Can i charge multiple phones with a 4-port hi speed usb hub its a microinv modle usb210p s/n 100707059
  • 397 Answers
Do you have Windows XP and at least Service pack 2 installed.
Service Pack 2 comes bundled with the neccessary drivers for USB 2.0
In device manager under the USB heading you must have:
PCI to USB Enhanced Host Controller
In the list.
Posted on Jul 22, 2008
SOURCE: Installing USB Hub
finsphan72's response is correct but you could use information one step earlier.
USB 1.1 is the older version of USB.  USB 2.0 is newer and much faster.  Your computer has hardware in it to talk to USB.  Because it is an older computer, it has USB 1.1 hardware.
The USB hub is just a splitter.  It lets you plug in several USB devices while only using one USB port in your computer.  But it doesn't change the fundamental capabilities of your computer.
The only way to get a computer with USB 1.1 built-in to support USB 2.0 is to add a USB 2.0 card to the computer.  This is an open up the computer and install a piece of hardware operation.  It isn't very hard and it isn't very expensive, but it might not be something you are comfortable doing (and it is possible to mess things up - you probably wouldn't, but you could).  Maybe this is an "ask a high school age friend for a favor" sort of situation.
Posted on Nov 07, 2008
  • 32281 Answers
SOURCE: Power supply for Targus 4 hub usb 2
Most USB hubs do not need an external power supply, except when a connected USB device draws more power than the computer/laptop USB port can supply. In this case an external power supply will need to be connected to the USB hub.
Normally this would be a 5 volt power supply, but make sure the polarity on the connector matches the power connector on the hub, check the label on the hub, sometimes it states to power requirements of the hub as well as the polarity on the connector. Normally the pin on the hub's power connector is positive (ie. +5V)
Posted on Nov 13, 2008
SOURCE: my dynex usb hub is not working
You need to unplug the power adapter from the wall, and disconnect the usb cord from the PC/laptop for at least 30 seconds. Then plug everything back in. Apparently this model suffers from static electricity from time to time. I have this hub also and it works every time.
Posted on Apr 27, 2009
  • 1272 Answers
SOURCE: 4 port USB hub not working...
Try connecting the hub to another USB port. You may even connect this same device to another computer and check if that works. This will help isolate the issue better.
Posted on Jun 23, 2009
Need power supply for kensington PocketHUB 7 Port USB
The K33366 POCKETHUB 7 PORT HI-SPEED USB HUB requires a 5volt supply at 4amps
Jul 02, 2014 | Kensington K33366 POCKETHUB 7 PORT...
Why my siyoteam 4 port usb 2.0 high speed hub not working in windows 8 hp laptop. i plug the port into the laptop but it cannot been seen in my pc, is there any thing can i do inorder this usb hub to work...
Perhaps the laptop port is designed for a usb 3.0 insert instead of a usb 2.0? Also try using compressed air to clean both connections. The hub male end and the laptop female end.
Oct 31, 2013 | Universal Genuine SIYOTEAM 4-Port USB 2.0...
My acer Aspire 57342 usb port seems broke. How do I get it fixed. I have an air card in the rear port but the front port I can't plug my mouse or printer into. Also another question are both usb...
BAD News.
Usually the USB Port is a part of the Mother Board on a PC and the replacement of the Mother Board is the only solution.
You can find them on the internet at Ebay and other locations. BUT it is very involved to replace.
If you have one good USB Port, Get an adapter that will allow multiple inputs.
Question 2. I do not know. On most PC's two are horizintal and two are vertical.
Jul 23, 2011 | Acer Computers & Internet
I have a model m01517 5 port usb hub. It has 2 usb cables to the computer, do I use the blue or black connector? I can only get one port to recognize a device plugged in the other four seem to be dead,...
Not sure I understand this hub either. Looks like only one port is a USB 2.0 port, but here is a snippet from the manual......
This iConcepts USB Hub provides the electronic interface between USB devices and the host, It allows up to five USB devices or Hubs to connect an upstream USB Hub or Host port.
• One USB 2.0 port
• 4 Port USB 1.1 and support high speed (480 mbps) and 4 port full speed (12 mbps) operations.
• The USB 2.0 port can operate both USB 2.0 & 1.1 Devices
• USB 2.0 port supports self powered mode and bus - powered mode, indicated by a powered LED .
• Over current detection and protection
Manual is provided here:
Sep 09, 2010 | Sakar (M01517) 5-Port USB Hub
I installed a 4 port hub to speed up my file tranfer to a flash drive. The files transfer but not any faster then using the front usb ports. It is normal?
Yes. While the speed from the USB device to the USB hub may be faster (USB 2.0 protocol, rather than the slower USB 1.1 protocol), your hub is still connected to a USB 1.1 port on your computer.
Aug 22, 2010 | Belkin ExpressBus (F5U021) 4-Port USB Hub
External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Jun 14, 2009 | SimpleTech Signature Mini 160GB External...
My sandisk wont charge?
I had the same problem until I purchased a Hi-speed USB 2.0 4-port Hub. Try using the Hub as a AC charging unit and see if this works.
Feb 28, 2009 | SanDisk Sansa Clip MP3 Player
"A HI SPEED USB device plugged into a non HI SPEED USB hub" error message, any idea? every time i plug a usb in to my computer it comes up that this device can perfom faster on a hi-speed usb port
This is not an error it just means that you are plugging in a usb 2.0 device into a usb 1.0 port. The devise will still function normally just not as fast. You could always add a usb 2.0 pci card to your computer.
May 05, 2008 | Samsung YP-K3 MP3 Player
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
