Rudd achiever heat pump will not come on. Fan works but no heat.
  • Heating & Co... Master
  • 1,867 Answers
Possibly stuck reversing valve?? Does it cool well, just no heat?? Possibly low voltage wiring in tstat, did it work last year??
Posted on Dec 20, 2016
  • 25 Answers
SOURCE: ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Posted on Nov 22, 2008
  • 4 Answers
SOURCE: Rudd Achiever Plus - Fan runs 24/7
it does sound like a limit switch to me as well. Make sure the fan switch on your thermostat is set to "auto" and not "on"
Posted on Mar 21, 2009
TheMobilian
  • 8220 Answers
SOURCE: Rudd Achiever A/C float switch is clogged.
If the pump was bad the switch is supposed to shut down the ac so the water damage won't occur. You most likely have a bad drain.
Posted on May 11, 2009
  • 1252 Answers
SOURCE: Ruud Achiever 10 heat pump - outside fan won't shut off
Definately get this checked out. Some thing has shorted just enough to let voltage "Feed back" and keep the fan running. Could be capacitor, wires rubbed through each other, etc. A reset is a safety that is used when there is an overcurrent or over pressure situation. No reset set for this situation.
There is always an outside chance that if you touch the unit while standing on wet ground, you may get shocked. I firmly believe that something is allowing power to the fan in a feedback condition so don't let this go as it may cause damage to other parts.
Good Luck and let me know how you make out on this.
FurnaceGuy
  • 74 Answers
SOURCE: I have a Rudd Achiever 14 and I want to know if
Take the front panel off the air handler and look for a heat element. You should notice controls and relays with larger wiring to it. It may not have any heat but you can add it.
Posted on Jan 06, 2010
I have a rudd UHLA-3617JA high achiever air handeler, works fine except the electric heater will not come fan starts normally, is this a fuse/breaker or failed electric element problem, how can i tell
It is either the element, sequencer (or contactor/relay), or power to the switching element. 5KW Elements normally Ohm out @ around 10 Ohms when they are good. Everything you need to check requires a multimeter.
Jan 21, 2015 | Heating & Cooling
No heat air or fan
Should be in the indoor unit. Power supply cabinet.
Dec 15, 2013 | Ruud UBHC Air Conditioner
I have a Rudd Achiever 10 . The unit was working yesterday morning, it stopped in the afternoon , and is still not working. The fan in the unit in the basement is working fine. Do you think it could just...
you will need to check you condenser unit(the outside unit) here is a website that may help,Tim:
http://www.air-conditioning-and-refrigeration-guide.com/air-conditioning-troubleshooting.html
May 30, 2011 | Ruud UBHC Air Conditioner
I have a Ruud achiever series heat pump. the unit would not kick on. the LED's under the cover are flashing that there is a high pressure lockout. is there a way to reset this on my own? i had a...
If condenser area is squeaky clean see if there is a way to reset the uit electronics. Check with Rudd for reset and then try again. If that does not do it then there may be an obstruction in the cooling system causing the high pressures and making it turn off for self preservation. You can also carefully push down on the contactor relay to see if the compressor starts at all - maybe there is an issue with the compressor.
Sep 15, 2017 | Ruud UAMB Air Conditioner
Rudd Achiever series model RQNJ-AO42JK 000 mfg
Turn the thermostat as low as it will go and have someone stand out side, they should here the condensor fan and compressor come on at the same time. They are two distinctive sounds so you should
be able to tell if the compressor is running.
If nothing happens and you are skilled with electrical
you can turn power off and remove the electrical
cover to the outside unit. Restore power and carefully
push in the contactor, if the fan and compressor
starts you have a thermostat or low voltage problem.
If just the outdoor fan runs on any attempt, more than likely you need a new capacitor.
Jun 18, 2010 | Ruud Central System Air Conditioner
Jan 05, 2010 | Ruud Handler Air Conditioner
Replace Rudd Achiever 10 ???
if the fan motor outside let go it could overheat the compressor which he should have known before he replaced the motor. also there is no way of knowing if there is enough freon in the system if the compressor does not start,your best bet is to get another repairman as a second opinion
May 12, 2009 | Ruud UBHC Air Conditioner
May 11, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Trying to change out my thermostat to a programmable one but the wire colors don't match up, what color wire does what on the Rudd Achiever series?? green/brown/yellow/white/blue
You should check the terminals where the other end is connected, there is no guarantee that the installer followed a wire color code. There should be a diagram in the HVAC unit. Normally, you have the power wire from the XFMR, a wire for the heat, a wire for the AC, and a wire for the fan.
May 05, 2009 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
