Question about Hunter Dryers
Hunter 44360 won't light back up after battery change . No corrosion on contact
5 Suggested Answers
SOURCE: hunter 44360 thermostat wiring
I bought the hunter 44360 programmable thermostat also, and have the same problem with the heat not shutting off. I recently took off the face plate and started looking at the switchess on the back. Look for a switch that has the option "std" or "hp". I flipped the switch to the "std" position and my therrmostat has been working great in heating my home.
hope this helps,
rich
Posted on Nov 18, 2008
  • 205 Answers
SOURCE: Need a user guide/owners manual for a hunter
Most manufactures have all their manuals available (for free) online, if you have trouble finding their site, try google or your fav search, good luck, Chuck
Posted on Mar 16, 2009
Pops65Pony
  • 137 Answers
SOURCE: i need a new manual.
Try this URL. Should be able to download it for free.
http://homeappliance.manualsonline.com/manuals/mfg/hunter/44360.html
Click on the above link. If that doesn't work for you, copy and paste it into your browser's URL line.
Posted on Oct 13, 2009
  • 1428 Answers
SOURCE: hunter prog thermostat 44360 flashing
Just hold down the two buttons for 5 seconds and it will be reprogrammed.
Good luck.
Posted on Feb 13, 2010
Changed batterys have blank screen what do i do now
Did you use a good replacement battery? Put in correctly polarity wise? Check for any corrosion on battery terminals?
Dec 08, 2015 | Hunter 7-Day Program Digital Thermost...
I have a Hunter Thermostat 44360 7 day Programable and I want to cancel all programs and just use it manually amy help?????
There should be a tiny unmarked hole in the front of the thermostat....if so, the thermostat 'reset' micro-switch should be under that hole. Gently stick a thin toothpick inside to depress the switch and get ready to operate it manually.
If there is no hole, separate the thermostat from its sub-base and look closely at the sub-base for a reset button.
Apr 13, 2015 | Hunter 44360 7-Day Programmable Digital...
Heating Model 44360
you should have a 'hold temp' option on your remote, it should then stay at the set temp until you change it
Mar 01, 2014 | Hunter 30124 Air Conditioner
Hunter 44360
check your termostat that is not working well
Nov 16, 2013 | Dryers
I need a new manual for my 44360 Hunter programmable thermostat.
Oct 13, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter fan 44360 won't turn my furnace on
List of things to check:
Are the batteries good?
Is the system switch set to heat, and not cool?
Does the fan come on when you set the fan switch to ON?
If none of these things seem to be the problem, call hunter fan tech support at 1-888-830-1326
Oct 08, 2009 | Hunter Fan Company 5/1/1 Programmable...
Replacing 2 honeywell thermostats with Hunter.
The hunter uses batteries and a ram chip to "remember" how you set it, the common is not needed with the Hunter. Some thermostats used the 24 volts of the thermostat circuit for powering up displays or for internal functions such as relays etc. Modern stats consume such a small amount of juice it is not typically required these days.
Aug 21, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44360 problem
You probably have one of the wires reversed or have the options set incorrectly as to what type of heater you have.  Check your instructions here: http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/42710.pdf
Oct 29, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44360 thermostat wiring
OMG! has anyone came up with a solution? I have the same problem as mlc3530b
Mar 08, 2008 | Hunter Fan Company 5/1/1 Programmable...
Dryers Logo
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
