Question about Tablets & eReaders
My password for brighthouse tv doesn't work on my ipad
How to connect to internet doesnt recognize router password
Are you sure of Wifi password is correct?
if so, 1st; try restarting your ipad by holding down power/sleep button untill it show "Slide to shut down" leave it off for 10 seconds & then re-open it.enter the Wifi -password, sometimes this step works.
2nd solution ; try resetting your iPad network settings, it will not affect your ipad in any thing except it will forget all entered passwords for any wifi you have already connected before. go to General from Setting, choose resett, and inside only reset network setting, shut down ipad & try to connect to the wifi again. Hope this solution work for you. Also you may try shutting down & opening your router again after 10 seconds while off. Good Luck.
May 19, 2016 | Apple iPad Mini
I have two iPads & my Twitter account works on one but not the other. When I log it, I'm told Password is wrong. I've changed password twice but it is never accepted on the 2nd iPad. Can you help?
You can use forgot password option in the IPad where your twitter account is not working properly.
Then reset your password and login to twitter using the same IPad which was having problem.
Getting started with Twitter for iPad
The last section of this link provides you with information on resetting your password.
If in case the problem persists then it must be an Apple problem.
Aug 29, 2015 | Apple Tablets & eReaders
I have changed my password for apple on internet but its not working on my ipad
Make sure you delete the previous account and you are connected to wifi during that process.
Mar 06, 2015 | Apple iPad Air
Don't remember password for ipad
You don't need to know your password for the iPad. As long as you know the password for your iTunes account, you used to setup the account on the iPad for. Connect the iPad with the computer and open iTunes and give in the password for the iTunes account. Apple will unlock the iPad and you can setup a new pass code for the iPad.
When you forgot your iTunes password, you have to contact Apple and prove you are the legal owner of the account.
Use this link to find more support for that:
Apple ID Support
Feb 16, 2015 | Tablets & eReaders
Why is my email not working
This is a very hard question to answer without me actually being there to see how it is configured at the moment. If you go into settings, email, calendars, etc, look to see if your password is configured correctly. iOS email is not hard to troubleshoot, but one must be there to see how it is configured now. Tell me this, is this a password issue? Do you need to change your email password? If you have an external email account that is added to the iPad, the password that you configured on your external account is the password you have to use on your iPad. This would be where you would have to go and change the password and then put the password into the iPad. I hope I helped some. Check this link for answers.
iPad Mail Contacts Calendars Apple Support
Oct 04, 2014 | Apple iPad 32 GB 3G Tablet PC
Ipad recovery
When you've forgot the lock screen password of your iPad tablet, you get 6 tries of the password entering. After that, the only way you could do is restore you iPad to Factory Settings, which would then no doubt delete your data and files on iPad. The lost data and files would not be backed up on iTunes then. In such case, the only way you could recover data and files from locked iPad is to use 3rd-party data recovery software app. Forgot iPad Screen Lock Password How to Recover Data from Locked iPad
Jul 31, 2014 | Apple Ipad2 32GB Wifi
I updated my exchange password on my laptop today at work, now when i go on my ipad it is asking for a password but when i enter my new exchange password it does not accept it
I've seen this happen with mobile devices sometimes, do you have any special characters? Make sure you're putting each character of your password in correctly. If you're certain that you are, log back in to your laptop and change your Exchange password to something simple like Password123. Wait about 20 minutes (it can take time for the password change to take effect across the domain) and try logging in with this new password. If it works, it was the password. If not, the issue may be on the iPad.
If that's the case, try removing the account from your iPad and re-adding your Exchange account. Hope this helps.
Nov 01, 2011 | Apple iPad 32 GB 3G Tablet PC
Tablets & eReaders Logo
12 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
