Question about Sewing Machines
How to remove thread that has wound itself around the back of the bobbin case on a Pfaff tipmatic 1035. Is it possible to remove the top plate to get access?
  • Sewing Machines Master
  • 11,494 Answers
Remove the bobbin case. If the machine has a free-arm cover, it should be removed also. On most older machines, there are multiple needle plates (zig-zag or straight-stitch) available so they are removable & exchangeable, but for your machine, you'd have to verify. You'll have to carefully remove the threads by cutting with a tiny pair of scissors and pulling the threads using needle-nose pliers or tweezers. If you are unable to remove all the threads, you may need to take it for service.
PFAFF Tipmatic 1014 Instruction Book Page 11
PFAFF Tipmatic 1035 Manuals
Pfaff Tipmatic 1035 Owner Manual Page 2
Posted on Dec 20, 2016
This is on a 5.0 pfaff sewing it will build a bird nest below the plate
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the top tension to the midway point (may need to tweak this for your particular machine).
Remove the bobbin thread from the machine. Reinstall the bobbin in the bobbin case confirming the bobbin is turning the correct direction and the bobbin case is correctly threaded.
Pull the bobbin thread up to the top of the fabric and gently hold both thread tails in your left hand when slowly taking the first couple of stitches.
Apr 30, 2017 | PfaFF Sewing Machines
How do I unjam a pfaff sewing machine
If possible, try removing the bobbin & bobbin case. That will usually allow access to any thread accumulation.
Sep 26, 2016 | PfaFF Sewing Machines
I have a Pfaff 4.2 Quilt Expression. I am free motion quilting and the bobbin thread keeps hanging up. Any suggestions?
1. The top loading bobbin cases have small brackets to keep them from turning or moving up or down.
2. Adjust brackets with small screwdriver. Allow enough room for thread to flow through.
3. Rotate hand wheel both directions to make sure the bobbin case doesn't move around. Also, watch the thread to see if it is flowing across the top of the bobbin case.
4. You may need to slow down movement of your "free motion". Also, make sure you are using the right pressure foot.
Mar 20, 2015 | PfaFF Sewing Machines
Thread caught behind the bobbin case holder
Take off the presser foot
take off the needle plate
take off the bobbin plate
take out the needle,
clip bobbin free,
Examine the bobbin carrier on how it fits into place. (important)
Lift out the bobbin carrier.
Each machine is a little different. You may want to take pictures as you do each step for later reference. Use something like an old egg carton or a muffin tin to keep your parts from rolling around or getting knocked off an lost.
Have fun.
Nov 05, 2012 | Pfaff Creative 4.0 Sewing Machnie
How to remove and fill bobbin
Locate the bobbin access panel to the right of the presser foot. Place thumb tip in the oval hole and pull to the left, (It might also tip up, but I doubt it.) Reach in and lift and grasp the little lever on the bobbin case, pull it out. Remove bobbin from case. Select the thread you want to fill the bobbin with. Place it on the thread spindle. Pull thread trough the small round tension disc on top of the machine and back toward the short spindle on the right top of the machine. If your bobbins have holes.. thread a hole and place the botton on that short spindle. Slide the bobbin and spindle toward the metal "fence". Loosen the hand wheel by turning the center knob counter clock wise. Grasp the little thread on the bobbin and start winding a few revolutions with you holding the thread. Stop and clip that short thread close to the bobbin then continue winding until full.
When the bobbin is full. Return the hand wheel knob to it's original position. Slide the bobbin winder spindle away from the "fence" and remove the bobbin. Place the bobbin in the case with the bobbin facing you... the thread when pulled should rotate the bobbin itself clockwise (VERY Important!) Hold the lever open and replace the bobbin.
For your convenience I have located this PDF for your machine. (be patient, it takes a while to load)$FILE/Pfaff%20260%20.PDF
Aug 09, 2012 | PfaFF Sewing Machines
Pfaff 4.0 quilt expression pulling bobbin thread up to top of fabric help.
try a new needle
rethread the machine top & bobbin
try adjusting the top tension just a touch to see if that helps
clean under the needle plate & in the bobbin area for loose threads
or lint
make sure the bobbin is wound correctly & inserted into the bobbin
case correctly
Jun 04, 2012 | Pfaff Creative 4.0 Sewing Machnie
Singer 2263 will not sew because bobbin thread winds back around the bobbin
have you tried changing the needle?
clean under the needle plate & in the bobbin area for lint
make sure the bobbin is inserted correctly into the bobbin case & also wound correctly
May 14, 2012 | Singer 2263 Mechanical Sewing Machine
How to thread a bobbin
Which Singer machine do you have? I know how to wind and insert a full bobbin for some models.
Some wind the bobbin with it in the case. This is the case with my Touch & Sew. Inserting a full bobbin is simple. Open the slide plate and drop in the bobbin with the rings up. Make sure that to hold the bobbin thread so that it comes off at the left. Then close the slide plate and make sure that the end of the bobbin thread is coming through the notch. Hold onto the threads and turn the handwheel until the top and bottom thread come back up with a twist. To wind a bobbin for this machine, open the slide plate (some models have a little mark to line up the slide plate). Put in the empty bobbin and thread the top normally. Set the machine to straight stitch and push the bobbin wind button in. (This has a bulls-eye symbol on it.) Wrap the end of the top thread around the presser foot screw several times and hold onto the end. Step on the foot control to start winding. Keep winding until the bobbin is full. The thread wound onto the screw should break. Pull some extra thread and cut it to separate the top and bottom threads. Close the slide plate and set your desired stitch.
Other models are wound at the top of the machine. For some of with a drop-in bobbin, you need to bring the thread down to a catch and then off to the left to another catch. Some have a vertical bobbin. I don't remember if they all have a removable case. Those that do need the thread to come through a notch on the case that pulls the thread under a spring that keeps the bobbin tension. However you should check your manual. If you do not have a manual, check if one is available online. ( has many of the Singer manuals for sale or download.)
If you post a comment with the model of your machine, I'll give you a description of threading the bobbin or winding one.
Jan 19, 2012 | Singer Sewing Machines
My bobbin binds up quite frequently. I pull it out to find that thread has wound around the post under the actual bobbin in the bobbin case
Is the case in correctly, in the correct direction so that the thread is not unwinding?? Also make sure area is free of dust, threads & has been oiled recently.
Sep 26, 2010 | PfaFF Quilt & Craft Pro 7530
I pulled out the lubricating strip under the bobbin
Bobbin Winding 1 Put spool of thread on spool pin. ] Use spool cushion when using cross wound thread. ] Use spool cap when using parallelwound thread. 2 Lift thread guide bar all the way up, and run thread through triangular thread guide as shown in drawing. 3Run thread through bobbin winding thread guide as shown in drawing. 4 Run thread through top thread notch 1, and align bottom thread notch 2 with guide pin on bobbin winder shaft. 5 Press bobbin stop up against empty bobbin. If the bobbin stop does not slide easily between the top and bottom of the bobbin, check that the bobbin is seated properly with the guide pin (4) inserted into the lower notch 6 While holding the end of the thread, step on the foot controller for a few seconds. Once enough thread has wound itself around the bobbin to hold itself in place, release the foot controller and trim the excess thread. 7 Stop winding when bobbin Begin
8 Manually move bobbin stop back to original position. 9 Cut thread and remove bobbin.
bobbin insertion 1 Lift slide plate (and open bobbin door). 2 Put bobbin into the bobbin case. ] Run thread through thread notch and under latch spring, so that a length of about 10 cm is exposed. ] Use a bobbin case with an idling prevention spring. 3 Pull the latch lever of the bobbin case out and push the bobbin case into the shuttle race and release the latch lever. ] If the latch lever is not all the way on the hook, it may fly off during sewing and cause lower thread breakage. 4 Lower slide plate and close bobbin door, following numbers 1 2 above in order. 6 While holding the end of the thread, step on the foot controller for a few seconds. Once enough thread has wound itself around the bobbin to hold itself in place, release the foot controller and trim the excess thread. 7 Stop winding when bobbin is full. Take foot off foot controller. * Place the thread end so that it does not protrude from the bobbin. Bobbin Stop
so this will be ok and no need to worry about this
Jun 23, 2009 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
61 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
