Question about Coffee Makers & Espresso Machines
Our brewer is letting c grounds throughto the cup???
    Top Expert:
  • Coffee Maker... Master
  • 78,267 Answers
Replace the filter?
Posted on Dec 20, 2016
3 Suggested Answers
  • 2976 Answers
SOURCE: Brewer Overfilling
You need a water level float or indicator. Without the brand, model & serial number, I can't give you any specifics but, if you go to the manufacturese website or a small appliance parts website, you should be able to find what you're looking for.
Posted on Jan 15, 2009
heatman101
  • 43501 Answers
SOURCE: At first brewer spitout half cup and bottom of cup
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 28, 2011
Coffee grounds everywhere
The coffee can't get out.
There is a hollow metal pin that punches a hole in the bottom of the K cup to let the coffee out. Either it is missing or clogged.
Feb 17, 2015 | Keurig K350 2.0 Brewer
Why cant I get a full cup of coffee
Brewing a Partial Cup
If the brewer is not brewing the full amount selected, it may be caused by the following:
  • The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
  • The brewer needs to be descaled. Please refer to the descaling instructions.
  • The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup pack.
Jul 27, 2014 | Keurig B60 Coffee Maker
Coffee grounds on top of k cup
Lower chamber is clogged. Clean as per manual page 18
Jul 31, 2012 | Keurig Ultra In Home Single Cup Brewer...
At first brewer spitout half cup and bottom of cup filled/w grounds,now it starts brewing process but no liquid is released ?
heatman101
Aug 24, 2011 | Keurig B60 Coffee Maker
Coffee maker will not make but one size cup
If your brewer is not brewing the full amount selected, it may be caused by the following:
  • The brewer may need to be de-scaled. Please refer to the de-scaling instructions.
  • The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup.
First try to make a descale maybe repeat it the next day.
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
Jul 04, 2011 | Keurig B60 Coffee Maker
Coffee overflows and grounds sit on top of pod
heatman101
May 18, 2011 | Keurig B60 Coffee Maker
My bunn overflows the grounds basket
Do you mean that the brewer basket (which contained ground coffee) is oveflowing before it filters down.
please give me detailed question and give me the modal number.
thanks
Mar 07, 2011 | Bunn 10 Cup Home Coffee Brewer
I can't get a full cup of coffee. I've descaled my machine and it still doesn't work properly. Any other suggestions?
Jan 14, 2011 | Keurig B60 Coffee Maker
Water runs thru maker without k-cup inserted but once I put a k-cup into maker the water drips out only and does not fill up the cup but when i remove the k-cup the water continues to run thru it.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 20, 2010 | Keurig B70 Coffee Maker
Will not percolate. Water is poured, it heats up, no coffee brew
Bunn Home brewers don't perculate. They work the same way that commercial brewers do. Fillit with water, let it heat for about 20 minutes, then put your filter and coffee grounds in the funnel, pour a pot of water into the machine, put the pot on the warmer, and let the water run through. Then enjoy a nice hot cup of coffee.
Apr 12, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
