until resistance is felt and fuel is seen pulsing through the lines without bubbles.
  5. pull the cord sharply and repeatedly until the motor "hits" on one of the pulls
  6. set the choke half closed
  7. pull the cord sharply until the motor fires and idles.
  8. allow the engine to idle until it will warms up and will idle when you slide the choke all the way open.
Jun 04, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Craftman leaf blower when I press primer bulb I get air in line. It seems to be coming from block that choke is attached to hoses look good.
Diaphram gasket in carb is swelled and air is getting through,get a carb reduild kit and it should be fine.
Aug 05, 2009 | Craftsman Blower Attachment
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
