Question about Jenn Air Kitchen Ranges
Jenn Air stove,JED3430WS01 When on duel, only the outer element comes on,stays on high even on low. I just changed the element. What else could it be? Thank you for your help. Rick
aborcass
  • 2651 Answers
SOURCE: Jenn Air Range SCE30600
i would pull unit out adn look for a bad thermostat on back wall wired inline from bake and broil elemnts, probably tripped during a clean cycle or something got to hot, common for oven to shut down because of bad safety thermo, yet stovetop function without interuption
Posted on Feb 23, 2008
aborcass
  • 2651 Answers
SOURCE: Jenn-Air element won't shut off
most likely its a faulty switch, not completly shutting down trickling power out.
Posted on Mar 16, 2008
  • 135 Answers
SOURCE: I have a Inglis smooth
The swich for the burner is bad and needs to be replaced. The glass will be fine, but unless your just boiling water you wont be abe to use it until you replace the switch.
Posted on Apr 08, 2008
  • 132 Answers
SOURCE: burner heating element stays on high-cannot
there is a thermostat element beside every burner
i think it need to be changed.
thank you
Posted on Jun 08, 2009
pride applia
  • 232 Answers
SOURCE: Largest element heat remains high in every position
you need a new switch no dought
Posted on Dec 24, 2009
THE COOKTOP WONT HEAT UP. BUT THE LIGHT ON THE CONTROL KNOB LIGHTS.
My first guess would be to check for proper connection at the wires from the stove body to that specific heating element.
Perhaps, lift-off or open the cook-top cover, and check the hook-up to the heating element itself.
How old is your stove, and is it fitted with the common "coil type" elements? Unless it's a very late, high-tech model, capable of checking its own wiring, the indicator light will illuminate regardless of an open circuit to the heating element because older models can't "see" or "know" whether something has come loose, so the indicator light will come on, and just sit there, cold and clueless.
Bon Apetit!!
Sep 20, 2016 | Jenn-Air JES9860 Electric Kitchen Range
My stove SVE47100C the elements in the oven do not heat.I have replaced the computer panel a year ago as well as the element
If both of the oven elements stopped working at the same time, and the stove top elements work then the problem is most likely in the high limit fuse. It is the common component to both oven elements.
The control could be bad, but I would have someone test the high limit first. It should read 0 resistance if it is good.
May 17, 2010 | Jenn-Air SVE47100 Slide-In Electric...
What des error cde F1 mean on a Jenn-Air D156 drp-in range
JENN-AIR
'Newer Style' Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
JENN AIR
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
Mar 22, 2010 | Food Processors
Jenn-air stove Model SCE30600B. Won't heat
check all the wiring at the main bus, and at the board connections could be a bad board
Oct 08, 2009 | Jenn-Air Ovens
Burner heating element stays on high-cannot
thank you
Jun 08, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Heating element will not come on
The best to test that is to remove the top and take the outer coil and use it on any of the other burners to see if it heats up, then youll know for sure is the element or the switch.
Eddie Rentas
Tupper Lake NY
May 14, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn air duel fuel problem
Depending on where you purchased the range find out if it is satisfaction guaranteed then either get a new range delivered or your money back. You need a burner selector switch to solve the problem.
Dec 09, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-air manual
You can find everything you need and diagrams at http://www3.sears.com/.  Just type in the model #.  There is no repair manual that I know of.  If you need help solving a problem once you have seen the wiring diagram let me know.
Oct 12, 2007 | Kitchen Ranges
Kitchen Ranges Logo
32 people viewed this question
Top Jenn Air Kitchen Ranges Experts
deton8 von Splosion
myrlanthian
Bill Boyd
Are you a Jenn Air Kitchen Range Expert? Answer questions, earn points and help others
