When inserting the installation disc and going thru the steps it fails because it says there is no downloadable data
    Top Expert:
  • Computers & ... Master
  • 23,200 Answers
If you were to explain what you are installing and on to what system, that would help you get an answer.
Posted on Dec 20, 2016
Hp photosmart 310c will not install on windows 7
IssueThe HP printer software installation fails to run in Windows 7 on a computer with an AMD C-50, C-60, or Z-01 1.00 GHz processor. After you insert the HP printer software installation CD or run the driver installation downloaded from the HP website, the setup does not open. You might receive an "HP Installer Setup has stopped working" error message.
'HP Installer Setup has stopped working' or Setup Does Not Run When Installing the HP Printer Software in Windows 7IssueThe HP printer software installation fails to run in Windows 7 on a computer with an AMD C-50, C-60, or Z-01 1.00 GHz processor. After you insert the HP printer software installation CD or run the driver installation downloaded from the HP website, the setup does not open. You might receive an "HP Installer Setup has stopped working" error message.note.pngNOTE:This document does not apply to HP LaserJet printers.Preliminary stepThe solution in this document resolves software installation issues only for Windows 7 computers with an AMD C-50, C-60, or Z-01 1.00 GHz processor.
  1. On the Windows taskbar, click the Windows icon (c01319360.gif ), right-click Computer , and then click Properties .
  2. In the System section under Processor , find the manufacturer, model, and speed (GHz) of the processor.
If your computer runs an AMD C-50, C-60, or Z-01 1.00 GHz processor, continue with the steps in the following solution.SolutionFollow these steps to download and install the newest, full-feature version of your HP printer software. Then, download and install a software patch to complete the installation.Step one: Download the softwarenote.pngNOTE:You must download the Full Feature software to resolve the installation issue.
Mar 24, 2013 | HP PhotoSmart Office Equipment & Supplies
Tip
How to copy dvd to iso on mac
An ISO image is an archive file (also known as a disk image) of an optical disc in a definite format. An ISO image includes all the data of files contained on the archived CD/DVD, or any other disc format. They are stored in an uncompressed format. In addition to data of the files it also contains all the file system metadata, including boot code, structures, and attributes.
DVD Copy Mac has the ability to Copy DVD to ISO Mac, burn ISO file to an optical Disc, copy ISO file to hard disc.
Free Download DVD Copy Mac, Then install and lunch it.
Step 1: Insert DVD Disc
Launch the Copy DVD to ISO Mac program and it will remind you to insert your DVD, Then you choose the DVD-Video that you want to copy in the pop-up folder.
Step2: Select the target
You can select to copy a new DVD disc or copy to your hard disk on your Mac. Click "Start" button after finishing selecting. It can burn DVD-Video disc and save the target as DVD Folder or Image(.iso).
Step 3: Start the Mac DVD Copy to ISO
After all things done, click the "Start" button to start to Copy DVD to ISO Mac.
Step 4: Copy finished
After the copy is done, a window will appear to inform you that the copy is finished. Click "Finish" to close the window and end the Copy DVD to ISO for Mac.
Tips of Copy DVD to ISO for Mac:
After choosing to copy a new DVD disc or hard disk on your Mac, you can do some settings, for example the DVD Name for the new blank disc or hard disk, select the burner if your have more than one and select the burning speed and copies
on Jul 23, 2010 | Computers & Internet
Micro sd 2gb tidak bisa format
Hallo scorpio, semoga solusi ini membantu
If the micro SD format fails, do not you repeat the formatting process. Because it will exacerbate the damage to the micro SD. Follow the steps below. Good luck.
All you have to do is:
Step One:
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
The first alternative - use the software HP Drive Key Boot Utility
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
If the second solution does not work, it means your micro SD damaged firmware. Based on experience, one of the causes of damage to the firmware is, the formatting process is done repeatedly, but always failed.
I hope this information helps. Thank you for using FixYa!
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
Need to change Vista Ultimate System for Windows for Windows XP, in my laptop HP pavilion ze4229. Is there a domestic way to do it?
first thing you'll need is a genuine copy of windows xp to install from.
you will also need to format the hard drive before you attempt to insert the xp disc otherwise it will usually fail. you can do this with the hirens boot disc by going into mini xp then format the c drive.
replace the hirens disc with the xp disc and restart the computer and install xp.
http://www.hirensbootcd.org/download/
'don't download the recommended download under the hirens title, go down the page to the hirens zip file)
Apr 09, 2011 | TechFuel AC Adapter (ACNB120W721) for HP...
How do I copy the mini disc onto a dvd disc, is there a converter program I need to download so that I can then burn several mini discs onto a 2 hour dvd?
Hi, You can convert mini disc ( 8 cm diameter ) to a standard DVD disc via your PC. Please follow this steps : 1. Install your canon software/driver in PC 2. Install DVD creator in PC ( common software is use Nero scout) 3. Download your mini disc data to PC 4. Enhanced your data with Nero 5. Burn your data to standard DVD
Make sure you have DVD RW hardware in your PC.
Dec 04, 2010 | Canon DC210 DVD Camcorder
My ibook (G3 700 two USB) stars but the screen continues to be dark I willl like restart, without any problema about data
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica; min-height: 14.0px}
Check for a failing hard drive
Trying booting from the Mac OS X install disc.
insert the Mac OS X install disc.
press the start button, while holding down the "C" key on the keyboard
Once you are running from the disc. go to Disk Utilities select the hard drive click the "repair permissions" button at the bottom.
If you get any red errors listed or it doesn't seem to finish repairing the permissions you have a failing hard drive and it will need to be replaced.
Nov 20, 2010 | Apple iBook G3 Mac Notebook
My desktop and appliaction are not opening on my
If the permissions get repaired and you still have the same issues you will need to restall the operating system. Backup important data before you do.
Jul 25, 2010 | Apple Power Mac G5 Desktop
Reinstalling to wipe laptop misplaced manual
OK insert DVD into drive set PC to BOOT from DVD, when it boots, go thru till you reach the place where it asks if ya wanna format the drive, do so. Then follow instructions until it finishes. Then you have wiped all old data etc and reinstalled ya operating system.
Jan 26, 2010 | Computers & Internet
Umar Hills wont load.
I have the same issue, the game asks for disc 3. It can read the disc i used it to start up the game it has nothing to do with the switching discs. I had the BG folder open with the game on small screen. I went to other areas, i use the ToB disc and in the BG folder when i went to other areas, it reads the folder i.e. disc 2. and i didn't have to change discs. but it didn't read the folder disc 3 when i went to umar hills WTF. I reloaded the game too but still fails.
Apr 19, 2009 | Macplay Baldur's Gate II: Shadows Of Amn...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
