Question about Nextbook Tablets & eReaders
Own 2 Nextbooksfor less then a yr.HDMI port has failed on both its obvious the port is to weak to hold any HDMI connector.Aluminum housing is extremely weak.Is there a return/repair option available
Kindle not charging
If your Kindle (any version) is not charging because the USB port has gotten loose, try this...wrap a small piece of aluminum foil around your USB connector - the end that plugs into the device. Be careful not to extend the foil past the end of the connector, you don't want to damage your device. Plug the cable in to the outlet and into the Kindle port as usual, then watch the orange light come on!
Kindle charging ports get worn out over time, the foil is a great conductor and makes a solid connection. Obviously, you'll want to try a different cable first, but if that doesn't work, this is free and easy!
on Mar 26, 2015 | Amazon Kindle Fire HD
How do i get the movies from my tablet to play on my tv?
Bluetooth if your television has it, or via your home network. You have to have the same app on the television as your phone. YouTube works really well.
Mar 19, 2016 | Tablets & eReaders
I replaced the front screen. Bottom 2/3 of screen is now scrambled. Can't do a reset as I can't read screen. What do I do?
Try to re insert the connector to the screen. Resetting won't do anything about hardware issues including the screen. Worst comes to worst, you can by a micro/mini(depending on port type)usb to hdmi and hook it up to a TV or other external hdmi display
Mar 06, 2015 | Tablets & eReaders
My kindle wont charge
internal battery probably needs replaced .take to a place that sells them and ask how to do it or have it done .
Feb 15, 2015 | Amazon Kindle Fire HD
Bauhn 9.7 3g tablet will not start up
Many things can cause a tablet fail to start. A damaged battery is one. It can also be due to a burned display. More often than not, it is due to OS having been corrupted. If the tablet can start with the charger connected, chances are the battery is no good and had to be replaced. For defective display, you can try connecting the tablet to a digital TV through the HDMI port. You may see something if the tablet is working but its display is defective. If the OS is corrupted, you will have to reflash its ROM with the right version using a computer. This process is a little too technical for novice. Get help from an expert. Remember, flashing will void your warranty.
There are other less likely causes for startup problem. If it's hardware issue, you are doomed.
Jan 12, 2015 | Tablets & eReaders
How to connect asus memo tab to tv
The ASUS Memo Pad has a Micro HDMI port next to the Micro USB port. Get a Micro HDMI to HDMI cable and you can connect the ASUS Memo Pad to your TV.
May 23, 2014 | ASUS Eee PC T91MTPU17BK Tablet
How to take a part Motorola Universal Dock csd-8109?
Motorola doesn't endorse/support this type of modification.
Motorola Support
Apr 24, 2014 | Motorola Mobility 89512N Platform...
Acer tablet a700 manual
SO sorry to hear this. I have seen to many tablets go BRICK after they are left to charge and then either they stay on the android boot/battery screen or they stick on the logo screen. There is a few things u can try to rescue you tablet.
First is this a acer tablet a700 or is it a acer iconia a 700?
I will assume its the tablet since if it was the iconia phone you would of been more upset for the 300 dollars plus. SO here we go and by no means can i tell u the exact reason these tablets fail or brick after charging.
This is a upper end tablet and not the cheap china clone. so hear is your first thing to try.
DO a hard reset with the keys first. WARNING reset can wipe out all ur data and set it back to factory if thats what u had it set to do. So if u have a sd micro card in its slot.. remove it and disconnect it from the computer dongle too. There are several diff options in recovery settings..back to factory or restore you settings from a backup file.. or wipe it and start all over.
so be aware that by doing a hard reset u can end up reinstalling everything u had on there.
Factory reset is first done with keys. HOLD THE POWER BUTTON AND THE SOUND UP but make sure you have the sleep / lock button right. at same time until it powers off..if not try power/sound up..this is the most common android tablet reset.
If this fails, then
The right side of the tablet is home to a microSD card slot (under a plastic flap) and a micro-HDMI port. The power/sleep/unlock key and 3.5mm headphone jack are located along the left edge, while a volume rocker and orientation lock switch are found on the top edge of the tablet, .
The micro-USB charging and syncing port, as well as a pair of speakers and a reset button, are located at the bottom of the A700
If u have made sure u have the sleep /lock switch in correct position. U have only one option left..the dreaded reset button. its on botton next to the usb sync charge port. Use a paper clip NO SHARP OR POINTS that break PENCIL lead .
DIsconnect from power and remove any micro/usb bridges..hold it in until it powers on and off..then cross your fingers and push the power button and wait.
If this fails to reset it back to factory and revive it. There are some software tools..SDK ANDROID isnt for the weak at heart though..lots of info and things that you will pull ur hair out trying.
If the reset above doesnt work..and u made sure its not in lock/sleep.. u are best off contacting the help line first and then last.
good luck my friend..
I will follow ur post what happens and i will get it
Oct 20, 2013 | Tablets & eReaders
Tablets & eReaders Logo
19 people viewed this question
Top Nextbook Tablets & eReaders Experts
Nhat Nguyen
Andrew Taylor
Andrew Taylor
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
