Question about Sony PlayStation Video Game Consoles & Games
The device i'm asking about is the Sony Playstation 3D 24" Display, i noticed that the bottom corners do not look like they are back lit or are dimly back lit, it is an LED display, is it an easy fix?
  • 175 Answers
SOURCE: LED Display is very dim
Unfortunately this is a bad display, and the kit to fix it (comes with new display board and power/relay board) is about $270 for the parts, and if you cant put it in yourself expect to pay an additional $120-$220 depending on rates in your area. Wish I had better news, but I see these (and Dacors) do this frequently. Hope this helps.
Posted on Nov 11, 2006
  • 943 Answers
SOURCE: kenmore model c970-655632 LED Display is very dim
hi joe. thanks for the question . you replace the clock to repair your problem . i have seen this happen on a regular basis . thanks the appliance doc
Posted on Oct 05, 2008
  • 114 Answers
SOURCE: Oven digital lighted display is dim
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Posted on Mar 21, 2009
SOURCE: dim LED display on oven
You need to replace the capacitors on the control board
Posted on Apr 10, 2009
SOURCE: Display on my Jenn-Air electric wall oven is very dim
I had the same problem and found the solution on-line.
Replace the C3 capacitor on the dispaly module. (100 UF, 35 volt, high temperature)
The local Jenn Air dealer wanted $211 for a new display module.
I purchased a Cap from a local electronics supply store for 79cents.
The only problem is that you need to have a soldering pencil/iron, a solder ******/wick and a small amount of solder.
Steps I had to take on my oven:
- Flip the AC breaker supplying the oven to off to be save
- remove 3 screws on top and 4 on the bottom of the display panel
- gently pull out the display panel and unplug the 2 cables to the display
- unclip the ribbon cable to the display module
- unclip the module itself by pushing on the 2 black tabs
- locate C3
- unsolder C3 and replace with new Cap- keeping the polarity strip the same as theh old Cap
- reasemble in reverse order.
It took me all of 20 minutes. It may sound difficult but is very easy if you have the tools
Good Luck
Posted on Jun 15, 2009
3d turn off
Hello Abhilash Patil,
You can adjust your 3D settings by entering the NVidia control panel which you will find in the System Tray in the bottom right hand corner of the screen.
I hope this helps.
Kind regards,
Jan 02, 2014 | Dell Computers & Internet
Sond ok back lit ok but no display
can you connect to a tv or another monitor???try this see if works;if not the problem is with the graphics if you can get picture on a tv monitor check the device manager..(right clik start control panel-device manager)if any items have a yellow triangle there is a problem.
Dec 12, 2013 | Sony KLV32S400A 32 in. LCD TV
I have the sony playstation 3D display. I was wondering whats the best settings for the display. For movies
If it's a 3D DVD you can have it on the 3D setting, but if it isn't a 3D DVD put it on the regular setting.
Jan 26, 2013 | Televison & Video
Sony Bravia KDL-46NX810 shuts off with 3D input only
Well written question but I would first call Sony Customer service to see if known issue or if the data base shows any reports or recalls for this issue.......
Oct 29, 2012 | Sony KDL-46NX810 46 in. 3D LCD TV
Got a playstation display and it has a bluish purple vertical line down the tv but it disappears when any red shows up in thae area of the line any ideas what's wrong with it and if it can be fixe
The display unit is defective, some IC seems to be damaged, it can be repaired from any repair shop, but I don't think the cost will be low, as the display is manufactured by Sony and the spares are not available easily .
Aug 28, 2012 | Sony PlayStation 3D Display - 3D LED...
Does the Playstation 3 support 3D DVD"S. I just bought a Sony 3D capable tv and hooked everything up and the PS-3 says it doesn" support 3D format.
With the new 3.50 update that Sony released it unlocked the ability for the PS3 to play 3D blu rays. Are you sure you have updated to 3.50 as you will need to do this before playing any 3D blu rays. I am sure if you update to this version you will find everything will be fine.
Hope this helps
Dec 04, 2010 | Sony Playstation 3 (PS3) Console
The screen display has gone dim and unvisable
It could be that your phone settings are set to where your phone goes dim to save power. All you need to do is go to your phone settings. Usually under display settings and then look for anything that says backlight there will be a way to change the amount of time it stays lit up.
Jun 10, 2009 | Sony Ericsson W910i Cellular Phone
ICF-C253 Lights gone out
There is a loose connection for the display near where you pushed on it to get ti working again. It would either need to be replaced or opened up and fixed by someone with knowledge of electronics.
Dec 09, 2008 | Sony ICF-C253 Clock Radio
Video Game Consoles & Games Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
