Question about GE Refrigerators
I have a GE model minisplit AE1C12DBH1 and the compresor does not running run.The capacitor part number is dificult to see.What are their specs.
Manuals found...760grs is the amount of refrigerant needed for each minisplit.
Posted on Mar 25, 2007
  • 388 Answers
SOURCE: I have a Sanborn Black Max 22 gal. compressor
Sanborn/Coleman was bought out by MAT Solutions. A website I found lists Sanborn/Coleman compressors and parts but it does not show your model number. It does say, however, to email them with your model number and they will be able to find your parts for you. I have included the link for you here:
Posted on Sep 11, 2009
  • 262 Answers
SOURCE: compresor is hot, have voltage, capacitor is ok
First unplug the machine. carfully remove the cover on the side of the compressor the get to the start device. Remove the start device. Once removed you will have 3 prongs from the compressor. Using a meter make sure you have continuity between each of the three prongs if you do not then the compressor is bad. If all check good then check each prog to the groud of the compressor or the case, if you have continuity then the compressor is bad. If you have passed both tests then you can try a new start device. after you replace the start device you will want to test the current draw from the compressor to make sure that it is not what is causing your start device to fail.
Note :The compressor is a sealed unit and its life can't be determined. puting a new start device on your compressor is a good idea and most of the time will solve your problem. But if your compressor is the cause of the problem it will only last about 30 days.
Posted on Jan 07, 2010
  • 266 Answers
SOURCE: need part number for run
You can get capacitors from any electric motor repair/rebuild shop if your capacitor is a 3 wire it will be a 5uf 30uf capacitor the fan motor runs off the 5uf the compressor runs off 30 or 35uf it will also have 440v 330v ect under the 5uf or 30uf this is the voltage as long as the replacement capacitor is within 5% it will not hurt anything. Capacitors usually run 5 to 15 dollars at a repair shop much more from duo them. good luck
Posted on Aug 08, 2010
  • 674 Answers
SOURCE: Run Capacitor is bad... what
Look at the old capacitor. The rating should be printed on it. You just need to get one with the same microfarad rating. If you can't read it take the model # with you to heating and air supply that sells Goodman units and they should be able to help you.
Posted on Sep 02, 2010
How do I check the start and run caps on a 5hp.22gal compresor. runs for 1 or 2 sec. then trips breaker.
To properly test capacitors requires a capacitor tester some multimeters do this. An indication of properly functioning capacitor can be checked with multimeter and checking ohms. The ohms on meters highest setting should show resistance for a couple seconds then go open. I'm curious to know amp draw when breaker trips and ohm out motor leads.
Dec 23, 2014 | Air Tools & Compressors
I have a GE Minisplit model AE1C12DBH1 and the fan motor does not work, I would like to know where I can get it or a replacement part?
check for tight connection of motor in pcb and in strip, check for capacitor , if everything found ok then it means motor get blown off , replace it
Oct 12, 2013 | GE Quiet-Aire Ductless Mini Split System...
Refridegerator too cold runs continuously.
by the looks of it this model has a main control board on the back.. problably bad
Apr 25, 2010 | GE GSH25JSRSS Stainless Steel Side by Side...
Duo therm air conditioner that the compressor will not start
Hello,The freezestat should be closed.Try jumping that out .
Apr 18, 2010 | Dometic Rooftop RV Air Conditioner
I have a Sanborn Black Max 22 gal. compressor Mod#B109BLR300-22SWC. The motor is a Magnetic/Century 3 H.P. 115v Model 8-165730-20 Ser# BF-532 15A-7.5 RPM 3450. It is missing the run and start capacitors....
Sep 10, 2009 | Air Tools & Compressors
Have a true reach in freezer model #T-72f missing start and run capacitor and relay need specs no service man.
call factory tell them what you have model ask for part numbers on capacitors. its only gonna be start cap
Aug 26, 2009 | Refrigerators
Fan running but dont hear comp. turning on
First check for burned wires in all the componnents in the condensing unit ,also the compresor terminals ,if they're all ok and if you know how and have a tester check the compresor if is not burned or grounded. After that you can replace the capacitor (is no more than $20) and if still won't start it means the compresor is either burned or stock.You can also try to put a start booster in parallel with the capacitor ,sometimes it helps it to start.
Aug 11, 2009 | Goodman CKL60AR60 Air Conditioner
Ruud 10 compressor not working
First make sure there's power to the unit outside , if yes set the theermostat on cold ,auto and to the lowest degrees ,then look the outside unit contactor, it should be pulled in (sometimes it takes to 5 minutes beacause a time delay) , if not the problem is in the thermostat , but if yes and there's power on the other side of the contactor ,either the compresor running capacitor is bad or the compresor itself went bad .Try replacing the capacitor first (the cheaper option) and adding a startting booster in paralel with the capacitor ,if still the compresor doesn't start you nedd to replaced it.All this counting that the fan in the outside unit works ,if doesn't replaced it.
Aug 05, 2009 | Ruud Matching Split Air Conditioner
Condensor fan runs but the compressor wont start
Either you have abad comoresor or abad compresor relay ,i will try to replace the relay first(if you don't have away to check the compresor) wich is cheaper (about $20 for the part)If doesn't work the compresor is burned or stuck.
Apr 20, 2009 | Refrigerators
be careful but dose in gas slowly until the frost line reaches the end of the evaporator
Mar 21, 2007 | GE Quiet-Aire Ductless Mini Split System...
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
