Honeywell ct3500a4453 My display isn't working and the batteries are new. Heat still kicks in.
3 Suggested Answers
  • 1015 Answers
SOURCE: Trying to replace honeywell T8001C thermostat with
Red is usually hot side of transformer,yellow is for the a/c compressor,white is for heater,green is for the blower fan,now the blue could be energize for heat or the common side for the transformer,brown can also be the common side of the transformer. It sounds like you need the blue wire connected to the common side for the thermostat....but be careful. Some units use this as a energize wire and are not a common. I would find out what furnace model you have then look online and double check what this wire is or you could damage the new thermostat and/or the 24 volt system on your fau. And also always have the power to the unit disconnected so you do not ground a circuit.
Posted on Oct 03, 2009
  • 80 Answers
SOURCE: My honeywell theromstat keeps displaying repl bat
Have you checked to make sure the batteries are, in fact, good and that they are facing the right way? If so, it's time for a new thermostat.
Posted on Oct 04, 2009
My Honeywell programmable thermostat's display is blank and I do not have any heat?
The thermostat, depending on the model, normally does not get powered by batteries, they are for backup power. You might be losing 24 volt from the furnace, causing the thermostat to run on batteries.
Apr 09, 2014 | Honeywell Programmable Thermostat Heater
Honeywell Thermostat RTH6350 makes heat run in AC mode after AC runs
Well, if it wasn't doing that before then you more than likely know its in your wiring. Cools down then heats back up sounds like the auto change over is on, and the heat setting is higher than the cool setting?
Mar 02, 2017 | Heating & Cooling
The thermostat is set on heat (70 degrees). My inside temperature on the display keeps saying 70 degrees yet the heater continues to kick in. The thermostat was just recently replaced and it has new...
Most thermostat have a dead band setting that you can set yourself.
Maybe your dead band is set 1 or 2 degrees above setpoint so unit would run to satisfy deado band
Jan 07, 2018 | Honeywell CT87B ROUND HEATING&COOLING...
I have a Honeywell CT3200A1001 in my home, I need help! It kicks on but won't heat the house passed 71 degrees. The furnace seems fine but the thermostat just keeps turning it on and off with no results...
try replacing the battery in the thermostat i am not familiar with this particular model but had a similar problem in my home replaced battery and now works good
Oct 10, 2009 | Honeywell Electronic Programmable...
EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
Oct 01, 2009 | Honeywell Electronic Programmable...
My thermostat quit working
Does it have batteries that need replacig. I think so. good luck.
May 31, 2009 | Honeywell Programmable Thermostat Heater
Honeywell Programmable Thermostat Display issues
there are currently 60 honeywell thermostats made i have no idea witch one you have , but a lot of the new ones run on batterys you might be seeing a low battery signal . look for a door where batterys might be and replace them
Jan 14, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
