SOURCE: thermostat control
I would like some help programing the thermostat in my house. Hunter, Model 44300A
Thanks,
SOURCE: My central ac system occasionally
I have seen this is many digital thermostats. The worst problems usually come from the touchscreen thermostats. I would suggest installing a new thermostat. Make sure that you read the instructions before you even remove the old one.
SOURCE: I set temp to 74 and stop at 70 and decresing.
The only thing I can think of other than being just old and worn out is that by design it may not be set to run but so much at a time. Has this always done this since you have had it? It may be needing calibration. One thing you can try is to set it at 2 degrees higher than you want it and then it would shut off at the temp you actually want.
SOURCE: I have a comfort control 2200 thermostat. I
May be the location of the thermostat. Try another thermometer right beside wall thermostat & see what it reads.
