I have a CS-5201 fan parts are missing to hang unit can I get these parts
2 Suggested Answers
  • 257 Answers
SOURCE: I purchased a ceiling fan
The motor is pretty much the entire fan and I have taken apart many of them but I do not see any fees able way that you would be able to get it back together if you could get a motor. I would make sure that the problem is not just the speed capacitor or the speed control switch, witch are fairly simple to replace.
Posted on May 30, 2011
Harbor breeze fan remote unit does not allow the ceiling cap to be replaced
That's a cheap store brand fan. I won't even install one anymore because they're missing parts half the time & they don't give good air flow. If you have the receiver all the way in the hanging bracket, the canapy cover should fit. Is the electricial box even with the ceiling or is it up higher?
Mar 15, 2014 | Dryers
C0046
Fusing section (The Hot part) has a fan well that fan is having problems causing this code. Open and close the front door. The fan at the rear of the fusing unit . Fusing unit has to removed the get to it.
Oct 25, 2012 | Minolta EP4000/5000 CS/PRO Copier
I purchased a ceiling fan fifteen years ago and the motor is going out. I'm not sure what the serial number is, but I found CS-5201. Is this your fan and can I buy a replacement motor.
May 30, 2011 | Hampton Bay 13087 70450 Carousel II...
Have a MINOLTA CSPRO 4000, erro code C0040----"FAN
The fan is not easy to replace...... The fan is located under the black transport belts. The fan is part
of the unit that brings the paper from the transfer & drum to the fuser unit. The unit is black and it looks like tank tracks. From what I remember the fan is acturely in the transport unit ... Good Luck
Apr 27, 2011 | Minolta EP4000/5000 CS/PRO Copier
How do you jump start model dell ps-5201-1d i want to see if it works with out hook in up to the motherboard
use a multimeter or plug a fan into one of the molex connectors, flick the switch and some times the fans will twitch a little when the power supply itself is turned on.
May 28, 2010 | Dell - PS-5201-1D (PS52011D) Power Supply
Receiver installation issue
Most of these fans locate the receiver on the mounting plate (metal part fixed to electrical box where ball hangs). The canopy (decorative part that covers the wiring on ceiling's electrical box) has enough space to hide it. I presume you're missing the manual, so install the fan and slip the receiver in the plate, right between the electrical box and the ball, everything's color coded, securely wire cables from ceiling to power cables in receiver and cables from the receiver to the fan. Slide canopy up and securely fasten with provided screws. Good luck!
Nov 01, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
I have a 4 blade HB cieling fan. 2 above 2 blades. Where to put the reciever seems to be no room. Instructions were missing.
The receivers in my 3 hampton bay fans actually slides into the upper portion of the hanging bracket ( the thing you screwed into your ceiling fixture that the fan hangs off of)..
It fits rather nicely once you make room for it with the wiring etc
Hope this helps.
Jul 07, 2009 | Hampton Bay 24002 Ceiling Fan
HOW TO CHECK IF THE POWER UNIT IS WORKING...? DELL PS-5201-5D
short green & black wire...if smps fan is working then ur smps s fine....& make sure u disc all smps cables from all preperials like cd rom hardisk etc
Apr 10, 2009 | Dell POWER SUPPLY PS-5201-5D (PS52015D)...
My xerox 5201 copier is making black copies. I
Xerox Copy Drum Cartridge 13R83 / 6R737 (20000 Page Yield)
Xerox brand - works in Xerox XC 355 XC 356 5201 5203 5205 5210 5220 5222 5305 5306 PRice is 135.00.. Post response if you want link to site. This will cure your grounding problem. You Cannot fix it, It is a consumable item and has no serviceable parts
Apr 03, 2009 | Xerox Office Equipment & Supplies
k24674
jasbo
jasbo
