Question about Pool & Spa
My Diamante spa by HS tooling has a LOC on the display and jets or temps. How do I unlock?
3 Suggested Answers
SOURCE: Mitsubishi HS-U447 VCR in Lock or "Loc" mode
Hopefully you still the VCR. Your's is stuck in "CHILDLOCK" mode. To release the lock you have to have the remote and press the DISPLAY for 8 to 10 seconds.
The purpose of the CHILDLOCK is to prevent others from using your VCR. If you want to set the VCR back on Lock you again press the DISPLAY for 8 to 10 seconds.
This solution is from the owner manual for HS-U448, so I figure your model is the same.
Posted on Jan 18, 2008
  • 111 Answers
SOURCE: My pacific hot tub has LOC on the display and i cant adjust the jets or temp. Is the display locked and how do i unlock it?
Mike,
Yes LOC is a standard topside lock code.
Try these common unlock codes,
Press & Hold Jet Button for 6 seconds
or
Press & Hold Temp Up & Temp down for 6 seconds.
Possibly your jet button is faulty i.e. it is broken internally or when it is pressed the button sticks in the on position and locks out the panel.
If those common codes don't work let me know which brand/topside control your spa has and I will get a more specific answer.
Posted on Jan 17, 2012
Display reads "LOC"
The SD card has a little switch on the left side (Lock/Unlock) that provides write protection for the card. The switch is in the Locked position and the camera can't write to the card. Remove the card and move the switch to the unlocked position (towards the contacts on the end you insert into the camera). Then replace the card carefully so that you do not change the position of that switch.
If that doesn't work, try another SD card.
I hope this helps.
Nov 17, 2013 | Wildgame Innovations Axe 2 2Mp Game Camera
How do I unlock the control panel on my spa?
Here's a link to a list of ways to unlock the control: http://spapartsshop.blogspot.com/2012/02/spa-control-panel-unlock-codes.html
Those guys should be able to help.
Nov 25, 2012 | Hydro Quip Inc Pool & Spa
Mike,
or
Jan 16, 2012 | Pool & Spa
Handset msg says.."Press HS LOC
Since you declined to specify the model of your Uniden DECT 6.0 phone, I can only direct you to select it from the list beginning here. The manual should have illustrations giving the locations of all buttons.
Sep 22, 2011 | Uniden DECT 6.0 Cordless Phone ID
My 1996 jacuzzi will not heat up past 71degrees, it was reading LOC which we removed but it will not increase in heat, the jets and blower are all working.
Sounds like it could be your main contol dial thermostat if the spa is old an has a mechanical thermostat an they tend to go after awhile or if its newer an has a electrical therm then is could have something to do w/the t-stat sensor which is the temp sensor this is the silver probe you should c some where in the inside of the water pertruding from the shell of the spa they start to go an can miss read temps up an down an all spas by ul law can not go above 104 thats why there is also most likly a hi limit sensor in the spa too.what it sounds like is that your sensor is so far off that when the water temp is 72 the sensor is tellin the circuit board that it is 103, an one of the many spas safty features is shutin down the heater to prevent over heating. also the heater could of went if u live in a some what warm area of the world that is what u may get as a temp just from the suns heat. check for power at the heater or read for resistants accross the two leads of the heater if you do not get a ohms reading near ten the heater is bad make sure u shut the power down always
Dec 27, 2009 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Panel reads HHO-----, no temperature display until activate jets, then shows a temperature drop sometimes down to 65 degrees ,then starts heating upwith jets going
"OH" is an overheat error. In normal function, it is used as a safety shut off if the spa water temperature reaches over 110 degrees in the event of a thermostat failure. But more commonly, (if the water temp hasn't gotten too hot) it indicates that the temp sensor(s) have failed. If you have a digital display on the topside controller of your spa, then it is a circuit board controlled spa pack. Most spa builders use the same control pack manufacturer - Balboa Watergroup. The sensor kit usually consists of 2 probes and wires that plug directly onto the circuit board. Depending on the spa, they could both be located onto the heater manifold, or one on the manifold and one mounted to the tub making direct contact with the water via a thru-wall sensor mount. If I knew the spa manufacturer, I could further assist you. If you replace the sensors, and encounter the same problem... then the circuit board is bad, and usually a costly replacement. The sensors are usually listed as a "BA sensor assy" Hope this helps you,
Dec 24, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
I have LOC on the control panel and I am not able
To Unlock Main Control Panel: Press DISPLAY, MODE, and DOWN buttons within five seconds. The “lock” symbol will disappear. All buttons are now active.
Sep 17, 2009 | Pool & Spa
Need code to unlock 1997 Jimmy Radio
the loc code is set the first time the radio is turned on. if you don't know the code there is no legal way to unlock it with out the tools at the dealership.
Aug 14, 2009 | 1998 GMC Jimmy
Mar 06, 2007 | Mitsubishi HS-U447 VHS VCR
Pool & Spa Logo
64 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
