My dawlance dwf-3500hz shows EA1 error - Washing Machines
My Daewoo DWF 806 MP doesnt dry/spin after washing and rinsing and shows LE error. When drying starts some sound comes and then LE error apperas
my Daedwoo DWF-806 MP machine when i swith on shows figure 49 and not figure 0, and it also making noise like Buzz in between when the machine is ON. Can anybody help me to resolve this defect
thanks
Nov 01, 2013 | Daewoo Washing Machines
My washwe daewoo dwf-1150wp present problem by making it function on starts to sound a beep and the display shows error 9 and makes no function
Pressure sensor error
The washing machine has detected an error with the pressure switch or level sensor
  • Check wiring to level sensor
  • Check level sensor
cheers-Denny
Oct 18, 2013 | Washing Machines
Like to set digital timer.It's a Provalue TS-EA1
1) Copy following links for possible TS-EA1 timer manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
http://waterheatertimer.org/pdf/TS-EA1-digital-timer-manual.pdf
2) This is a new series of 50 Hz timers made for worldwide 230Volt market.
Manual was written based on other similar timers, and how those timer buttons worked, although there is not another timer with 1:1 same buttons.
3) Add comment and say what you discover when trying to program your timer. Then possible manual can change accordingly.
Jan 06, 2013 | Hardware & Accessories
Want to set timer on Provalue ts-EA1
Evidently there are several brand names selling TS-EA1 timer
Jan 06, 2013 | Sunbeam 6 Robinson Home Digital Timer
Daewoo washing machines dwf 7108 error e4
my deewoo 7kg showing E4 when power was switch on.
Oct 19, 2012 | Washing Machines
Dawlance split air conditioner shows the eror in display f6
Check the condensor fan motor. If less RPM replace capacitor. still continues, replace f.motor.
Aug 25, 2012 | Dometic Heating & Cooling
Dawlance monogram error code e5
P1 error code in dawalance inverter
Jun 12, 2012 | Heating & Cooling
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
