Indicator has continious blink meaning reversed polarity, how do I correct it?
2 Suggested Answers
  • 118 Answers
SOURCE: LED light blinking constantly
short in a/c wires on contactor is bad, disconnect wires at a/c and power up if no pop fuse it is the contactor. if still pops replace wire.
Posted on Oct 29, 2009
Jump start with reversed cables. Now car wont start? Ideas?
Oh, oh. U did something stu--d and trashed the electrical system of the car with the reversed polarity. There is no telling just what you trashed - hope you have lots of dinero for the diagnostics and/or repair.
Apr 08, 2017 | Cars & Trucks
Why my apc ups change its polarity after mains failuer
Probably because polarity at the plug is reversed, check for that.
There is a red LED at the back of the unit, if it is lit, polarity at the plug is reversed, you will have to correct this.
Apr 30, 2014 | APC Smart-UPS 1000VA UPS System
Coleman furnace
Reverse polarity means the power wires coming to the furnace are connected backwards. The black wire should the hot ( 120 volt line) . The white wire should be the neutral. The green should be the ground. Check these connections and test them to make sure they are correct. You should get 120 volt reading between the black and white.120 volts between the black and green and 0 volts between the white and green. Hope this helps.
Jan 02, 2014 | Heating & Cooling
My gibson furnace geves the error L1 neutral polarity
This means the hot ( L1 ) and the neutral connections are reversed.check the 120 volt power to the furnace for the correct polarity also make sure there is a good ground connection. Hope this helps.
Dec 07, 2013 | Heating & Cooling
What is reverse polarity
Reverse polarity means in a dc voltage scenario (boat camper anything 12 volt Dc) thatvthe positive ( red) and the negative ( black ) have been switched or reversed.In a 120 volt ac scenario (house ,garage , outlet etc.) It means the hot
( black ) and the neutral ( white) are reversed.
hope this helps.
Dec 04, 2013 | Heating & Cooling
My neutron R32 blinks continious yellow when switched on
blinking yellow light usally means the motors are not engaged so find the levers to reengage motors
Dec 04, 2013 | Invacare Health & Beauty
Apr 24, 2009 | Goodman GDS80703ANA Open Flame Mid-Size...
Goodman heater will not start have continuous blinking light replaced secondary transformer still no work and continusous blinking verified 120 volts to vent fan but vent fan not running vent fan ohms to...
I cant be sure but usually the constant blink on some boards means reversed polarity. Check your HOT (L1 - Black) comming in to the connector box and the your NUTURAL (L3 - White) should not read any volts to ground (not more than 12 volts on an electronic VOM). If this is opposite remove power and reverse black and white wires and retry.
HOPE THIS HELPS PLEASE GRADE ME ACCORDINGLY and GOOD LUCK!
Mar 03, 2009 | Goodman GMS90703BXA Heater
6 blinks
sounds to me like i wish i could find out if this is new install or if the electric has been changed recently,,,sounds like reversed polarity on the plug,,,which means the white and black wires need to be swapped. If there has not been change recently than u need to see the other post i made on goodman about the combustion fan motors and there types and fixes. But almost certain that is reversed polarity. good luck
Oct 23, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
