Question about Brother Sewing Machines
Bobbin thread is jamming machine
My Brother sewing machine has suddenly started grabbing the fabric in the bobbin area and making big knots that I cant get out of the feed dog area without taking everything apart. Ive changed the needles, thread, bobbin, cleaned everything and oiled. Still happening. What else can I check?
  • Brother Master
  • 12,532 Answers
Remove the top thread, When you re-thread, be sure to ALWAYS RAISE the presser foot so the thread will seat in the tension disk. Verify the thread path is correct. Set the upper tension to the midway point and retest your machine.
Posted on Dec 20, 2016
    Top Expert:
  • Brother Master
  • 51,293 Answers
It indicates that you have a situation called " bird nesting" and that is a result of the needle thread tension being too loose
needle tension should be tight so that when you pull the thread to thread the needle you have to exert a bit of effort to pull the thread through the tension plates
you can adjust up or down from that feeling
thread thickness affects the tension and needle eye size also affects the tension as a small eye on large thread makes the thread movement hard indicating less tension or a big eye on a small thread affects the tension as the thread slips easily and needs more tension to pull the bobbin thread up to the centre of the material being sewn
Thread keeps knotting up under the fabric (bobbin area)
Could be what is called thread nesting or bird nesting.
The first thing to try is installing a brand new needle in your machine. Then try the following suggestions:
sewing machine birdnesting
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
3 Common Sewing Machine Problems and How to Fix Them
Nov 29, 2015 | Brother XL-5130 Mechanical Sewing Machine
I have a brother lx 2500 sewing machine and when it jamed i opened up the bobbin area and cleaned everything but now having problems getting the casing back in
Use a mirror and make sure that the area is perfectly clean and there are no obstructions. Then make sure that the needle is all the way up to the top of its cycle and then insert the bobbin.
Sep 20, 2015 | Brother Sewing Machines
Upper thread gets jammed in bobbin area
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Dec 12, 2012 | Brother Sewing Machines
The thread clicks when it goes around the bobbin and I have to stop sewing as it makes a big knot on the back of the fabric. I have cleaned out the bobbin case but it is still not sewing properly. It was...
Hello Supernana.
Check to see if you have your bobbin in upside down. If your machine requires it to unspool from one side having it spool from the other side (counter clockwise vs clockwise) can cause you problems like this. Your manual should tell the correct direction. My machine (Brother) for instance requires that the thread to pull counter clockwise direction.
Sylvia
Mar 17, 2011 | Elna Quilter's Dream 6003Q
I have a brother sewing machine. i threaded and have rethreaded and threaded the bobbin over and over. it will not move the fabric and botton thread will not catch onto top. what am i doing wrong?
Brother machines are usually a very good brand. Sounds like you are having a small problem with threading..........I know how frustrating that can be!
Start over....totally from the beginning. First, clean the machine of all dust, I use a small paint brush to remove lint from the bobbin case area. Oil the machine. Remove all the thread from the machine, use a different bobbin and rewind it with new thread. Make sure the bobbin thread is the same as the thread you use to thread the upper needle with. Use a new needle that is the appropriate size for your sewing project. Check to make sure the feed dog is moving when you turn the wheel that raises the needle up and down. New needle, new bobbin, new thread......before you place the fabric under the presser foot (and with the presser foot raised), turn the wheel one complete rotation to allow the upper needle thread to catch the bobbin thread. Gently pull both threads out towards the back of the machine, making sure the bobbin thread is now coming up through the little hole in the feed dog plate. Place fabric under the presser foot, lower presser foot and as you slowly start to sew, make sure you have the bobbin thread pulled with slight tension out from the back of the needle. This will take up any slack in the bobbin thread and keep it from making a knotted mess. Good luck, I hope this helps.
Feb 13, 2011 | Sewing Machines
When the needle descends it gets stuck as it enters the bobbin case area. It will only release if I move the bobbin. The thread from the needle gets knotted up and pulls the fabric down into the bobbin...
Could be a few things. Absolutely minutely check that the top thread is threaded properly. Otherwise, it could be: Old thread. incorrect thread for the material. wrong size or blunt needle. or incorrect tension on needle I had this problem and I was missing a part of threading even though I have been sewing for years. :)
Oct 08, 2017 | Brother LS30 Mechanical Sewing Machine
When i start to sew on my Janome sewing machine model Sewist 525S it does a couple of stitches on any stitch type then bangs then sews then bangs then stops. I look to see the problem and the bobbin and...
There has to be a problem in your threading or your needle. You may have the needle inserted backwards, flat side has to face rear or the needle is bent. Totally unthread your machine and make sure that there are no tangles and that it feeding the right way. Watch how they show your for threading and winding the bobbin, plus threading the bobbin. Good luck, but I truly think it is in your threading.
Sep 25, 2010 | Brother LS-1217 Mechanical Sewing Machine
Brother embroidery machine broken
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
Feb 04, 2010 | Brother SE-270D Computerized Sewing...
Upper thread knots up with bobbin thread when sewing a stich
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Thread knotting on the bobbin can be a lot of things but here's some guidance:
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Jamming bobbin case:
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes.
Mar 16, 2009 | Sewing Machines
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
