Question about Hitachi 50V500 50 in. HD-Ready LCD Television
When trying to turn the tv on, it trys to come on for a few minutes and then just shuts down
    Sergeant:
    Champion:
  • 227 Answers
Replace the lamp that's your problem
good luck
Posted on Jul 21, 2009
Hi. I have a samsung HLP-6163WX/XAA projection tv. Recently I asked a question, but I can't seem to add more details to it so I am asking again. After running for ten minutes the tv picture will turn black...
The glue is just protection as far as the lamp gone if you bout an after market on that probably the problem I went threw 5 of them before I to it to a TV repair shop he put in a oem lamp and it's work fine ever since hope this helps
Feb 05, 2015 | Samsung Televison & Video
Replaced lamp, but TV continues to shuts down a few minutes after starting. I replaced the lamp and it still has the same problem. What else can it be? After about 4 or 5 trys, the TV seems to work okay.
Tv have alots of clicking noises too to get tv turn on?The Ballast board is having problems.The Ballast board job it to ignite the projection lamp.
Feb 18, 2011 | Samsung HL-S5687W 56" HDTV
Tv won't turn on. red power light is out
red light is on, but when the tv is turned on, it immediately shut down and goes back to the red light setting. It is like it blows a fuse or something to that effect.Post Solution
Mar 02, 2010 | LG 50PC3D 50 in. Plasma Television
Temp light flashes tried unplugging it for a few minutes turned it on tries to power up but then power , lamp , temp lights flash for a few seconds then it shuts down and temp light stays on
It sounds like you have a thermal issue. The TV is getting too hot or the Thermal Fuse is bad. The thermal fuse detects the temperature in the TV and tells the TV to shut down if it thinks it is too hot. Most likely caused by poor ventilation or clogged fans from household dust. Try moving TV away from wall or cabinet first, if this does not fix the problem, clean ALL the fans in the TV. If problem still persists, replace the thermal fuse.
Oct 04, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
The tv keeps shutting off just after minutes of turning it on. We can wait about 5-10 min before turning it on again but then it only stays on for a few minutes.
This sounds like a heat related problem, which could be a faulty chip or a cold (bad) solder joint on one of the PCBs (printed circuit boards). Due to the lethal voltages present inside a CRT type television, it is strongly advised to have this repaired by a qualified technician. however, if you or someone you know is technically inclined, you can try to fix this yourself. Cold solder joints can often be spotted by visible cracks in the solder joints. a through inspection of all the boards could easily identify the problem which can be resolved with a quick tap with a soldering iron and perhaps a little extra solder added to the joint. if that yields nothing, another method is heat/cold stressing the boards while the TV is running. With the TV on, spray small areas of the PCBs with cold spray (or a can of compressed air duster turned upside down) until the tv shuts off. then heat the last sprayed part with a hot air gun (or a hair dryer) until you can get the problem to repeat regularly. inspect the area causing the problem and you will probably find the culprit.
May 26, 2009 | RCA TruFlat 27F520T 27" TV
Rear Projection TV shuts down after a few minutes.
My science teacher had the same problem.
After, he replaced the lamp it stoped over heating.
witch is most likelywhy the tv is over heating
Jan 21, 2009 | Zenith D52WLCD 52" Rear Projection...
Door locked, start pause light flashing
I also have the same problem. I have got it to work by unplugging for a day and night. When I plug it in the next day it works like new for a couple days and then back to the same old "door locked" problem when the door isn't locked........BIG HEADACHE!!!!
Jun 11, 2008 | GE WSXH208A Front Load Washer
Won't turn on
those tvs will try 3 times before completely shutting down. you can try and take the back off and check CP150 it is a large capactior located near the middle of the board on the left hand side(looking from back) if it looks and feels like the top is vented or puffed out then that could be the problem. if not i suggest having a qualified service tech take a look because there are too many things that could be the root cause.
Apr 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
79 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
