Question about Plumbing
I bought a glacier bay faucet 12/02/2016 model 675360508d2 and it recently is making noise when the sensor is activated and the led light comes on intermittently.
  • 68 Answers
SOURCE: glacier bay kitchen faucets with 2 handles and a sprayer
to be honest with you if there is a problem the glacier bay brand is from home depot and they are usualy around 20 to 30 dollars the replacement stems are usualy 15 to 40 depending on the part plus the hours ur gonna spend fixing it your better off with a full replacement. if replaced keep in mind you might want to replace the supliy lines to the faucet with stainless steal suply lines to ensure no leaks and if your shut offs are old dont touch them shut off your water main and drain down your house by opening all the faucets and shower valvs in your house then drain at the lowest point in the house weather it be a sink in the basement or an out side faucet once the supliy lines and faucet is in place then close all the faucets you opened and slowly turn on the water to your house slowly and this will ensure you dont have any leeks from your shutoffs good luck  your friendly plumber
Posted on Apr 12, 2009
  • 10865 Answers
SOURCE: Single-handle Glacier Bay shower faucet, hot/cold reversed
Hello. It sounds like your plumbing was installed wrong, with the hot and the cold supply lines reversed. If that is the case, those supply lines will have to be replumbed to make your faucet work properly. Often, if those lines are accessable, it is only a 20 minute job. Joe
Posted on Mar 18, 2010
  • 102 Answers
SOURCE: I recently bought a Glacier Bay 303-635 All-in-One
Try adjusting the water level down about a half inch or so and see if that helps. It could just be siphoning. Otherwise the valve may be defective. Hope this helps.
Posted on May 11, 2010
  • 349 Answers
SOURCE: I have a Glacier Bay(Costco) kitchen faucet. The
Check the weight and see if it has screws in it to move in on the hose line the distance it lacks retracting.
Most of them can be adjusted to proper retracting mode. It may have a couple of screws in it.
Posted on May 15, 2010
  • 349 Answers
Behind the handle check to see if it has a dail to take out and replace at a different postion this will change the hot and cold. It a anti scald protection device. Don't remove cartridge just adjust dail.
Mark where you start and take out and move a 1/8-1/4 turn at a time and replace til temp desired. It has teeth like a gear you move to adjust temp.
Posted on May 16, 2010
How do I put seats and springs in a glacier bay Aragon three handle knobs
How to Repair a Glacier Bay 3 Handle Tub and Shower ... > Glacier Bay Faucet Instructions
My three Handle Glacier Bay Tub Shower Faucet Makes a High-Pitch Squealing ...The Glacier Bay tub faucet screw-cover buttons will not stay on the handles. ... Sealthe flanges to the shower wall with a high-grade anti-microbial kitchen and ...
Nov 07, 2015 | Plumbing
How to remove Glacier Bay Lever Kitchen Faucet Handles
To remove the lever handle from a Glacier Bay two-handle kitchen sink faucet: Insert a 2.5mm hex wrench into the small hole underneath the lever. Work the wrench into the small handle set screw.Turn the wrench and setscrew counterclockwise to loosen. Pull the Glacier Bay lever handle off the faucet stem. P.S. You do not need to remove the screw to take the handle off.
on Oct 07, 2010 | Globe Union Glacier Bay 8 In Double Handle...
Glacier bay led faucet will not light up
It has lost power. If AC, check the electrical breaker, if battery operated, replace the battery.
Aug 04, 2014 | Plumbing
I have a glaicer bay kitchen faucet and when the water is turned on there is thumping. When I take the sprayer off the thumping stops.... is therea probelm with the sprayer?
to reduce the 'thumping' noise, open the supply valves more. If they are already at maximum, you may have a restriction further up the supply lines. Thumping is typically caused by unbalanced flow around the seat and washer, usually caused by restrictions.
Mar 03, 2014 | Glacier Bay Kitchen Faucets. Lyndhurst...
Have just installed glacier bay faucet model #8181/ 785 564 single handle with pull-out sprayer. once pulled out the sprayer will not re-seat into the faucet but hangs out about an inch or two. have...
Take it back to HD or Lowes where you got it and trade it in for a will be glad you did... this is only the beginning of your get what you pay for...
Apr 21, 2011 | Microwave Ovens
We just bought a house with a Glacier Bay single handle faucet in the shower. We only get scalding hot water from the faucet when we turn it on even if we move the faucet to cold. Pls help.
Hi and welcome to FixYa. I am Kelly
You need to most likely change the inner valve cartridge. These Glacier Bay valves are sold at Home Depot and finding the correct replacement part will not be easy. Personal experience is to remove the old valve cartridge and walk into the store with part in hand. These valves use a ceramic insert / disc that locks into a groove of the cartridge. If the ceramic piece has drifted out of place they usually break off the inner locking tabs.
Should the store you visit not have the part you need... read these links:
Also read the 23 March article on this link near the bottom of the page: Heading name is
Infromation Technology
Let me just add something........ check with your realtor about your HOME WARRANTY. This repair may very well be covered by the home warranty.
My honest opinion.... the sooner you get rid of the Glacier Bay Shower control the happier you will be. These controls were at one time Marketed under the in store name Pegasus.
I did not intend to ruin your day but... I do want anyone reading this to be advised of the consequences of buying inexpensive shore controls.
A word of advice when purchasing a new control valve. Pay for the good name ONCE and make sure the repair parts are in the same store where you make the purchase. It will cost you less in the long run. Have the sales person show you the repair parts for the MODEL that you are thinking of buying. Delta, Moen, Price Pfister are 3 names that have been around a long time and have repair parts readily available in the marketplace. (end rant)
Thanks for choosing FixYa,
Apr 02, 2011 | Home
How to repair facet stem for glacier bay products kitchen sink
Theres not much you can do to repair the stem except replacing the small O-ring up inside. You can call Glacier Bay and ask for a new stem ( the faucet has a limited lifetime warranty. You can also use Delta faucet repair parts in your Glacier Bay kitchen faucet; they come from the same mold. Heres a link to Glacier Bay 2 handle kitchen faucet repair. Heres one to the Glacier Bay faucet manual for your faucet.
Sep 16, 2010 | Globe Union Glacier Bay 8 In Double Handle...
Need a manual for glacier bay model 881-0002 faucet. Can you e-mail me a pdf?
<a href=",-173-418l(881-0001),-173-418l(881-0002),-173-418l(881-0005).html">,-173-418l(881-0001),-173-418l(881-0002),-173-418l(881-0005).html</a>
Aug 11, 2010 | Plumbing
We recently installed a new bathroom faucet and it
check the strainer where the water comes out of your faucet it may be clogged or if the faucet has a cartridge in it it may be clogged and you will have to dis assemble the faucet to clean it usually the strainer is the problem and it should unscrew by hand
Mar 11, 2010 | Plumbing
Plumbing Logo
199 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
