Loud buzzing noise when machine is off. sounds like the finish buzzer only way louder. sometimes it happens during a cycle.
    Sergeant:
  • 199 Answers
It is the water inlet solinoid it need to be replaced get the model number to the unit and get one from any appliance store
Posted on Jul 21, 2009
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
Oct 22, 2014 | Washing Machines
Dishlex dx 203 buzzer
solenoids that control water flow (taps) buzz when failing Check out the water in solenoid.
May 26, 2013 | Dishwashers
We have a Maytag Performa PAV2200 Washing machine...lately, during the spin cycle it makes a loud whinning or scraping type of noise during the spin cycle and sometimes during the wash cycle.... we took...
Might be the tub bearing going out. Is she leaking any?
Here is a visual inspect and repair of the tub seal:themobilian_1841.jpgthemobilian_1842.jpgthemobilian_1843.jpgthemobilian_1844.jpg
I used a pipe wrench to unscrew this top portion of the seal (lefty loosey)themobilian_1845.jpgthemobilian_1846.jpgthemobilian_1847.jpgthemobilian_1848.jpgthemobilian_1849.jpgthemobilian_1850.jpgthemobilian_1851.jpgthemobilian_1852.jpg
Those 6 springs are pretty tough to get back on there without the special tool
other than that it all goes back pretty easy.
Service manual and more HERE
Mar 12, 2011 | Washing Machines
How can I disconnect the alarm when the drying is finished?
  • Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down.
  • 2
    Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device.
  • 3
    Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels.
  • 4
    Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz.
  • Feb 17, 2011 | Miele Novotronic T230C Electric Dryer
    Amana washing machine makes loud noice when trying to spin
    sounds like you are dealing with the same problem as me .
    take off the front panel (after unplugging power) take a flash lite and look at the large pulley at the back just below the pulley is the helix check to see if they are worn .
    http://fixitnow.com/wp/2008/10/21/amana-washer-makes-loud-ratcheting-noise-during-spin-but-doesnt-actually-spin/
    Feb 26, 2010 | Amana NAV3330AW Top Load Washer
    Loud buzzing noise throu8ghout cycle. Sometimes washer sticks in wash mode
    Hi!
    The noise is coming from the power board may be a loose connection or a cold solder joint
    Mar 14, 2009 | Kenmore 24 in. 16352 / 16354 / 16359...
    Washing machine makes buzzing noise
    Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
    Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
    first thing i would check is to make sure your copper water line is not touching the motor this will give you this noise. just take off lower kick plate and start d/w you will be able to tell where the noise is coming from.
    Nov 28, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
    Noise during spin cycles
    GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
    Oct 12, 2007 | Washing Machines
    Washing Machines Logo
    56 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
