Question about Refrigerators
How to put in door bar 240534701
I was cleaning refrigerator, took off shelf bar, and cant get it to snap back in tightly. The part # is 240534701
SOURCE: How do you get the door back on
It's annoying but it just slides in from the top. You are probably doing it right but it takes a few times
Posted on Jan 22, 2008
SOURCE: Maytag Elevator Shelf
Let me just say, your post helped me, because I realized that I was not going crazy.  But, I was able to find the manual on this frigerator, which was key.  There was one phrase in the manual that gave me help - "when the glass shelf is pushed to the rear, it will align the rear latches.
Manual from whirlpool website: http://shared.whirlpoolcorp.com/assets/pdfs/literature/MSB2154ARA.pdf
So, the rear latches must be installed in such a way that the sliding glass shelf not only touches them, but pushes them into the correct position.
This fact helped me to try different positions, each time testing to see if the glass shelf would do anything.  Finally, I realized that there is a triangular shaped part of the rear latch.  The hypotenuse of the triangle is what comes into contact with the little nub on the underside of the glass shelf.  The nub on the glass shelf pushes the rear latch along the hypotenuse of the right triangle, and into the correct position.
Here is a picture of it installed in my frigerator,which I am sure will tell it better than any words:
Posted on May 31, 2009
Number5Gayle
  • 98 Answers
SOURCE: refrigerator side not sealing tightly when shut.
Sounds like you may need a new magnetic seal. It is worth the money to fix it, saving electric and your food items.
Good Luck
Posted on Aug 09, 2009
Vac Belts
  • 701 Answers
SOURCE: The beater bar won't spin
Even though the belt is intact it can still be stretched and if it is it won't turn the brush roll when it's on the carpet. Here is a link to the belt you need and to a manual you can view:
Rainbow Replacement Belts and Manual
Posted on Nov 28, 2009
  • 10865 Answers
SOURCE: Oven door hinge
Hi Monica. Use a flat blade screw driver to pry the hinge back into the open position. Once you have done that, I recommend that you enlist the aid of a friend to help you slide the door back on as it really is a two person job. Regards, Joe
Posted on Dec 16, 2009
Testimonial: "very good and quick response. Thanx"
Took maytag oven door off to clean cannot get it back on hinges will.not stay open and keep.snapping back fingers r sore took a pipe to pull them back but they wont stay How do I keep them from snapping...
It is a two person job unless you want to pull the whole stove out and take the cover off and then remove the springs. Put the door back on and put the springs back and the put the cover back on.
Oct 10, 2014 | Ovens
Freezer door won't close tight
There should be adjustments in the hinge assembly. Go to Jen-Air .com, then select parts. They will have diagrams to view for repair, adjustment etc.
May 06, 2014 | Jenn-Air JCD2389G Side by Side...
Can't put shelves back in fridge.
I found the manual online. See if this page helps.
Nov 29, 2013 | GE PSH23PSRSV Stainless Steel Side by Side...
Kenmore model #795 69009 900
Check door make sure the screws are tight, clean door seal with alcohol all the way around, If all that checks out make sure the bottom shelf that your crisper drawers go into is pushed all the way back and there is not a lot of heavy objects weighing the door down make the necessary adjustments.
Jul 28, 2012 | Kenmore Refrigerators
Jenn-Air JCD2389G Side by Side Refrigerator Damper Door fell off. How do I put it back and what will happen if I cant?
Not knowing exactly how you broke it off, its hard to say just how its supposed to go back on. Since these are usually screwed into place, or in some cases its a snap tight fit, something is definitely broken, and you will likely need to replace the damper door. If you do not fix this properly, you will not be able to adjust the fresh food temperatures, and in fact you may freeze your refrigerated food, or it may be not cold enough to keep food fresh at all.
Feb 01, 2011 | Jenn-Air JCD2389G Side by Side...
In cleaning my GE, I took the vegetable/fruit drawers out to clean and can't get them back in properly. The space is tight and there's not enough room to open the door wide enough to slide them back in. ...
You will have to pull the fridge out from the wall till you have room to open the door all the way. If it won't open, there is a stop on the bottom hinge that can be swapped or taken off to allow it to open farther.
If your are sure it's not needed you can just break the styrofoam and throw it away.
Dec 07, 2010 | GE Refrigerators
I can't get the crispers and shelf back in after cleaning.
The bar goes into slots right above the drawers and under the shelf above the drawers. It's not obvious to see at first. It's at the very front of the shelf. You have to slide one end of the bar in first then the other side. The bar sticks out a little on each side so it can sit in the groves on the side walls of the fridge. For the longest we tried to put it underneath the drawers even though we knew it wasn't right. Hope this helps. The Whirlpool website can give you a parts manual if you enter the model number.
Jan 24, 2010 | Refrigerators
My Kitchenaid dishwasher not cleaning dishes on top shelf
You need to clean the jets on the machine arm with an old toothbrush etc... then clean out the debris filter on the bottom of the tub near the dryer bar. The calcification in the little jet areas causes this problem. This should help.
Jan 18, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Whirlpool oven door
The metal bars go under the top door handle part, put them under the part you need to screw back in.
Sep 15, 2008 | Whirlpool RBS245PDS Electric Single Oven
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
