Question about ViewSonic Pro8200 Projector
Images on our viewsonic projector pro8200 is upside down on screen please need some help to rotate or flip images thanks
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: Convergence error on viewsonic projector PJ820
your gonna need to get a service manual from the manufacturer and do a convergence alighnment with the on board generator. Unless some unknowing hands have been inside the unit.?? Contact them here at this link Good Luck service.us@viewsonic.com
Posted on May 10, 2006
pgh_pa_guy
  • 2992 Answers
SOURCE: Settings on ViewSonic PJ513D Ceiling Mounting
The user's guide says for ceiling mounting,
"Set Front Ceiling in the System Setup: Basic > Projector Position menu after you turn the projector on."
The user's guide is on the CD included with the projector as a pdf file. You can also download the user's guide here:
http://www.viewsonic.com/assets/006/5619.pdf
If you find this solution gives you what you needed, please take a moment to rate it. Thanks for asking here!
Posted on Feb 22, 2009
wellss123
  • 4 Answers
SOURCE: Viewsonic PJ513DB DLP Projector projects upside down
Double check which menu item you are expecting to find the orientation. It might even be under 'image', 'settings', or its own button not in the menu, Jon.
Posted on Feb 24, 2009
My projector screen is showing my computer screen upside down, how can I fix this?
I don't know your model but you just need to go into the menu and look for the section that explains how to reverse or rotate your image. Many people ceing mount them upside down and need to flip the picture which is what has happened to you.
Jan 09, 2013 | Office Equipment & Supplies
I have a Panasonic PT-LM2U; when it is turned on, everything powers up fine but the image projected is upside down. I've looked through the menu but didn't see an option for flipping or rotating...
Every modern projector that I have seen has a setting that will allow you to flip the image for this.If you purchased it used it was probably configured as a ceiling mount in an upside down orientation or rear projection onto a translucent screen. (The projection method can be set from the "OPTION2" menu. in a Model LM1 so it should be similar. http://service.us.panasonic.com/OPERMANPDF/PTLM1U.PDF
If yours doesn't have this option, then you'll have to use mounts that require the projector to be upside down.
Jul 18, 2011 | Panasonic PT-LM2U Multimedia Projector
My project image is flipped horizontally on the screen, but displays normally on my laptop. How do I fix my projector image?
The projector may have a menu function for flipping the image dependent on whether it is merely set on a desk, or mounted upside down on the ceiling. See the manual, printed or online.
Feb 02, 2011 | ViewSonic PJD6211 Projector
Upside down images
the projector will project 4 image configurations: front, rear, ceiling front, and ceiling rear. go into the menu, under settings, and change it from ceiling to front.
Jan 07, 2010 | InFocus In2102 Projector
Lcd projector projects images upside down???
if you go through the projectors setup menu you will find the option to invert / flip and rotate image adjust as required
REgards Al "alastech"
May 29, 2009 | Epson PowerLite 62c Multimedia Projector
Feb 22, 2009 | ViewSonic PJ513DB Projector
Projector displays reverse image also has grayish purple color
Use the remote to go into the menu and change the screen position. There are 4 to choose from, flip left, flip right, flip upside down left, flip upside down right. It may be tricky to navigae the menu backward though.
Dec 31, 2008 | BenQ PB6100 Multimedia Projector
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Rotating the image.
Hi, I am not familiar with that model, But usually if you go into the settings menu you will see settings for the display which may be under "Display" "Rotate" "Keystone" "Flip" That model is made to be mounted upside down so somewhere in the menu there will be a setting similar to those I mentioned that will flip the image.
Hope that helps, Sorry I couldn't be more specific.
Sep 20, 2007 | Hitachi PJTX100 Multimedia Projector
ViewSonic Pro8200 Projector Logo
82 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
