SOURCE: Car audio
Product Details and Features
PLX-520
Key Features
Amplifier Type
Dual Channel
Bridgable
Bridgable
RMS Power at 2 Ohms
400 W x 2
Performance
Frequency Response
10 Hz - 50000 Hz
Signal to Noise Ratio
102 dB
THD at Rated RMS Power
0.01 %
Crossover / Equalizer
Bass Boost
With Bass Boost
Low - Pass Frequency
50 Hz - 120 Hz
High - Pass Frequency
80 Hz - 800 Hz
Other Features
MOSFET Circuitry
Yes
3 Way Ready
Yes
Dimensions
Width
10.4 in.
Depth
17.7 in.
Height
2 in.
..This is what I found for logic soundlab PLX-520 Amplifier, hope its what you were looking for. Don't forget to rate answers.
SOURCE: the low input plug on my logic soundlab cpx1820 is broken.
Hello lucky33irish,
If it is just the plug that is broken, it's a rather easy fix. Just solder on a new plug. Look closely at the old one to make sure that you match up the wires correctly. You can get replacement plugs at Radio Shack or try this web site. I like the Switchcraft 3502. It's very durable and easy to work with.
http://www.mcmelectronics.com/
A better fix would be to replace the cables with a new set of RCA's.
If the pin from the old plug is broken off inside the jack, you'll need to remove it. I usually start with a scratch awl and gently pry the old pin backwards until I can get ahold of it with a pair of needle nose pliers. Just be careful that you don't push it in deeper.
Anyway, hope this helps.
SOURCE: logic soundlab cpx1400 need to wire to a kicker cvr 15
Hello discrete01,
The Kicker model number 07CVR122 has dual 2 ohm voice coils, and can be wired for either 1 ohm or 4 ohms. Model number 07CVR124 has dual 4 ohm voice coils and can be wired for either 2 ohms or 8 ohms.
Kicker's wiring page is here: http://www.kicker.com/dvc_wiring
If you have the version with 2 ohm voice coils, you want to use the 2nd diagram for a final load of 4 ohms to the amp. The 1 ohm load is too low for the amp and will cause it to overheat and possibly fail. If you have the 4 ohm version, use the wiring shown in the 3rd diagram which is a perfect match for the amp.
Hope this helps.
SOURCE: logic soundlab plx 46 red led lit
does it have sound if not it may be on a protect or themal mode try taking our=t your main fuse when the system is in and put it back in
