Question about Water Water Heaters
How do I get water to go only into tank? - Water Water Heaters
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 10 Answers
Honestly I have knowing idea what you said but if you are talking about how to get a water and a tank I know how to do that you grab a cylinder tube and put like water in a small container and take it and like Omega's dog is outside go-getter so you would take the water and put it in there and that's how you do it
Posted on Dec 20, 2016
  • 2,760 Answers
Im not sure of your exact question here , im guessing here but are u saying the water wont fill the water heater when supply valve is on , if im right and this is ur question , then try opening a hot water tap somewhere else in house the air that is trapped should be expelled from open tap safely into sink there and heater should fill
be mindfull to not add power/gas till your sure the water heater has filled this would cause failure of your heat supply device
My water heater shuts down in cold weather. How do I fix this problem
Add tempering tank.
Tempering tank made from old tank-type water heater, or small tank heater will passively heat incoming water.
http://waterheatertimer.org/Tempering-tank.html
This works because tankless can only raise temperature so many degrees. If water is very cold, tankless cannot keep up, so the sensors shut down the unit.
Passively preheating water... or using a small tank connected to power can preheat water enough so tankless works.
Also delime tankless each year will help remove natural scale that builds up inside tankless heat exchanger.
http://waterheatertimer.org/How-to-delime-tankless-water-heater.html
Gene
Water Heater Timers Save Money
Feb 13, 2015 | Water Water Heaters
Low water pressure
Hi Bob,
You can determine if the tank is the problem by connecting a garden hose to the drain that is provided on most water heaters. Before doing this, be sure to shut of the electrical supply to the heater - otherwise you can damage heating elements if an electric type or waste fuel by heating an empty tank if a gas / propane fired type.
If you get a slow flow out of this drain, it means that somewhere in the cold water supply side to / in the tank - there is a problem. Inside the tank, the cold water is delivered by a "dip tube" that distributes the cold water to the bottom in the tank. Dip tubes are used in both electric and gas / propane fueled heaters. Here's a cut away view of a typical tank:
If the tube is clogged, or there is build up, scale or debris in the supply (cold water) side of the heater, flow rates will suffer. Likewise, if there is a problem with the output of the tank, it will directly affect flow as well.
If you get a good flow rate from the drain, then the issue is going to be on the hot water output side of the heater. Again, the same build up, scale, debris issues on the hot water out put pipe will cause problems with flow. Typcial tanks do not have dip tubes for the hot water side of the tank - as taking hot water from the top of the tank is most desireable and is furthest away from the cold water that rushes in to make up the hot hot water going out.
There's nothing really in the tank itself that can cause issues with flow outside of the dip tube, and piping to and from the tank.
Jun 29, 2012 | Water Heaters
How do i install a pressure tank to my water heater?
Do you mean expansion tank? To relieve pressure?
Expansion tank goes on cold water line before cold enters tank.
See image:
http://waterheatertimer.org/images/water-heater-expansion-tank.jpg
Expansion tanks are installed when TP valve is constantly drizzling hot water due to very hot temperature settings. Or when water pressure is high, etc
It's also smart to install expansion tank so plumbing lasts longer, and older tank is less likely to rupture and cause damage. Inspect tank for leaks each 6 months.
Some regions require expansion tank by local code.
Water heater can be damaged when pressure exceeds 80psi. : Test pressure using pressure gauge at water heater drain valve.
Other resources:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
http://waterheatertimer.org/images/BTG-100-Pressure-gauge.jpg
Sep 27, 2011 | General Electric Water Heaters
Is my water heater still under warranty leaking water on top of heater and out from bottom and from plate
1) If water heater is leaking, I suggest you protect yourself first.
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
2) You have to do some work to find out if tank is under warranty.
-Contact manufacturer: http://waterheatertimer.org/Water-heater-manufacturers.html
-Contact installer: If plumber installed heater, then installer backs warranty for some manufacturers. If you installed heater, then warranty is less or void
-Look at paperwork and manual that came with water heater and read about warranty coverage
-Look at markings on tank to see if tank is 6 year, 15 year etc
-Warranty is based on date of manufacture: To find date of water heater, look at serial number located on label on side of tank:
Open link below for serial number decoder by manufacturer.
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
3) If tank is older than 6 years, and tank label shows this is a 6-year tank, then tank is no longer under warranty.
If you have a lifetime tank, then warranty is in effect, so contact manufacturer.
Open following link to see troubleshoot checklist for leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
Other things to consider:
-If tank rusted out after a few years and installer did not install a jumper wire between hot and cold pipes, then tank warranty will probably not cover tank.
-If tank rusted out and you have water softener, and did not inspect anode rod or maintain water heater, then you did not read manual or maintain heater, and warranty might not cover problem.
-I suggest you read water heater manual cover to cover so water heater will not start leaking.
Other useful links:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
Feb 12, 2011 | Reliance Water Heaters
Water is found leaking at the bottom of the tank, near the plastic cap, at the centre of the tank. What actually happens and how to resolve. The heater has been installed more than 5 years ago. From the...
A) Calculate date of water heater manufacture from serial number located on side of tank:
Date of manufacture is not date of installation.
Warranty is usually from date of manufacture
Serial number also shows tank size in gallons, tank volts and watts, and whether tank has 1 or 2 elements.
B) Troubleshoot leaking water heater:
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Several things can be looked at to see where leak is coming from.
Carefully go over tank pipes and valves to eliminate every suspect.
Final suspect: tank is rusted out.
C) If tank is rusted out, then tank needs to be replaced before it ruptures.
Ruptured tank can cause major damage and water runs until shut off.
To prevent rupture, turn off power to heater, turn off valve located above tank, open tub faucet for a moment to relieve pressure on tank.
Turn on heater only when needed until new tank is installed.
4500 Watt water heater produces 21 gallons hot water per hour.
Shower uses 6-9 gallons hot water. Bath uses 12-14 gallons hot water.
"It is possible to limp along with a failed water heater if the leak is slow and if you turn off power and water when not using hot water. That trick could buy time, possibly up to 3 months. With time, you can consider how to make the system do more for less as well as comparison shop, get competitive bids, etc"
D) Now you're home is safe from damage.
If tank is only 5 years old, it rusted out pretty quick.
There are three things you can do so next heater lasts longer.
1) Learn about anode rods, and inspect anode rod every 1-3 years.
Loosen anode rod before installing new tank so replacement is easier.
2) Attach electrical ground wire between hot and cold pipes to prevent stray current from reducing life of water heater
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#straycurrent
3) Flush tank each 6 months to prevent sediment
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flushelectric
Dec 28, 2010 | Rheem 81VP6S/430126 Water Heater
We have a brand new rheem 40 gal elec water heater, after installation we have water leaking from the base of the relief valve, pooling up in the plastic fitting and making it way over the side all over...
Water heater should be set in a drip pan.
Otherwise, put 1 gallon bucket under TP release pipe to catch water.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#drip-pan
When you say relief valve, I assum you are talking about brass valve located on top of tank or near top of tank. This is TP valve and a pipe connects to this valve and runs down to within 6" of bottom of tank. TP valve has a small lever on it.
If you are talking about tank drain valve located at bottom of tank, then add a comment.
Following information is for TP valve.
Dripping TP valve can be caused by 3 different thing:
1) Obstruction inside TP valve. Open TP valve for a moment to flush away particles and slowly lower lever back down. See if water stops dripping, if not, then replace TP valve
2) Defective TP valve: replace TP valve. Turn off electricity to water heater. Let heater cool for several hours so you do not get scalded. Close shut off valve located above tank on cold side. Open tub spout to relieve pressure, open tank drain or open TP valve and empty water below TP valve level. If TP is located on top of tank, not much water has to be drained. Tank is under press when hot, so be careful. Put teflon tape on new valve and install with big pipe wrench by turning clockwise until TP valve is very tight.
3) Overheating tank. TP valve is temperature-pressure valve. If tank water is over 150 degrees, the TP valve starts drizzling hot water to relieve tank pressure.
Lower tank pressure two different ways:
a) turn down thermostat
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
b) install expansion tank on incoming cold water line
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#expansion-tank
Dec 19, 2010 | Rheem Water Heater Pressure Relief Valve
Low boy water heater leaks at point where cold water pipe enters caseing.The leak is below the threads.The caseing is rusted at the point where the pipe goes through.Can this rusted place be patched or...
1) Your water heater needs to be replaced.
It cannot be repaired.
Tanks rust out after anode rod is depleted unless anode is inspected and replaced 1-3 years.
Water softener causes anode to deplete quicker, so inspect every 2 years.
Also stray household current can cause tank to rust out. Put bare copper ground wire between hot and cold pipes on new heater.
2) First thing is protect yourself from tank rupture where water heater bursts open and water runs until it's shut off. Ruptured tanks are big topic in homeowner insurance industry today because they cause major damage inside house.
- Turn off heat source so tank is not under pressure:
Gas: Rotate dial to pilot so pilot light stays lit, but burner does not turn on
Electric: turn off circuit breaker
- Turn off water going into tank using shut off above tank.
- Open hot side to bathtub to relieve pressure from tank.
- Check label on side of tank to get tank specifications for replacement.
3) What to do until replacement.
You can get by for a while on leaking tank by turning it ON only when needed.
Make sure tank is full of water before turning heat source back on.
This will buy time until replacement.
Electric tank heats 21 gallons water per hour.
Gas water heater 41 gallons per hour
Shower uses 6-9 gallons hot water, bath uses 12-15 gallon hot water.
4) Additional reading so next tank lasts longer
Dec 05, 2010 | Water Heaters
How does rhe hot and cold water hook up on a 71-40d which is which top and bottom
Tanks are marked with Hot and Cold.
1) If water connections are on top of tank, look for red marking or word HOT that shows where hot water pipe connects. Look for blue marking or word COLD that shows cold water connection.
2) If water connections are on side of tank, cold water connects to bottom one, and hot connects to top.
3) If hot and cold are reversed, the tank will not work.
Pipes on top of tank: cold water enters tank and is sent to bottom of tank in a long tube called the dip tube. This means the cold is on the bottom since hot water rises to the top. The hot water exits top of tank.
Pipes on side of tank: You want cold water to enter bottom, so hot water naturally rises to the top outlet.
Nov 14, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Cold water ok, no water flow from hot water lines.
Bypass valve incorrectly set
obstruction or dirty tank
plugged line - lime or other! does cold flow into tank ok?
Tank is split water going somewhere you can't see - this should be obvious.
There is not really anything to obstruct the flow normally so there
would have to be an obstruction somewhere. Lime, junk, garbage etc build up .
On my coach I have lots of pressure on the cold side so hot would have to have the same unless there is an obstruction into or out of the tank. If in the bypass position you have sufficient flow than the lines are ok and the problem or obstruction is in the tank itself. Drain the tank, leave the bottom plug out, open up the pressure relief valve. Turn on the water and see if you get a lot of water draining from the drain hole on the tank. There should be a lot of water coming out of the drain hole. If so that tells you that your getting sufficient flow into the hot water tank. If so your problem is the water getting out of the tank. Like a clogged return line or an obstruction from the water tank to the faucet. A dirty scale lined tank can do a number on tank water flow. Also check to see if the water is going somewhere else, your tank could be split and you just can't see where the water is going!
Dec 17, 2009 | RTO Atwood Water Heater - 6 Gal LP
Water Heaters Logo
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
