Machine just stopped, tub is full, could smell a burning smell
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Could be wrong, but it might be possible that the motor blew or something. Probably should get that checked out
Posted on Dec 21, 2016
Maytag Neptune MAH5500 smelled like burning plastic at the end of the cycle. (The whole basement smelled bad.) The smell seemed to be coming from the plastic part at the top where it latches.
Tub bearings get worse, if they faulty, the machine would be noisy and getting louder. Sudden burning smells usually mean an electrical failure of a component but if this has stopped and the machine is working properly, its possible that something has got caught up in the rim of the tub or gasket area and during spin it has got "burnt" by being dragged around the edge. Have a close look at your clothes that were washed on that day for signs of burning or damage and around the top at leading edges of the tub for signs of melting or damage.
Mar 21, 2017 | Maytag Washing Machines
Maytag hav2558aww, made loud squealing noise upon the start of an agitation
Possible item caught between basket and outer tub. Remove the front panel and tub top ring. Shine a bright light around the semi-transparent tub and look for item. Check the pump pulley - ride the belt off and spin it by hand. If you feel any resistance or grinding replace the pump.
Mar 10, 2014 | GE Profile WPRE6150KWT Colossal Capacity...
Sewing machine slows to a stop.
When was the last time you oiled it?
Sewing machines need regular oiling as you use them - it sounds like you have or are close to seizing the bearings.
In future, when you smell burning and a machine that should operate at full speed slows down - stop, don't persist in using it.
It clearly has something wrong with it.
Your users manual should cover oiling the machine - there are predetermined points at which you drop the sewing machine or 3-in-1 oil into. Only a few drops are necessary, but you should oil it every few hours of use.
Jan 11, 2014 | Omega 6147 Sewing Machine
Washing machine has smell (burning) and doesnt spin or drain tub.
Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
Nov 27, 2013 | Washing Machines
Washing Machine won't do anything and is full of water
Check to see if the tub is free to move in at least one direction or the drain pump for blockage from a small item of clothing. It's best to wash small items in a laundry net bag when mixing with large items to prevent one from getting pushed over the top of the inner tub and either blocking the pump or jamming the tub. Hope this helps you.
Nov 22, 2017 | GE WBSR3140DW Top Load Washer
Machine stopped abruptly full of water. smelled like burning.
That could be a Locked Up Clutch Pulley One-Way Roller Clutch bearing my 1st choice Or a tranny lock up if this happened during wash/agitate part of the cycle.
If this happened in Spin Cycle it could be seized Outer Tub bearings.
If you want to DIY see this post
I have a neptune that continues to beep and do its own thing. do you thinks it's the computer board?
Feb 22, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Dryer smells like something is burning and making a slight humming sound
check tub bearings and/or rollers or for anything that could impede the turning of the tub. Sounds like something is stopping the tub enough
to make the drive motor turn on the belt causing it to burn and smell.
If you fix the problem with the tub be sure and change the belt
Leo Ponder
Jul 28, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
if it smells like rubber burning then i would suspect a belt is worn or slipping or somthing has jambed the basket from turning .. the belt is not expensive ..labor of course would be extra .. if the burning smells like insulation or a strong electrical burning smell then you may have a bad motor .. those used to be about $70 + labor .. no telling what they get for them now ...
you mention that the smell came from inside ... do you mean inside where the cloths are (the tub) or inside the cabinet (outside of where the cloths are) ...if the smell was coming from inside the washing tub .. then i would suspect something cought between the inner and outer tubs .. if the smell is not from there then the first suggestions above are good ... bras and slippers and such are good for getting cought .. check where the movable tub (with holes) meets the outer tube (no holes) .thats at the very top of the tub .. ..make sure nothing it cought there ...
Aug 05, 2009 | Washing Machines
Admiral lnc6760b71 Problems - Strong smell of burning plastic or rubber last week. Now the machine will stop when full of water and not respond. Later it will continue by itself. I took of a small panel...
Same problem, same model admiral. The smell is motor overheating. Once cool enough, it will continue with it's cycle. I took the top off and watched it run. The motor stopped and smoke rose from the motor located at the front right corner. I am scrapping mine and buying another washing machine. This admiral has been trouble since we bought it 5 years ago.
Jul 11, 2009 | Washing Machines
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
