Question about Samsung UN55FH6200F 55" LED TV 1920x1080, 240 Hz, HDTV
Samsung UN55FH6200 replace main & t-con board. screen black can barely see display word when power on. Saw burn mark near where power cord plugs in on Power Board. Can the Power Board cause this
  • Samsung Master
  • 6,694 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Dec 20, 2016
Samsung un65h7150fxza, no sound & no picture. The back light is lit but the standby light is out.
T con board only affects video. Your issue is for audio and video . > main board issue.
Sep 11, 2017 | Samsung Televison & Video
Samsung smart tv no picture and sound. Replaced T-CON and Main Board. Same result. Any ideas?
did you change power supply? how many times does light flash (red) you didnt change the power supply did you use a vom on connections?
We Are Here To Help !!!
Donal Deane MCSE,ASE,CPO
Aug 18, 2017 | Samsung Televison & Video
When I plugged iron in sparks came out at wall and iron where the cord connects.
If you've had this iron for a while it sounds like the cord may be frayed.
switch it off at the wall and unplug it, check the cord for wear, if the insulation is frayed, torn or broken and there are black burn marks on the cord where you saw sparks then the cord needs to be replaced.
DONT plug the iron back in until the cord is replaced.
Otherwise If there are no breaks or black burn marks on the cord, then your power point may be faulty and needs to be replaced!
I hope this was helpful
MobileJB
Jul 13, 2011 | Oreck Cordless Speed JP8100CA Iron
No picture sound only
If the backlight works (meaning that when the tv is on, and the lights in your house are turned off, there is a black glow coming from the screen) then you know your backlight is powered and such.
So far, so good... the next problem lies in one of two places (most likely). It could be the main board which is where your connections plug into the set... If this main boards output to the t-con board is dead, then replacing the main board will fix this problem....
However the more likely problem is with the T-CON board. If you open your unit, there is a silver metal casing with some screws near the top of the screen. You will notice some metallic tape at the top of this metal piece. Also, you will notice a wire harness/ribbon cable connecting just under the base of this metal. Beneath the metal is the T-CON... This board is pretty much the only thing between your main board and the screen.
Replacing the t-con could fix your issue.
If you locate this board, there should be a model number located on the upper-right corner. Be sure and replace it with the correct part.
Please keep in mind that although I am tech savvy, I am not a certified samsung technician.
I hear that a good place to order such parts is shopjimmy.com
Good Luck!
Feb 09, 2011 | Samsung LN-T3253H 32 in. LCD Television
Samsung UN55FH6200F 55" LED TV 1920x1080, 240 Hz, HDTV Logo
119 people viewed this question
Jerry Greenberg
Jerry Greenberg
