Question about Sewing Machines
How do you load a cam into the royal viking 40 60
Machine needs to rest message
When you see this message, wait until the OK message is enabled. Tap the OK button and then resume sewing. This message occurs often enough to be listed in the manual under Pop-up messages in both the Sewing and Embroidery section. (That starts on the last few pages of each of these "chapters".) Turning off the machine while this message is displayed may cause on issue with the on-board computer.
For the Husqvarna Viking Designer Diamond Royale, you can find the manual on the product page: http://www.husqvarnaviking.com/en-US/Machines/DESIGNER-DIAMOND-Royale . The direct link to the manual is http://www.husqvarnaviking.com/getattachment/Machines/DESIGNER-DIAMOND-Royale/Designer_Diamond_Royale_manual_ENG.pdf.aspx . The pop-up for the Machine needs to rest is shown on pages 4-26 and 8-14 (pages 74 and 123 of the PDF). The Designer Ruby Royale has the messages on pages 4-24 and 8-14 (70 and 116 of the PDF). The manual for this machine is here: http://www.husqvarnaviking.com/SiteMedia/Products/Machines/-%20DESIGNER%20RUBY%20Royale/Manual/Ruby_Royale-manual-EN.pdf .
I hope this helps. If the message comes up after a few minutes of sewing (under 5), I would recommend that you consider cleaning the bobbin area. Sometimes a flossing swab can help remove debris that has gotten into the corners below the bobbin. If that doesn't help, your machine may need to be serviced.
Nov 22, 2017 | Husqvarna Sewing Machines
The plastic gear in the 6010 Viking is cracked and I'd like to replace it.
Have you searched the internet?
Absolute Sewing Machine Information Husqvarna Viking Service manual
Sewing Machine Viking 6000 Cam Replacement (not sure if it is the cam gear that needs replacement)
If you are unable to find instructions, perhaps you can find an independent sewing machine repair person who would be willing to do it for you.
Jun 03, 2016 | Husqvarna Sewing Machines
My Husqvarna Viking model 6000SL Sewing Machine would only sew in reverse the dealer has got it to sew forward but says the cam is jammed and he cannot get it off can you help?
You will need to have it serviced by a Viking Service Tech. You can find a dealer near you by using the link 'Locate a Dealer' at the Husqvarna Viking Website - http://www.husqvarnaviking.com/us
If the local dealer cannot repair, they can send it to the Viking Service Center in Nashville, TN for repair.
Jul 12, 2014 | Husqvarna Viking 1
I have a Viking sewing machine from the 70's. The cams aren't working correctly. I've had plastic parts and a metal ring replaced by a certified Viking repair person, but still not working correctly. ...
Was the inner zig zag gear replaced? To check this, look in the hole where the cams go. You should see the black plastic gear with 3 slots all the way around where the your cams lock on to. Look at the gear closely. You should NOT see any crack or splits in the plactic gear. If you do, then this why your go on properly.
Apr 25, 2011 | Husqvarna Viking 1
Viking Husqvarna Model 6020 stitch selector will not turn.
look at the cam gear. This is the unit that the cam connects to. It could have a crack or be split completely. If there is a crack the cam stack will have to be replaced. The parts are hard to get and a good technician is needed.
Apr 23, 2010 | Husqvarna Viking 1
Viking 2000 owners manual
http://singerco.com/accessories/manuals.html (for your manual)
Feb 09, 2010 | Husqvarna Viking 1
I need to find a part for my 1964 viking 2000 colormatic. It is the fixed cam (plastic) that is cracked.
That part is called the "permanent cam" the part number is 4111595-01. Your local Husqvarna Viking dealer should have them. You can locate your closest dealer by visiting their web site, they have a dealer locator. Just put in your zip code and they'll show up.
Oct 18, 2009 | Husqvarna Sewing Machines
Looking for replacement cam
I found out that the cams for the 6000 series are no longer available through Viking repair or dealers. I will check on eBay to see if anyone has parts available there.
Mar 26, 2008 | Husqvarna Viking 1
Broken Cam in a Husqvarna 2000
You can find a video on how to do this at Sewingnz Youtube channel playlist
Jan 28, 2008 | Husqvarna Viking 1
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
