Question about Bernina Sewing Machines
Bernina 630e motor reboots itself when I press on the pedal. It was working perfectly until it wasn't -- in the middle of a project.
I am able to get stitches by turning the hand wheel, but the motor reboots every time I depress the foot pedal. I've looked for lint and threads in the bobbin housing and under the stitch plate but didn't see any. There is no longer a Bernina Dealer in my area... Any suggestions??
SOURCE: Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching mode and in that give the straight mode the problem will be solved
Posted on Jun 05, 2008
SOURCE: Bernina Aurora 440 knotting below my fabric and into bobbin area.
Are you sure you have the bobbin the right way round in the holder....when you look at the bobbin and tug the thread, the bobbin should move clockwise.
Pull out the foot pedal and use bsr2 with the start/stop button.
Bring bobbin thread to top of work before starting to sew. This may help knotting problem
Posted on Jun 17, 2009
  • 208 Answers
SOURCE: The bobbin thread is bunching on the under side of
Make sure that you use the F foot when using decorative stitches.
The stitch balance my be off. Remove the accessory bin and you will see a large plastic screw with a + and a - and an arrow. Using a coin, turn the arrow to the center and test. Turn the arrow towards the + to stretch the pattern out.
If this doesn't work, it must me calibrated internally and requires an experience hand.
Posted on Jul 11, 2009
  • 980 Answers
SOURCE: Sewing machine not stitching
Sounds like you need to retime the machine, if you email me I can attach instructions
Posted on Jun 26, 2010
SOURCE: Remove thread message in husqvarna viking sapphire 870 quilt
I had this same problem, on my Designer Diamond. I blew it out with an air can and that didn't work, but then I decided to turn it off, then back on and start sewing a line in reverse. That seemed to fix it. My machine is working fine now.
Posted on May 27, 2011
Cant get benina 830 to turn on
take it in for a service
could be foot pedal problem or motor problem
Dec 16, 2016 | Bernina Sewing Machines
Concerning 1970s 830 Bernina. There is no motor sound..nothing. Is the carbon brush in the pedal?
could be
more likely a problem in the speed control of the motor or the motor itself ( they have brushes )
take it in for a service and proper diagnosis.
Oct 22, 2016 | Sewing Machines
Bernina 1030 starts by itself and runs very slowly some time after parking the needle at the top
This is most likely a fault in the foot control. Normally supplied with this machine is a Type 10 and this can be fixed quite easily but probably not by the machine's owner unless you have some electrical and mechanical experience.
If you have knowledge of and access to a multimeter, you can test it. What working properly, you will find the following:
Pedal released: resistance is infinite (anything around 4k Ohms or less and the machine will run).
Heel pressed: resistance is about 10k Ohms.
Toe steadily pressed from nothing to all the way down: resistance is infinite then after a small depression, jumps to about 4k Ohms steadily decreasing to zero as the pedal reaches all the way down.
Your problem, being at the point where the pedal isn't pressed suggests that there's some contamination in the pedal. It's also possible that you have a type 365 pedal (as used on the 930) and this is more likely to give this kind of trouble due to the use of carbon brushes in this foot pedal.
Feb 07, 2014 | Bernina Sewing Machines
Bernina 801
the motor will have to be replaced, here are 2 links for parts or you can contact a bernina dealer and order one or have them put a new motor on the machine.
Jul 27, 2013 | Sewing Machines
Are Bernina Nova 900 foot pedals still available?
My "new" Bernina 900 (I just bought it) has another foot pedal than Bernina that is perfect : a YDK !
Mar 12, 2010 | Sewing Machines
I hate this model. No matter how many times I have it serviuced, I keep having problems with the top thread breaking - at the start of the st8itching or in the middle. No discedrnible reason is present....
Possible reasons:
Hook timing is incorrect
Gap between hook and needle incorrect
Needle bar is not at correct height
Feed timing is incorrect
Needs a new hook
Lint or thread hiding between upper tension discs
Lint hiding under bobbin case tension spring
If you feel that your Bernina dealer has not solved the problem, contact Bernina a arrange to send it to the factory and they will solve it once and for all.
Jul 11, 2009 | Bernina Activa 130
Bernina 200 e freezing
Ask them to replace the I/O print and make sure its upgraded to the latest firmware, also have them check or replace the motor depending on when you bought your machine these could be under warranty.
Jun 18, 2009 | Bernina Artista 180
Bernina Activa 135 foot pedal problem
If you can get acess to or borrow another foot pedal to try I would do this first any of the Activa, Artista range fit to try. The fault may not be in the foot pedal but in the main CB of the machine. This can give a fualt of lights on but no motor drive. In this case the board would need replacing by a technician. Hope this may help.
Jun 11, 2008 | Bernina 1008
Sewing Machines Logo
26 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
