Question about Haier Televison & Video
My Haier portable tv says no database. We are using antenna not cable
MNfisherman
  • 11896 Answers
SOURCE: replacement battery
2.5 hr rechargeable Li-polymer battery
Posted on Feb 01, 2009
  • 905 Answers
SOURCE: Poor reception on atsc portable tv
an external or outside antenna will improve the amount of stations picked up and maybe a amplified antenna will help
but the boxes they sell seem to do better in reception even with only a rabbit ear antenna.
I use a box on my 32in LCD because the internal tuner just does not get all the channels without having to get up and move the antenna and the outside antenna , well I'm not going to go out there to move it all the time , and the amplified antenna I still have to keep getting up to move the antenna
so in all the box( "zenith","digital stream"are good , have yet to test others) works the best in recieving the digital channels without much worry of the antenna
Posted on Mar 13, 2009
budmrtn
  • 11361 Answers
SOURCE: trying to hook up laptop with haier tv using vga
Dod you use HOTKEYS on the laptop to tell it to send the signal the VGA outlet of the laptop? The hotkeys function can be set to turn off the laptop screen and only have external monitor to be the only display or it can be set to have both of them on.
Posted on Nov 03, 2009
  • 3 Answers
SOURCE: Haier HLT71-7'' LCD TV
ITS BROKEN
Posted on Mar 06, 2010
martyr366
  • 11 Answers
SOURCE: need code to turn tv on for haier model HTF20R21 tv?
Is it a Haier remote? Haier customer service person says that no Haier flat screen TVs or, for that matter, DVD players, are set up to be able to work with a universal remote; only their older tube TVs do. The Haier remote must be used. So we all can stop trying to find the codes. It wold have been nice is the user guides had revealed this unfortunate absence of functionality
Replacement on the Haier website is $19.99 plus a load in shipping.
I am not sure if your remote has a search code function, Most do. Check your instructions. I proceeded to go one by one through our remote's TV codes with the search code function, pushing the power switch after each code, until the set turned on.
Hope some of this helps
Read more: http://wiki.answers.com/Q/What_is_the_universal_remote_code_for_a_haier_tv#ixzz1kUnuLc2r
Read more: http://wiki.answers.com/Q/What_is_the_universal_remote_code_for_a_haier_tv#ixzz1kUnRB5An
Posted on Jan 25, 2012
I need a antenna that have a good strength to get more channels, right now i can only get a few channels
Tries websites like Amazon.com,Ebay.com to buy a Digital design antenna for a better strength longer ranges.But many of these antennas are design for mostly big tvs sit on a table tops.Just look for many of those digital design antenna choices,one of them will be snall enough and portable enough to carry with ur portable tv.
Jun 04, 2011 | Haier HLT71 7 in. Portable TV
Mini flatscreen hAS POWER BUT SAYS NO DATABASE..NEVER GETS A PICTURE///?
HI:
You must to setup and change the signal input to cable if you are using cable to connect the TV. IF you are using the antenna that came with the unit, you must select AIR mode. Then do a channel search to find and program in the channels.
Apr 20, 2011 | Haier HTN20R15 TV
MY NEW HAIER 7" TV SAYS "NO DATABASE"! AND WHEN
Don't throw it away just yet. It's still under warranty so returning it would be far better than throwing it away ;)
As you can tune the cable channels OK, I suspect there is a problem with the reception from the antenna and the signal strength is too low. Please can you answer the following simple questions so that I can help you to solve this problem
1. What antenna are you using - indoor/rabbit ears or outdoor/roof antenna?
2. Do you have a good reception on another TV connected to the same antenna ?
If you are using an indoor antenna, try moving the TV to another location to see if you can get a better reception.
Please let me know the answers to the above questions. I will then be able to assist you further.
Regards,
BElectric
Jan 22, 2011 | Haier HLT71 7 in. Portable TV
Sound is operating correctly ..However, there isn't any video , screen has an extremely faint picture
Sounds like a broken backlight. That's a write-off for an old set, or a factory warranty repair (90 days labor, 1 year parts). First make sure the TV is in TV mode (press mode on the set, or TV/AV on the remote).
Once in TV mode, press MENU and use the navigation buttons (arrows and ENTER) to choose the set to factory default mode.
Also make sure you have a working signal by trying another TV on the antenna or cable coaxial wire.
You can also try adjusting the brightness from the MENU.
If these steps do not work, call the Haier hotline listed in the manual: 1-877-337-3639
Oct 14, 2010 | Haier HLT71 7 in. Portable TV
How do i improv my signal strength? it has always been very poor no matter where i go.
Best solution to improve signal strength is with an antenna other than the simple rod antenna.
The rod antenna is really only useful for very close stations and does not work well under most conditions, especially if you are on the move while using it.
Even a simple portable rabbit ears antenna can make a big difference.
Believe it or not, I have used a rabbit ear from the local dollar store to receive much better signals than with the rod antenna.
If you are using the Haier in a home, you might try purchasing an inexpensive old-school antenna from solid signal or radio shack. I set mine on a plastic garbage can in the attic and ran a 100 foot coax cable down to my old cable wire outlet.
You can also buy amplified antennas which look good and mount on the wall or near a window for apartment dwellers.
You might also try making your own HD antenna out of coat hangers and a piece of wood.
Oct 09, 2010 | Haier HLT71 7 in. Portable TV
CAN NOT RECIEVE ANY CHANNELS JUST KEEP RECIEVING \...
May 20, 2010 | Haier HLT71 7 in. Portable TV
What does it mean when it says no database?
It means there is no Database.
The data base is were all information is.
The database in this circumstance I would assume is the Memory card
Dec 07, 2009 | Haier HLT71 7 in. Portable TV
I have this same model TV and I use it with as
You probably need an RF (radio frquency) modulator to be connected between the cable and the TV. Connect the cable to the ANT IN on the RF modulator and then use the TO TV outlet OR the three RCA outlets (yellow video, red left audio channel, white right video channel) to connect to the Haier portable TV
I bought two such modulators made by TriQuest at a local surplus-type store (i.e. Big Lots) for about ten bucks each.
Incidentally the TriQuest unit also has an S-video output.
Nov 16, 2009 | Haier HLT71 7 in. Portable TV
Televison & Video Logo
77 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
