Question about Samsung Televison & Video
Samsung HLS-6167W shuts off every few minutes. I replaced the lamp 3x and recently the lamp ballast and #2 fan. Problem continues, so should I look at the power supply board or the color wheel?
Sometimes the TV stays on for hours, but more frequently it shuts off after few minutes. It also makes a humming noise ...
  • Mircea Ghita
    Mircea Ghita Dec 20, 2016
    Thank you... at this point will try anything. Could you confirm where the Temp Sensor I located? I tried all options online but was not able to locate a picture or schematic
  • deton8 von Splosion Dec 21, 2016
    Typically... (AA41-00801D):
    I can only say what they look like...
    from eBay (in the immediate are of the "LAMP" source...
    http://www.ebay.com/itm/Samsung-HLP5063W...
    http://www.ebay.com/itm/SAMSUNG-HL-S5687...
  • Samsung Master
  • 3,092 Answers
Hello Mircea Ghita,
I'd be more inclined to make sure the high temperature sensor was I good shape...
Go to "shopjimmy" ...(below)
They offer a ecent selection of parts at excellent prices
AND give advice...
It's been a while but I love our old DLP...
It has always made fan noises...
(but if you PUT EVERY WIRE EXACTLY BACK... serious
humming will only be a transformer getting ready to fail).
TV Parts Universal TV Stands DLP Chips ShopJimmy
Posted on Dec 20, 2016
  • Samsung Master
  • 2,760 Answers
If the sounds a high pitch squeal !! I had an ole tv that did that when u watched it , finally one day the dang power supply up and gave out !! so that must be what the noise was coming from all that time !!!
Testimonial: "it s more lie a humming sound and no a high pitch. Does that make a difference?"
I have a Samsung hlr5667w when I turn it on the lamp lights but the screen is black with a dim flickering light behind it, there is no audio. The lamp will stay on for a couple of minutes then the set...
If you heard recently a high pitched sound or fan like sound it may be the color wheel--if it fails the set will detect that and shut set off.
If lamp comes on even for a few seconds it likely is good--ballast which drives lamp is possible but rare.
Apr 05, 2012 | Samsung Televison & Video
I have a Samsung HLM617WX XAA DLP TV purchase in 2004. I replaced the lamp (BP96-00224J) in 8/09. Other than this the TV has operated perfectly. This week the screen went blank and the three LEDs flashed...
If the lamp is failing, the sensor on the ballast unit will shut it down. Check with a new lamp and ensure the cooling fans are clear and filters are clean.
Mar 31, 2017 | Samsung HLN617W 61" Rear Projection HDTV
Just pick up the 6167w it turns on fans are workin light comes on and in 3 seconds light gets brighter and the tv then cuts off please help
Try the ballast - mine was doing the same thing, I replaced the lamp - which was only 2 months old - same thing, replaced the cooling fan - same thing - Bought a new ballast for $62.00....Yeah problem solved!
Feb 18, 2011 | Samsung HL-R6167W 61" HDTV
Replaced lamp, but TV continues to shuts down a few minutes after starting. I replaced the lamp and it still has the same problem. What else can it be? After about 4 or 5 trys, the TV seems to work okay.
Tv have alots of clicking noises too to get tv turn on?The Ballast board is having problems.The Ballast board job it to ignite the projection lamp.
Feb 18, 2011 | Samsung HL-S5687W 56" HDTV
Just replaced lamp a week ago and tv worked fine
2 things will cause this Lamp is defective, or Fan to lamp quits running this will shut TV OFF, if the fan quits running while Lamp is on it is design to shut Lamp Off to prevent Damage to Lamp IF Fans are ok It will be the Ballast board It is what turns Lamp on.Look on E-Bay for Ballast board if it turns out thats what you need or call Encompasss Electronics 1-800-638-3328
Sep 19, 2009 | Toshiba 62HM95 62" DLP HDTV
My Samsung HLN5065W turns itself off after about 15 minutes, and all three lights on the front panel flash. The first couple of times this happened, there was a loud muffled sound before it shut itself...
This is a DLP projection that has a ballast and color wheel along with a lamp. The three flashing lights on the front are a diagnostic code. The exact meaning is listed in the owner's manual under troubleshooting. I don't have the manual for your model with me at the moment, so I can't look it up. Since the unit works OK for a while, it suggests that a component is failing under heat stress. This is often the ballast. The ballast is the part that provides the power for the lamp similar to the ballast in a flourescent light. Check the manual for the code and post it here. Also, because your model uses 2 different ballast/lamp combinations, you will need to get the lamp number off of the lamp. Please post that here too.
In the meantime, check the rear area for any obstruction in the air flow. There should be a fan in the rear that needs to be clear of debris and can turn freely. With the set unplugged, try turning hte fan by hand. It should turn easily and continue on its own slowing down to a stop. If it stops suddenly, the fan may be defective and not moving enough air to keep the lamp cool.
Keep us posted.
Dan
Apr 25, 2009 | Samsung HLN5065W 50" Rear Projection...
Projector
Check that you replaced the lamp in the right way, and also that the unit is well reassembled, you may also need to reset lamp counter from menu on some model.
Mar 07, 2009 | Dell 2300MP Multimedia Projector
Compaq MP2800 Lamp powers down after a few seconds
Hi Wayne
It is normal for the lamp's fan to start running , but should actually happen within 15 seconds of starting up. Try changing the lamp's fan and if the problem still persists then you will have to replace the Ballast ( lamp's powersupply )
Mar 22, 2008 | Compaq MP2800 Multimedia Projector
Samsung dlp tv hls 5688w problem
Possibly a bad fan. operate the set for at least an hour to warm it up then shut it off does the noise continue for a moment? If so its probaly the fan for the lamp that is making the noise.
Mar 20, 2008 | Televison & Video
Televison & Video Logo
55 people viewed this question
Jerry Greenberg
Jerry Greenberg
