Question about RCA Class 1080p 120Hz Smart Back Lit LED HDTV - SLD55A55RQ 55 in. Black 50 to 59 in
RCA SLD55A55RQ 55 INCH HDMI SMART TV CUTS OFF AFTER FIVE MINUTES
I HAVE DONE FACTORY RESET UNPLUGGED TV, CUT OFF AUTO OFF AND I CAN'T FIGURE WHY IT'S AUTO SHUTTING DOWN...AS IN REMOTE STOPS WORKING AT 449 AND IT SHUTS OFF 500 MINUTES...BLUE LIGHT GOES TO RED SO NO PROBLEM IN THAT NO CLICKING NOISES ITS SIMPLY TELLING ITSELF TO SHUTDOWN AFTER FIVE MINUTES
  • RCA Master
  • 6,694 Answers
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Dec 20, 2016
My RCA flat screen model SLD55A55RQ flipps colors when you turn it on the sound works just see the colors. None of the answers are for a Rca model flat screen
T'Con board fault. Check and replace it. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jan 24, 2017 | RCA Class 1080p 120Hz Smart Back Lit LED...
I have lost reception on channel 9 and pixels playing up on other channels how can I fix the problem Samsung smart tv
Do a reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 12, 2016 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
HOW CAN I RESET A RCA 55 SMART TV MODEL SLD55A55RQ, WITH A BLACK SCREEN
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 07, 2015 | RCA Class 1080p 120Hz Smart Back Lit LED...
1.5 yr old Samsung series 6 6030 will not turn on
Sounds like main board fault. But, before make it confirm, try a hard reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 08, 2015 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
I have a 55-inch Seiki TV purchased May 2012 For past 3 days stuck on dvd1 and no sound. How do I change to HDMI1?
Do a hard reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 08, 2015 | Seiki SE551GS 55 inch 120hz 1080p Slim LED...
55UES 7000 FACTORY HARD forgot code
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 02, 2014 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
RCA video works. HDMI 1-4 do not work. No video
first do the power reset procedure . unplug tv hold power button on TV down for a minute. then plug tv back in then turn on.. see if the HDMI works .. if not test the HDMI cables/devices on another tv.
Jun 14, 2014 | Vizio XVT553SV 55 in. LCD TV
No sound on tv
Unplug your tv for a few minutes might help if it doesn't, turn your tv on, go to menu, reset to factory settings.
Apr 12, 2014 | Samsung NEW 55 Class 54.6 Diag. LED 6000...
Hdmi ports not working
Disconnect EVERYTHING for a few minutes - reconnect and restore all factory settings.
Jan 26, 2014 | Samsung 55 inch UA55ES8000 Smart 3D LED...
RCA Class 1080p 120Hz Smart Back Lit LED HDTV - SLD55A55RQ 55 in. Black 50 to 59 in Logo
32 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
