Question about Sewing Machines
Getting my cams in my sewing machine - Sewing Machines
Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Nov 05, 2009 | Kenmore Sewing Machines
I have a Kenmore 158.850 sewing machine and I want to get the cams for different stitching capabilities... what are the part numbers?
You will have to get part numbers from the supplier or manufacturer, they are normally stamped on the cams.
Nov 04, 2009 | Kenmore 15516 Mechanical Sewing Machine
My Sears Kenmore 1751 siz-zag sewing maching will only sew in reverse. A few minute ago it was sewing fine in both directions. The button I push to make it sew in reverse doesn't feel like it is...
these older cam machines have grease in then that can jam up the cams if you can get the covers off soak the machine with wd-40 and play with the reverse and stitch length if it breaks free try and soak up as much of the wd-40 as you can and then put sewing machine oil in the machine
Jun 21, 2009 | Sewing Machines
Price and avaiability of cam stack and where from??
The camstack stack gear for your sewing machine runs about $110 you can find it at www.parts4sew.com
Apr 22, 2009 | Sewing Machines
Broken Cam
You can try;
http://www.a1sewingmachine.com/parts.html
Email your parts request to them.
Or you can contact your local dealer.
You can get an owner's manual from;
http://www.riccar.com/help/manuals
Mar 28, 2009 | Riccar Sewing Machines
Elna machanical sewing machine
50 year old elnas made stitches by cams. look to see if the machine has a cam in it. you can see this by opening lid on top of machine. cams are black with red or white showing the pattern of the cam. could also have broken cam stack gear. That would require technician with elna experience
Jul 05, 2008 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
22 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
