Reversed polarity on amana heater furnace, how do I corrwct it?
  • 2,760 Answers
Depends on how you "reversed polarity " if you have just connected the hot and neutral backwards that's not bad just remove power and swap them , Now if you have somehow connected the incoming power to the low voltage control wires , then that's a problem ! im guesing that some parts got damaged then
Posted on Dec 20, 2016
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My 90% York furnace went
Improper grounding can also cause that fault to come up. Check everything you can to make sure that all ground wires are connected. Make sure especially that the power line in is grounded to the body of the furnace.
I have had to in an extreme case drive a separate ground rod outside and run a ground wire directly from the furnace to the ground rod.
Also If have had a power surge take out the inducer AND the circuit board at once...the circuit board problem does not show up unitl the inducer fault is gone...
These types of problems can many times be very difficult to find and fix. It may take a lot of time and experimentation to discover the cause.
Heatman101
Posted on Nov 03, 2010
  • 27 Answers
SOURCE: How do you reset the furnace when it indicates the
To reset any furnace just unplug and plug it back in. If the polarity has been reversed open up the small box the power cord goes to, you'll see white, black and green wires. find the ones that are attached directly to the power cord and switch the white with the black and vice versa.
Posted on Oct 19, 2011
  • 448 Answers
SOURCE: coleman furnace
Reverse polarity means the power wires coming to the furnace are connected backwards. The black wire should the hot ( 120 volt line) . The white wire should be the neutral. The green should be the ground. Check these connections and test them to make sure they are correct. You should get 120 volt reading between the black and white.120 volts between the black and green and 0 volts between the white and green. Hope this helps.
Posted on Jan 02, 2014
Testimonial: "the only thing I don't get is if I shut the power of to it and leave it for a while it will come on it ran all night lastnight and now I cant get it to work for anything what would cause this the motherboard or what ever you call it was just changed Tuesday morning and it was working fine now the reverse polarity code if flashing"
Coleman furnace
Jan 02, 2014 | Heating & Cooling
My gibson furnace geves the error L1 neutral polarity
This means the hot ( L1 ) and the neutral connections are reversed.check the 120 volt power to the furnace for the correct polarity also make sure there is a good ground connection. Hope this helps.
Dec 07, 2013 | Heating & Cooling
I keep getting a reversed polarity signal on furnace.
Either you have a bad board, or current leakage between ground and neutral on the ac line. I have reversed the polarity on the black and white wires before and fixed it, but it's been rare.
Nov 21, 2013 | Goodman Furnace Draft Inducer Blower ...
Changed to lux9100e thermostat and get reversed polarity message on bryant furnace
I think it means that you need to reverse the wires to their respective connections on the thermostat..
Sep 24, 2012 | Lux Tx9100e 7 Day Universal Programmable...
How do i fix reversed 115 polarity on a heat unit amana
Can you be more specific with your question? A 230V unit won't work with 115V power. Reversed polarity may just mean that the outlet is wired backwards and the wires need to be switched around.
Nov 01, 2011 | Amana PTH153B25AJ Heat Pump Air...
How do you reset the furnace when it indicates the polarity has been reversed
Oct 02, 2011 | Goodman GMS90703BXA Heater
I get trouble code 8 and the furnace shuts off
Trouble code 8 for GMS8 and GMS9 indicates a reversed polarity on the line voltage. Meaning that the wires are switched. Assuming it is 115v system the black and white wire are reversed. Also check all of your grounds and ensure they are strong.
Dec 03, 2010 | Goodman GMS90703BXA Heater
Led keep on flashing
What is the model #. Sounds like your polarity is reversed. Do you know how to check for this.
Nov 13, 2008 | Goodman GMS90703BXA Heater
6 blinks
sounds to me like i wish i could find out if this is new install or if the electric has been changed recently,,,sounds like reversed polarity on the plug,,,which means the white and black wires need to be swapped. If there has not been change recently than u need to see the other post i made on goodman about the combustion fan motors and there types and fixes. But almost certain that is reversed polarity. good luck
Oct 23, 2008 | Goodman GMS90703BXA Heater
No ignitor light
Found the problem. The polarity is reversed on the 115V plug. Remove the cover and sitch the black and white wires.
Nov 20, 2007 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
