Question about Cooktops
The igniter does no spark when pushing in the knob
Ignatior keeps sparking and stop why
i presume the sparking is actuated by when you push down on the knob. there is a switch under there. remove the knob by pulling it and use some small drop of cooking oil on the shaft to free it up. pres and pull till it works freely. this should allow the spring in side to push the knob up easily and turn of the sparking.
Sep 09, 2016 | Cooktops
Burner igniters keep sparking long after the burner is lighted
The igniter is activated by a pressure switch, when you press a button or push in the knob, sounds like it has a bit of gunk in ther e stopping it from coming out again.
Mar 05, 2014 | Thermador SGS36GS Gas Cooktop
Hello, My Creda cookertop ignition system has a problem . There are 4 burners on this CT. 2 diagonally across burners cannot ignite when their knobs are activated but they show sparks of ignition when the...
(1) Get Naval Jelly (Rust dissolver) and apply on the igniter and than see if everything is fine.
(2) Check the connections from the knob to the burner. Probably have a leak. Replace the wire from the knob to the burner.
Feb 02, 2011 | Cooktops
The ignition on my hob is sparking every second or so constantly on it's own? The knobs don't seem to be stuck down or anything obvious. All four ignition points on the cooking points are visibly sparking.
I think the problem lies at your knob mechanism. Try to service the mechansm. Currently the possible problem is lies at the contact point(electrical) might accidently contact without pressing down the knob. This normally occur when it is hyper press or there are grease in between the contact. Possible solution is replace the damage knob... or repair it.
Aug 19, 2010 | Cooktops
R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
Have Jenn-Air 36" gas cooktop w. 5 burners, black. Mdl JGC8536ADB. Plastic knobs keep splitting, even if we remember to push down before turning. Have replaced two sets and now we're down to two working...
Hi
Thanks for using FixYa. There are a few things to check for. Make sure the electrode (the small metal piece that the spark comes off from) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and not a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it.
The switches or the range control knobs may have got wet and are completing the circuit to the spark module thus causing it to continuously click or fire off sparks continuously. Use your hair/blow dryer and blow some hot air around the spark module area.
This is a typical spark module wire diagram--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 31, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Burner won't light
hi gud day,i think the sensor is we have problem is hard to repair in ur own,try to call the person have expireince for repair that unit, or ur igniter ligther have damage like small broken if u hear have click is ok but much better to check the igniter coz the broken igniter is not directly spark in the burner that why is not light.to check if remove the burner base cover then see if the igniter like a small niddle color white,turn the knob to click the igniter then see it wer the spark directly if u not see it means have a broken igniter.
tns gerbee
May 26, 2009 | Amana AKS3040 Gas Cooktop
Stuck auto ignition
try easing each knob upwards a bit.
Jul 15, 2008 | Smeg 23 in. SE64 Gas Cooktop
Cooktops Logo
65 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
