Question about Camping, Backpacking & Hiking
Have a utility here 1000 lms flashlight that stopped working. Replace nine aa batteries and still not working what should I try next
  • Camping, Bac... Master
  • 17,267 Answers
First make sure all the batteries are in the right way. If that doesn't fix it, you will need to return it under warranty. There are no other replaceable parts with the exception of tailcap switches.
Posted on Dec 20, 2016
  • 2,760 Answers
1st go back and verify that u installed them correctly , lights nowdays have a specific way the cells go in them or they don't work
2nd try a new light bulb (if it has one) bulbs do go from time to time u know
and last try fiddling with the battery cover , some lights have a tricky way the covers go on !!
How do I replace the 2 AA batteries on the ML1W2AAE flashlight?
Unscrew the base counterclock wise until it comes off. Remove the old batteries, and insert the new batteries making sure that you insert both batteries positive (+) end in first. Replace base cap.
Aug 12, 2014 | Energizer ML1W2AAE 1 Watt Led Metal...
Tip
How to replace the lamp in a Mini Maglite
The Mini Maglite is a durable, compact flashlight. If your Mini Maglite stopped working, check or replace its two AA batteries first, and if that doesn't fix it, you'll probably need to replace the lamp. You can order replacement lamps in packs of two online, or you may be able to find them locally in a hardware store.
To replace the lamp in a Mini Maglite:
1. Unscrew the bottom of the flashlight. (Hold the flashlight with the head facing down so that the batteries don't fall out.)
2. Remove the batteries.
3. Unscrew the flashlight head from the barrel.
4. The lamp is mounted into the flashlight on two prongs; gently pull up on the lamp to remove it.
5. Install the new lamp by lining the prongs up with the two holes and slowly inserting it fully.
6. Screw the flashlight head back on.
7. Reinsert the batteries.
8. Screw the base back on.
When you've finished, turn the flashlight on (by turning the lens cover or the head counter-clockwise) to verify that the new lamp works. If the light doesn't come on, take the flashlight apart again and check to make sure the lamp is installed correctly and fully. Since the lamps come in packs of two, if you can't get the first lamp to work, try the second lamp in the pack. If that lamp doesn't work either, check your batteries and make sure the lens cover and head are both screwed on all the way.
on Jan 12, 2011 | Kitchen Appliances - Others
Replace batteries for stanley 95-112 flashlight
95-112B - Stanley Tripod Flashlight battery replacement is in the center chamber. Open the three legs, then put your fingers around the bottom part of the center chamber and turn counter-clock wise. Wella put in 3 new AA Batteries.
Apr 14, 2014 | Stanley 3in1 Tripod LED Flashlight 95155
How do you change batteries stanley 3 in 1 tripod led flashlight
The unit is 3 individual flash lights. Pull one of the flashlights by the head (the light part) it will come out easily once you know what you are doing. The other two may be pulled out in the same manner. The bottom will then unscrew where you will be able to replace the AA batteries. Each flashlight will then go back into place very easily. Hint...test each individual flashlight before putting back together to make sure you have your batteries in the proper place and that they are useable batteries.
Dec 08, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
I have a 3AA LED mini maglite with stuck batteries. The best I can tell they have not leaked. I tried freezing the unit as well as heating the barrel to no avail. Is there a way of removing the bulb...
well, I have a 3 cell mini maglite AA with a corroded battery stuck up next to the LED. I have searched but not found a way to remove the LED to push out the battery with a dowel. The best solution I read about was to drill a hole in the battery and insert a large screw and pull it all out.
(My Maglite is from 2009 or 2010, but I think they made this model in 2011, 2012 and 2013- this is for SEO!)
Sep 13, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
Won't power up even with new batteries
The same thing happened to mine- over Thanksgiving! I did 2 things and one of the fixed it, but I don't know which one. The first thing I did was to take out the little cr1220 battery (I did this just to look at it). The next thing I did was to wipe the AA battery contacts (top and bottom) with a Qtip dipped in rubbing alcohol. I out in new AA batteries, and now my camera works!
Dec 02, 2009 | Canon PowerShot A470 Digital Camera
Don't know how to replace AA batteries in Maglite AA.
they either unscrew from the back end or they unscrew from around the thick light end , then just pop in some new batteries making sure that they are pointed in the same direction
Jun 02, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
LED Flashlight Battery Drain Problem
This particular flashlight uses a microchip that consumes the power of the batteries, whether in use or not. Loosen the case to where the batteries go in, so there is no contact with polarity. Or just take the batteries out completely and replace them for actual use.
GGBMDB
Apr 05, 2009 | Stinger Streamlight 75000
Low Batterie Sign
I had the same prolem. OK, try this. Try to discharge the AA batteries in some use, flashlight or else,,,,then recharge them, full charge, install the batteriers ...they should work fine....
I read somewhere that canon is able free of charge to correct a shortcircuit that the camera is susceptible to develop in the installation of batteries......But I hope the advise will work...
Remove batteries when not in use.
Oct 03, 2008 | Canon PowerShot A540 Digital Camera
Camping, Backpacking & Hiking Logo
836 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
